Tested it and works okay for me. Fingers crossed that the next step will benthe consumption sensors
Same here, second zone is available now and integration works as expected. Great job @cjaliaga . Looking forward for new features.
Thank you very much. itās work fine with WH-SDC16H6E5 Unit.
As an alternative, if you use the heishamon device to connect your aquarea heatpump to an MQTT server, Iāve released an integration which works only locally (no connection to the Panasonic cloud).
Here are a few screenshots:
Iāve used Heishamon integration about 3 month for now and Iām very happy with it. Panasonic cloud solution didnāt work very stable for me (often disconnects).
Hi, your heishamon integration works only with the separate device or this is also working on Panasonic Wifi module flashed with GoHeishaMon software GitHub - lsochanowski/GoHeishaMon: port of https://github.com/Egyras/HeishaMon to golang to run directly on CZ-TAW1
This port seems to use same mqtt topics so i think it will work. Try and open an issue if it does not work!
I tried this port as well, but failed. After that I ordered Heishamon board.
Hello, Iām quite fresh in it. How can I āgetā in Grafana temperature of heating water (entity: climate.xxx)? I can see it in dashboard, but as ātotal entityā not a value.
It is been a long time since there has been some updates. Is the integration development still alive? I guess the most requested thing right now should be the consumption sensors.
I built Grafana graphs from Influxdb data.
Iām really looking forward the consumption sensors as well. The integration is great, and Iām only missing this information. Thanks for the effort!
Me too⦠Seem like the integration is not developed that much recently.
Hi Carlos
Iāve been wanting to say this for some time.
Thanks to your work, Home Assistant is now controlling my 9 kW Panasonic All In One - keeping my family warm and at the same time avoiding the expensive hours - with almost no intervention from my side.
Panasonic should pay you for this
I would be happy to send you some payment, but I donāt know how/if that would work through github.
Greetings from Denmark
Hey @XiteKnight,
Thanks a lot for your kind words, Iām really happy to hear that the integration was useful to you and your family, thatās what matters here
And thanks a ton, this means a lot to me I enabled the GitHub Sponsors on integration repo so that should work. Thanks again!!
-Carlos
Is it currently possible to see the complete data of the heat pump (those visible on the service cloud) or only those from the smart cloud?
Unfortunately not,
Consumption is not visible which is why I decided to disable the integration in favor of the Panasonic comfort cloud app as consumption is essential.
app on smartphone ?
hate to say this as I really appreciate the hard work put into developing this integration, I also disabled it because the set heating schedule was ignored for few timesā¦
Wouldnāt it be possible to create an integration that reads data from https://aquarea-service.panasonic.com/ via a web scrap?
