šŸ”„ Pellet stove 'Duepi-evo'
@Whatsek They will respond (as they did with me)ā€¦i asked them 2 questions, the pin layout of the connector (which i got) and an overview of the serial commands (which they refused, as it was company proprietary :thinking:)
Well it used to work both remote and local, but a few months ago I connected the device to my IOT wlan and it doesnā€™t work remote anymore. Have not tried to fix it yet.
It looks like my unit reports that during every new session, at least it does when using telnet.
The integration doesnā€™t do anything after the error message (or I am looking in the wrong place)
@Marcel_de_Jong I still have my unit here, if i have time i will try to hook it up again and see if i can fix it :wink:
I appreciate all the work you put in to this, thanks and let me know if I can help
Hallo @Marcel_de_Jong,
Iā€™ve been trying to test again once, but still lack the time to do it.
So much to do, so little time :frowning:
And the USB2Wifi module I put to sale, so once I receive an offer, I do not have the possibility anymore to check.
What I did manage to observe is that the unit communicates very frequently when connected.
Have you tried to set the scan interval way lower (1 or 2 seconds)?
scan_interval: 1
having an issue with your intergration, i am trying to collect locally but its giving me this error in logs,pretty sure i am using the correct ip because i got an notification from my deco saying a new device connected to the network
Hmm
What about port number?
The ESPLink uses port 23 by default, but basically it is a telnet port (meaning you can monitor it using any telnet programšŸ˜‰
Should look something like this:
which is the same what the ESPLink uc shows:
Ahā€¦
I donā€™t think thatā€™ll workā€¦
This user also tried, and I never had the time to investigate it.
In the meanwhile, I sold the wifi moduleā€¦so I canā€™t do any further testsā€¦
I can only recommend to replace it with an ESP01 moduleā€¦
I have provided some info in the first topic on what is needed for that :wink:
The costs for the ESP01, voltage adaptor and programmer is around ā‚¬8,- so that is not too much :wink:
could it also work by using the ESP programmer as a voltage regulator instead of the esp01-s adapter module? so from the programmer (with the esp01s connected) with a usb-female to the pellet stove pinout (gnd,5v,rx,rx)?
nope, programmer is not the same as a voltage regulator
Hi, I have the same problem as you, the port is closed (I was trying to set it up from the beginning of this thread) I cantacted Duepi, and they told me that all the new delivered modules, (since 1 year maybe?) do not have a local port open anymore. Really bad news. They also didnt have an alternative. So we have to build our own board. Unfortunately I not really good with soldering, but I will try to make some time this winter to try to make one. But for the people that cant get an a local connection, this is sadly the bad newsā€¦
With the modules i used there is no soldering involvedā€¦.
Especially when you use one of these:
(female-female)
I recommend the CH340G programmer
and sacrifice a couple of those wires when wiring the serial programmer; just strip and twist, you only need them oncešŸ˜‰,
I
Thank! No soldering will help :wink: I think it will be time to start with the ESP projectsā€¦
If I use this board: Link
Then I can program it directly through the USB connection on that board? Plugin the 4 cables and lets heat the room? :wink:
What type of board is that on the picture? The same but without the programmer functions?
Hmm, you can,
but youā€™re on your own figuring out how to wire it to the stove (canā€™t be that difficult thoughšŸ¤”)
But i think it is easier with the stuff i mentioned (and price wise maybe even cheaper)
I see that the prices on banggood went up, since you ordered. So I will order in the netherlands:
Any usage to order an extra set?
You only need dupont female-female.
Checked Aliexpress??
Thanks! Will have to wait longer, but it is really cheaperā€¦ Quick question, I read about putting the CH340 in download mode (with the older USB model) How do I put the one on your list in download mode? (Thanks, and will post my succes, or failure!)
Mogƻh @Whatsek,
I honestly donā€™t have a clue what theyā€™re talking aboutā€¦maybe weird translation from chinese to english?
try this one instead
ā‚¬ 0,59 22ļ¼… Off | 1PCS USB TTL converter UART module CH340G CH340 3.3V 5V switch
Could i use an esp 8266 instead? Because thatā€™s what i have on hand right now
