Philips Air Purifier
Hello!
I’ve tried to integrate it with Hamilton Beach 04386A, works fine for me! If the air start smelling nicotine, my purifier starts to fresh it quickly!
Ask me if you need any assistance!
What exactly have you integrated with your Hamilton Beach purifier?
As far as i can tell that model is not smart, and certainly not over the same protocol as the Philips purifiers are. Please let us know exactly what it is you have done.
Very interested in this. Please share!
Could you put this in a GitHub repo please? :slight_smile:
Remember to vote here
Did you have any luck polishing the component and publishing it on github? I’d be interested to give it a spin.
I made this component, need some polish and after some days i will release it on GitHub
Awesome! Can’t wait to get my hands on the component. I’ve already got some ideas for a nice visual lovelace card. I’ll get right to it once you post the code! Cheers mate!
More progress now parameters work!
flipping awesome! Now just something to send commands and that’s it.
I’ll take this xiaomi purifier lovelace card and as soon as your code is up and running i’ll map everything over to the philips. (credits for the xiaomi card go to this guy: https://github.com/TheRealBadRobot/Bad-Robot-Lovelace/tree/master/air%20purifier%20card)
xiaomi
Great work you guys!
Will use it when you publish it on github! :+1:t2::+1:t2::+1:t2::+1:t2:
Try to get the time the filters have left also… I know work in progress but better to remind now than later. :wink:
Also added filters, work on adding services to set parameters
Just don’t suddenly disappear from the forum without leaving any code behind like that guy did 3 months ago :slight_smile:
Great work again! :+1:t2::+1:t2::+1:t2:
Now speed work and you can change it, and also Turn On Air Purifier and Turn off work! Only left set parameters!
I release this component on GitHub, but for now Services to set parameters not ready, will be added in next update: https://github.com/xMrVizzy/Philips-AirPurifier
Just had a quick look and it’s found my purifier. Hopefully i’ll have some time tonight to play around with it, but so far so good! Thanks a lot!
Just made a lovelace card based on the sensors we have so far. Pretty pleased with how it looks tbh.
I’ll send you a PM. I think it would be easiest if you add the config for this card to your github as well so people can find the whole deal in 1 location.
What i’m missing until now:
  • Device status not visible
  • not able to send commands yet
ideas:
  • convert filter hours to days
  • display the date when filters need to be changed
  • automations based on outdoor air quality and presence detection :slight_smile:
Here’s the card i’ve slapped together so far:
For anybody that is just as eager as me to get this working, here is what i did so far:
Declare individual sensors in configuration.yaml:
#Philips Air purifier sensors
    sensors:
      purifier_air_quality:
        friendly_name: "Air quality"
        value_template: "{{ states.fan.philips_ac3829.attributes.pm25 }}"
      purifier_humidity:
        friendly_name: "Humidity"
        unit_of_measurement: '%'
        value_template: "{{ states.fan.philips_ac3829.attributes.humidity }}"
      purifier_temperature:
        friendly_name: "Temperature"
        unit_of_measurement: '°C'
        value_template: "{{ states.fan.philips_ac3829.attributes.temperature }}"
      purifier_speed:
        friendly_name: "Speed"
        value_template: "{{ states.fan.philips_ac3829.attributes.speed }}"
      purifier_allergens:
        friendly_name: "Allergen index"
        value_template: "{{ states.fan.philips_ac3829.attributes.allergen_index }}"
      purifier_mode:
        friendly_name: "Mode"
        value_template: "{{ states.fan.philips_ac3829.attributes.function }}"
      purifier_pre_filter:
        friendly_name: "Pre-filter"
        unit_of_measurement: 'Hrs'
        value_template: "{{ states.fan.philips_ac3829.attributes.pre_filter }}"
      purifier_wick_filter:
        friendly_name: "Wick filter"
        value_template: "{{ states.fan.philips_ac3829.attributes.wick_filter }}"
      purifier_carbon_filter:
        friendly_name: "Carbon filter"
        value_template: "{{ states.fan.philips_ac3829.attributes.carbon_filter }}"
      purifier_hepa_filter:
        friendly_name: "HEPA filter"
        value_template: "{{ states.fan.philips_ac3829.attributes. hepa_filter}}"
      purifier_target_humidity:
        friendly_name: "Target humidity"
        value_template: "{{ states.fan.philips_ac3829.attributes.target_humidity }}"
      purifier_water_level:
        friendly_name: "Water level"
        value_template: "{{ states.fan.philips_ac3829.attributes.water_level }}"
      purifier_brightness:
        friendly_name: "brightness"
        value_template: "{{ states.fan.philips_ac3829.attributes.light_brightness }}"
And then the lovelace card (using custom circle sensor card)
elements:
  - icon: 'mdi:fan'
    style:
      '--iron-icon-height': 45px
      '--iron-icon-width': 45px
      color: dodgerblue
      left: 10%
      top: 7%
      opacity: 0.7
    tap_action: none
    type: icon
  - entity: sensor.purifier_speed
    style:
      border-color: 'rgb(34, 154, 210)'
      color: 'rgb(255, 255, 255)'
      font-family: Trebuchet MS
      font-size: 90%
      font-weight: bold
      opacity: 1
      pointer-events: none
      left: 6%
      text-shadow: 1px 1px black
      top: 7%
      transform: 'translate(0%,-50%)'
    type: state-label
  - icon: 'mdi:water-percent'
    style:
      color: dodgerblue
      left: 10%
      top: 20%
    tap_action: none
    type: icon
  - attribute: humidity
    color_stops: null
    entity: fan.philips_ac3829
    fill: 'rgba(0,0,0,0.3)'
    font_style:
      color: white
    gradient: true
    max: 100
    min: 0
    show_card: null
    stroke_width: 10
    style:
      height: 60px
      left: 10%
      top: 20%
      width: 60px
    type: 'custom:circle-sensor-card'
    units: '%'
  - icon: 'mdi:thermometer'
    style:
      color: dodgerblue
      left: 10%
      top: 35%
    tap_action: none
    type: icon
  - attribute: temperature
    color_stops: null
    font_style:
      color: white
    gradient: true
    max: 100
    min: 0
    show_card: null
    stroke_width: 10
    style:
      height: 60px
      left: 10%
      top: 35%
      width: 60px
    units: °C
  - icon: 'mdi:bug'
    style:
      color: dodgerblue
      left: 10%
      top: 50%
    tap_action: none
    type: icon
  - attribute: allergen_index
    color_stops: null
    font_style:
      color: white
    gradient: true
    max: 10
    min: 0
    show_card: null
    stroke_width: 10
    style:
      height: 60px
      left: 10%
      top: 50%
      width: 60px
  - entity: sensor.purifier_mode
    prefix: 'Mode: '
    style:
      border-right-style: solid
      font-size: 90%
      font-weight: bold
      opacity: 0.8
      right: 1%
      top: 80%
    type: state-label
  - entity: sensor.purifier_target_humidity
    prefix: 'Target humidity: '
    style:
      font-size: 90%
      font-weight: bold
      opacity: 0.8
      right: 1%
      top: 85%
    type: state-label
  - entity: sensor.purifier_water_level
    prefix: 'Water level: '
    style:
      font-size: 90%
      font-weight: bold
      opacity: 0.8
      right: 1%
      top: 90%
    type: state-label
  - entity: sensor.purifier_brightness
    prefix: 'Brightness: '
    style:
      font-size: 90%
      font-weight: bold
      opacity: 0.8
      right: 1%
      top: 95%
    type: state-label
  - entity: sensor.purifier_air_quality
    style:
      font-size: 90%
      font-weight: bold
      left: 46.5%
      opacity: 1
      top: 17%
    type: state-label
  - entity: sensor.purifier_pre_filter
    prefix: 'Pre-filter: '
    style:
      border-left-style: solid
      font-size: 90%
      font-weight: bold
      left: 1%
      opacity: 0.8
      top: 80%
    type: state-label
  - entity: sensor.purifier_wick_filter
    prefix: 'Wick filter: '
    style:
      font-size: 90%
      font-weight: bold
      left: 1%
      opacity: 0.8
      top: 85%
    type: state-label
  - entity: sensor.purifier_carbon_filter
    prefix: 'Carbon filter: '
    style:
      font-size: 90%
      font-weight: bold
      left: 1%
      opacity: 0.8
      top: 90%
    type: state-label
  - entity: sensor.purifier_hepa_filter
    prefix: 'HEPA filter: '
    style:
      font-size: 90%
      font-weight: bold
      left: 1%
      opacity: 0.8
      top: 95%
    type: state-label
image: /local/pictures/ac3829-3.png
type: picture-elements
In today update i added ability to Turn On, Turn Off and Change Speed of Purifier!
