MArtin_br
(M.J. Brockhus)
June 25, 2019, 1:03pm
1
Tried almost all posibilities but cannot get both actions working. Each is working individually but when both are without errors only the last one works and the payload is not published to my sonoff. I have tried all kinds of indents, formats and examples but need now humbly ask for advice/suggestions. Any reaction is welkom.
Kind regards Martin J
- type: image
# hold_action:
# action: more-info
tap_action:
action: call-service
service: mqtt.publish
service_data:
topic: "cmnd/sonoff/backlog"
payload: "RfSync 12030; RfLow 450; RfHigh 1230; RfCode #400001"
service: light.toggle
service_data:
entity_id: light.keukenkast_leds
entity: light.keukenkast_leds
state_image:
"on": /local/resources/keukenkast leds aan.svg
"off": /local/resources/keukenkast leds uit.svg
style:
top: 58%
left: 35%
width: 3.5%
Maybe use a script with the 2 actions in and call that instead ?
MArtin_br
(M.J. Brockhus)
June 25, 2019, 7:46pm
3
I have tried via automation and trigger mqtt but more or less same problem to fire 2 actions one after antother, only the last one worked.
Something like this ?
Probably change the name (tap_action_sequence
) in both to something more relevant
Delay might not be needed
Script:
tap_action_sequence:
sequence:
- service: mqtt.publish
service_data:
- delay:
seconds: 1
- service: light.toggle
service_data:
Image tap action
- type: image
hold_action:
action: more-info
tap_action:
service: script.turn_on
service_data:
entity_id: script.tap_action_sequence
MArtin_br
(M.J. Brockhus)
June 25, 2019, 10:22pm
5
Will try tomorrow and let you know asap.
Thanks for sharing your ideas.
petro
(Petro)
June 25, 2019, 11:06pm
6
@MArtin_br @Holdestmade
That won’t work. You’ll have to make a script and call the script. You can only call 1 service from lovelace, you cannot call multiple services.
@petro That’s what I’ve shown ?
petro
(Petro)
June 26, 2019, 12:16pm
8
Sorry, was late when I posted. Thought it was inside the lovelace yaml.
MArtin_br
(M.J. Brockhus)
June 26, 2019, 1:31pm
9
Like the idea for the script, unfortulately floowing error is thrown:
Invalid config for [script]: [service_data] is an invalid option for [script]. Check: script->script->keukenkast_leds_script->sequence->0->service_data. (See /config/configuration.yaml, line 36). Please check the docs at https://home-assistant.io/components/script/
I now have script with or without “-” 's
keukenkast_leds_script:
sequence:
service_data:
delay:
seconds: 1
service_data:
and in ui-lovelace.yaml
- type: image
tap_action:
service_data:
entity_id: keukenkast_leds_script
state_image:
style:
top: 58%
left: 35%
width: 3.5%
MArtin_br
(M.J. Brockhus)
June 26, 2019, 1:33pm
10
When testing it complains: cannot call script/turn-on. Service not found.
Try this
sequence:
- delay:
seconds: 1
- type: image
hold_action:
action: more-info
tap_action:
service_data:
petro
(Petro)
June 26, 2019, 3:27pm
12
Missing a few things.
Your sequence isn’t a list of services. That’s what the -'s do. Makes it a list. Sequence is fired top down on the list.
You’re missing the domian in your entity id for the call-service in your lovelace yaml.
you don’t really need to use script.turn_on. You can just call the script directly.
sequence:
service_data:
- delay:
seconds: 1
service_data:
- type: image
tap_action:
service: script.keukenkast_leds_script
state_image:
style:
top: 58%
left: 35%
width: 3.5%
MArtin_br
(M.J. Brockhus)
June 26, 2019, 4:29pm
13
Working like a charm, thanks to the both of you.
From the 6502/z80 era with limited resources i still tend to write code as compact as possible altough no longer in direct opcodes or mneumonics.
Now I can finallyl focuss on the aparent dead time before the sonoff executes a next command. This is the more a minor because the RF led lights used do not send back their effectif state.
Kind regards and thanks again
Martin
MArtin_br
(M.J. Brockhus)
June 26, 2019, 5:01pm
14
pETRO:
This however doesn’t seem to work:
service: script.keukenkast_leds_script`
petro
(Petro)
June 26, 2019, 5:47pm
15
It should, I’m using it everywhere in my lovelace.yaml. Either way, if you got it working then no point in changing it.
MArtin_br
(M.J. Brockhus)
July 1, 2019, 3:51pm
16
With your help things are finally moving. From the 6502/Z80 era with forced mneumonics and very limited resources this is a very steep curve and feel like some fuzzy logic.
Blunt enough to throw in another riddle:
Am i thinking to simple now?
in cover.yaml
- platform: mqtt
state_topic: "vitrage_rechts/status"
command_topic: "cmnd/Sonoff-Bridge_1/backlog"
# Dooya remote 2 up stop down
payload_open: "rfraw AA B0 35 05 04 1338 0618 0168 0302 22E2 A481A3A3A3B2B2B2A3B2A3A3B2B2A3B2A3B2A3B2A3A3A3A3B2B2A3B2B2B2A3A3B2A3A3A3A3B2B2B2B2 55;rfraw 177"
payload_close: "rfraw AA B0 35 05 04 131A 0622 0154 0302 222E B481A3A3A3B2B2B2A3B2A3A3B2B2A3B2A3B2A3B2A3A3A3A3B2B2A3B2B2B2A3A3B2A3A3B2A3B2A3B2A3 55;rfraw 177"
payload_stop: "rfraw AA B0 35 05 04 1338 0618 0168 02F8 22D8 A481A3A3A3B2B2B2A3B2A3A3B2B2A3B2A3B2A3B2A3A3A3A3B2B2A3B2B2B2A3A3B2A3A3A3B2B2B2B2A3 55;rfraw 177"
set_position_template: "50"
qos: 1
optimistic: true
retain: false
and in scripts:
vitrage_rechts_scripts:
sequence:
- service: cover.toggle
entity_id: cover.vitrage_rechts
no errors are thrwon but the Sonogg console is not showing the payload beiing sent.
Any ideas for this dilemma?
petro
(Petro)
July 2, 2019, 12:46pm
17
cover doesn’t have a toggle service. You should look at the cover services and choose the appropriate service
MArtin_br
(M.J. Brockhus)
July 16, 2019, 11:44pm
18
The covers I use don’t send feedback. I try to construct a 1-button control to cycle up-stop-down-stop-. That needs a variable to give the values 0 75 100-25-0 but variable.py is not working. Before trying the im,possible I would like to know if variable/ init .py should still work.
MArtin_br
(M.J. Brockhus)
July 19, 2019, 6:33pm
19
Still going strong. I am trying to program for non-feedback covers.
The general idea is that after starting to open or to close a 15 second window is available for a stop command after that delay the postion variable _pos is set.
I have no errors that i am aware off but only the first option is excuted no matter what the current value of the position variable is 0, 75, 100 or 25.
Who can shed a light on this?
scherm_links_script:
sequence:
- service: script.turn_on
data_template:
entity_id: >
{% if ("variable.scherm_links_pos", "0") %}
script.scherm_links_0
{% elif ("variable.scherm_links_pos", "75") %}
script.scherm_links_75
{% elif ("variable.scherm_links_pos", "100") %}
script.scherm_links_100
{% elif ("variable.scherm_links_pos", "25") %}
script.scherm_links_25
{% else %}
script.noop_script
{% endif %}
Sample of the 4 working scripts:
scherm_links_75:
sequence:
topic: "cmnd/Sonoff_Bridge_1/backlog"
payload: "RfSync 10160; RfLow 300; RfHigh 960; RfCode #ED92A4"
- service: variable.set_variable
variable: scherm_links_pos
value: 100
entity_id: cover.scherm_links
petro
(Petro)
July 19, 2019, 6:42pm
20
need the function calls
{% if is_state("variable.scherm_links_pos", "0") %}
