[PoC] Multiple actions on tap action
I sometimes want to do multiple actions from one frontend button. I searched for it, multiple threads (1, 2, 3, 4, 5, 6, 7, 8 and even a PR by thomasloven), but the only option was to build an script for each set of actions. I don’t like that clutter :sweat_smile:
So, here’s my Proof of Concept approach.
1. ONE generic script for all
Right now it’s very basic, it only supports up to 3 actions, and limited to services with one entity.
alias: Convert to actions
sequence:
  - service: "{{ service1 }}"
      entity_id: "{{ entity_id1 }}"
  - if:
      - condition: template
        value_template: "{{ service2 is defined }}"
    then:
      - service: "{{ service2 }}"
          entity_id: "{{ entity_id2 }}"
  - if:
        value_template: "{{ service3 is defined }}"
    then:
      - service: "{{ service3 }}"
          entity_id: "{{ entity_id3 }}"
mode: single
I think it can easily be expanded to support other service data other than entity_id
What I’m not so sure about is how to support other actions. Since it does go through a script, I guess it is limited to certain things. But
I’m also not sure if it should be parallel instead of sequential, or what happens with the next if the previous fails. For now it’s enough for me.
2. The tap_action in the front-end
We are passing each service and entity_id as service data to the script
tap_action:
  action: call-service
  service: script.convert_to_action
  service_data:
    service1: fan.turn_off
    entity_id1: fan.ventilador_habitacion
    service2: scene.turn_on
    entity_id2: scene.ventilador_habitacion_off
Happy to know your thoughts and improvements!
Reference links:
Way to call multiple actions from button?
Possible to trigger multiple actions with a single tap on the button card?
How to add two (or more) actions to a single Button-card?
How to perform multiple actions
Having two tap_actions within one button
One button with two actions
Picture-elements card: Multipe actions/services on tap_action
Allow multiple tap/hold/doubletap actions. by thomasloven · Pull Request #8125 · home-assistant/frontend · GitHub
How about passing a list of actions with possibility of different params then you are not limited to number of actions and can call different service types. Example below only shows 2 service param types but more could be added.
alias: Multi Tap Action
sequence:
  - repeat:
      for_each: "{{actions}}"
      sequence:
        - if:
              value_template: "{{repeat.item.entity_id is defined}}"
          then:
            - service: "{{repeat.item.service}}"
                entity_id: "{{repeat.item.entity_id}}"
        - if:
              value_template: "{{repeat.item.message is defined}}"
          then:
                message: "{{repeat.item.message}}"
mode: parallel
The use like this.
show_name: true
show_icon: true
type: button
tap_action:
  service: script.multi_tap_action
  service_data:
    actions:
      - service: light.turn_on
        entity_id: light.lounge_lamps
      - service: notify.persistent_notification
        message: Lounge lamps on
entity: sun.sun
Wow, thank you for building on this. It works great, and as you said can be expanded based on one’s needs.
I like it. What about if you need to include service data?
e.g.
show_name: true
show_icon: true
type: button
tap_action:
  service_data:
    actions:
          brightness: 255
          hs_color: [0,100]
        message: Lounge lamps on bright red
entity: sun.sun
Yes, I was thinking about that and actually, I think it can be much simpler (as I think all services accept the entity id in data??)
Script
sequence:
  - repeat:
      sequence:
          data: "{{repeat.item.data}}"
mode: parallel
Button
show_name: true
show_icon: true
type: button
tap_action:
    actions:
          brightness_pct: 53
  target: {}
entity: sun.sun
Yes… but no.
Yes they should accept an entity id in the data block for backwards compatibility, but no that is not always the case. In fact there have been examples where a service does not work at all with the entity_id in the data block. I’ll see if I can find an example, but they were all from quite a while ago. They may have been fixed.
Ideally we should be using
  entity_id: domain.object_id
That always works.
Ah ok, then we should go for the higher certainty. I think then there are 4 scenarios for a service call.
  1. Without entity or data
  2. With only entity
  3. With only data
  4. With entity and data
As such, maybe this is the script…
sequence:
  - repeat:
      sequence:
        - if:
            value_template: "{{repeat.item.entity_id is not defined and repeat.item.data is not defined }}"
          then:
            service: "{{ repeat.item.service }}"
        - if:
            value_template: "{{repeat.item.entity_id is defined and repeat.item.data is not defined }}"
          then:
        - if:
            value_template: "{{repeat.item.entity_id is not defined and repeat.item.data is defined }}"
          then:
            data: "{{ repeat.item.data }}"
        - if:
            value_template: "{{repeat.item.entity_id is defined and repeat.item.data is defined }}"
          then:
mode: parallel
4 examples to show (what I think!?) is all combinations.
show_name: true
show_icon: true
type: button
tap_action:
    actions:
      - service: frontend.reload_themes
      - service: switch.turn_off
        entity_id: switch.bedroom_lamps
          brightness_pct: 53
  target: {}
entity: sun.sun
I have a scenario where I need to pause between calling the first service and the second. I added the following after the 4 conditions:
        - if:
              value_template: "{{repeat.item.wait is defined}}"
          then:
            - delay:
                hours: 0
                minutes: 0
                seconds: 0
                milliseconds: "{{repeat.item.wait | float}}"
Hello, excellent script!!! It works perfect for running multiservices. Any ideas to navigate?
service1: switch.turn_on
service2: navigate
url_path:“/lovelace/…”
thanks
That is exactly what I would need too!
I navigate to a sub dashboard with a tap_action, showing camera snapshots with the ability to browse through them. I would love so much being able to reset the chosen snapshot to the newest one in the same tap_action that navigates to the sub dashboard.
Currently I always need to take a separate action like double click to reset…
@gastonche and @Tarkoon, apologies I did not reply before - not notified of further posts to this.
Not sure if you have solved this but for future info.
As navigate is a function of the button actions (and you can only have 1 action on a button - exactly why this script got created), this needs a little bit of a workaround.
You will need to install browser mod as this creates a service that you can call to navigate to a page in your browser.
Modify the multi_tap_action script to be this:
sequence:
  - repeat:
      sequence:
        - if:
              value_template: >-
                not defined }}
          then:
        - if:
              value_template: >-
                defined }}
          then:
              entity_id: "{{ repeat.item.entity_id }}"
        - if:
              value_template: >-
                defined }}
          then:
            data: >-
              {% set b =  {"browser_id": browser_id} if
              browser_id is defined and "browser_mod" in repeat.item.service else {} %} {{ dict(
              repeat.item.data, **b) }}
        - if:
              value_template: >-
                defined }}
          then:
            data: >-
mode: parallel
and then on your button use like this (I have used the previous example showing all scenarios and now adding the navigate with browser_mod scenario. Note the button tap_action must be fire-dom-event and you must include the browser_id: THIS under data.
One caveat of this is that is basically uses browser mod to navigate to the page on the device you have clicked the button on. However, all browser windows that have HA on them on that device will navigate to your lovelace view, not just the one you are currently viewing.
type: button
tap_action:
  action: fire-dom-event
  browser_mod:
      actions:
            brightness_pct: 53
        - service: browser_mod.navigate
            path: /lovelace/lounge
      browser_id: THIS
entity: sun.sun
show_name: true
show_icon: true
Hope that helps.
I’m a new to scripts.
When I attempt to call the script multi tap action, I get the following error:
Logger: homeassistant.components.script.multi_tap_action
Source: helpers/script.py:1934
integration: Script (documentation, issues)
First occurred: 6:11:56 PM (2 occurrences)
Last logged: 6:11:59 PM
Multi Tap Action: Repeat ‘for_each’ must be a list of items in Multi Tap Action, got:
I'm calling it via:
                - element: shark.clean_den
                  entity:
                    - input_text.cleaning_living_area
                  tap_action:
                      actions:
                        - service: sharkiq.clean_room
                          entity_id: vacuum.kitchen
                            rooms: Den
                        - service: input_text.set_value
                          entity_id: input_text.cleaning_living_area
                            value: den
I figured out my issue, you have to change “data” to “service_data”
I guess, scripting has changed in the last coupe of months:
The following works for me:
                  entity:
                  tap_action:
                    service_data:
                      actions:
                            rooms: Den
                            value: den
                    target: {}
Hello
I’ve tried to use this automation, but I ran into some problems:
here is the automation copied from above:
sequence:
  - repeat:
      sequence:
        - if:
              value_template: >-
                not defined }}
          then:
        - if:
              value_template: >-
                defined }}
          then:
        - if:
              value_template: >-
                defined }}
          then:
            data: >-
              {% set b =  {"browser_id": browser_id} if browser_id is defined
        - if:
              value_template: >-
                defined }}
          then:
            data: >-
mode: parallel
show_name: true
show_icon: true
type: button
tap_action:
  target: {}
  service_data:
    actions:
      - service: input_number.set
        entity_id: input_number.teste_number_1
          variable:
            value: 30
        entity_id: input_number.teste_number_2
          variable:
            value: 30
entity: script.multi_tap_action
show_state: true
I’ve tried several ways:
          value: 30
          variables:
             value: 30
        data: 30
  target: {}
and got lots of errors:
Failed to call service script/multi_tap_action. extra keys not allowed @ data[‘value’]
Failed to call service script/multi_tap_action. extra keys not allowed @ data[‘variable’]
Service input_number.set called service script.multi_tap_action which was not found.
Failed to call service script/multi_tap_action. Error rendering data template: Result is not a Dictionary
Hope someone that can help is still watching and thanks in advance
I’ve wanted to display remote popup and turn on TV as a result of one tap_action on the dashboard button. Above script solution was kind of working - only issue was that using ‘THIS’ browser_id results in showing popup in all open Home Assistant cards on the same machine:
tap_action:
  browser_mod:
    service: script.living_room_tv_timer
      content: !include popup_tv.yaml
      browser_id: THIS
sequence:
  - action: browser_mod.popup
      title: Philips TV
      content: "{{ content }}"
      browser_id: "{{ browser_id }}"
  - action: script.living_room_philips_uhd_android_tv_on
By accident in browser_mod documentation I’ve found browser_mod.sequence => github.com/thomasloven/hass-browser_mod/documentation/services.md which resolves that issue!
tap_action:
  browser_mod:
    service: browser_mod.sequence
      sequence:
        - service: script.living_room_philips_uhd_android_tv_on
        - service: browser_mod.popup
            title: Philips TV
I hope this solution will benefit your use cases as well (:
Thank you for mentioning it. I don’t remember now if I wasn’t aware of it at the time or it somehow didn’t fit my need :thinking: But if it works, it’s definitely better!
Noting here that the difference makes the calls stay in the Browser a.k.a Browser Call. Whenever you hand off to a script that will become a server call, where if you pass THIS, you will get the action on any open tabs of the Browser that sent the server call.
I’ve suggested this feature, please head over to GitHub and discuss/upvote there:
That is exactly what I needed and I didn’t manage to find anything on internet, but I got dual action with a single tap (NO browser-mod needed) by using button-card’s action: custom callback.
If it is still relevant, I added a button that when clicked triggers an script and redirect the user to another dashboard, the code I’m using is:
- type: custom:button-card
  icon: mdi:play
  tap_action:
    action: custom
    custom: |
        hass.callService(
          'script',
          'turn_on',
          { entity_id: 'script.do_something' }
        window.history.pushState(null, "", "/dashboard/secondary");
        window.dispatchEvent(new CustomEvent("location-changed"));
In this case the script could be script.multi_tap_action
Hope this helps. :blush:
Note that action: custom will be sent to HA but it will ignore it. The fact that button-card parses the javascript is a hack and not supported. The better way to do this is outlined in this discussion. It uses action: fire-dom-event and since it runs the actions on the event, the whole sequence can still use standard HA confirmation.
