Plant monitoring with Mi Flora sensors and ESPHome Bluetooth Proxy
Recently I began monitoring the plants in the house using Mi Flora sensors. My wife is very fond of plants and she wanted to have a better insight on the moisture state of the potsoil.
A friend of mine suggested to use the Mi Flora sensors and link them to an ESPHome Bluetooth Proxy. Those are extremely small and affordable. They are ESP32 based, use Bluetooth Low Energy (BLE) and can be placed anywhere in the house. You can flash them right from the page above after which they get instantly recognized by Home Assistant. I use the M5 Stack.
The Mi Flora sensors have their own app from Xiaomi, which works nice and is quite well designed. You can use the app to install the Mi Flora sensors and monitor them from the app. However, after you’ve done proper integration in Home Assistant, you don’t need the app anymore. For various reasons it’s preferable to have it all in Home Assistant, instead of the app.
Setup and plant specifics
It takes some work to get everything you have in the app into Home Assistant. the Mi Flora sensor reports moisture, illuminance, temperature and soil conductivity. But important other specifics that you set in the app don’t come through, like the name of the sensor for example. Neither plant specific parameters like minimum moisture value for a specific plant, which you set in the app, don’t get written into the sensor and don’t come through to Home Assistant. So you need the app until you know which sensor you are reading in Home Assistant and also to determine the specifics that you want to have in Home Assistant.
Plant database
Setting up the proper plants in the app (there are thousands to choose from), plant specific parameters like minimum and maximum values for moisture or conductivity are taken from the Xiaomi Plant database. They are stored in the app. You can use those to create separate sensors or entities in Home Assistant to use for reporting or other purposes.
The planttype parameters are also made available though in this great community, as the database got exported out of the app. You can find it in CSV here: MiFlora Sensor Plant Database . Essentially you don’t need the app at all if you use this file.
Home Habit Wall Panel
I am using HomeHabit on a Lenovo tablet, attached to the wall. Read about my other project for that setup here: Home Habit touch panel.
Complete setup in Home Asisstant
My setup contains the following:
  • ESPHome BLT Proxy with 6 Mi Flora Sensors connected
  • Reading out plant status, nicely laid out in Lovelace with photos (from the web) and on my wall tablet using Home Habit
  • Reading moisture, conductivity. Temp and illuminance are optional for me.
  • I am also having the min and max range for each plant by manually creating an Threshold sensors and using the values from the Mi Flora app. A Threshold sensor will report ON if the value (e.g. moisture) is within range, OFF if it’s outside.
  • A Group sensor based on the Threshold sensors that combines the states into one, reporting ‘All good’ or ‘Needs attenting’.
  • A Template sensor renaming the output of the Threshold sensor, reporting for each plant whether it’s below (‘Dry’), within (‘Good’), or above (‘Wet’) the specified range.
  • An automation reporting when a plant runs dry for more than two days.
Read more about it here (you can skip the part about integrating it in HA, that’s taken care of using the Bluetooth Proxy).
Just a quick question, is there a way to do what you’ve done, but have it outdoors? I think I checked this a year or two ago and from what I could see, most of these sensors are indoor use only.
I have several window boxes outside that I’d love to be able to keep track of.
The Bluetooth Proxy can be near your window on the inside. Not sure about the waterresistance of the sensor, but I’ve seen some people reporting using them outside. Best to check the IPx value and see if it can survive the elements all year round. Alternatively you could put it in a waterresistant outdoor electricity box.
Yes, I’ve used miFlora devices (I have ~15 of them) outdoors for several years. They are in pots under a roof, but still exposed to limited rainfall.
When I water my plants, the sensors are often completely immersed for a period of several minutes. As long as the seal around the battery compartment is properly fitted, that is not a problem.
I now have ESP32 devices outside, but it also worked fine with one placed indoors near a window with direct line of sight to the pots. At least for distances up to 6-7 meters.
Just got some of these miFlora - they work great. Quick question my conductivity is low, whilst moisture seems ok. Does this mean I need to water the plant to increase the conductivity or feed it or something?
Cheers
Stuart
Low conductivity means it needs fertilising.
Hi to all,
We are cheeking the Mi Flora integration, but we have problems with the conductivity because the conductivity increase when I put the plant on water (by immersion) to normal values (in the middle of the tolerance for my plant), but when I take the plant out of the water it immediately goes back down and in less than 10 hours I am back below the tolerance, probably in to 2 or 3 hours the conductivity will be down the tolerance.
Any suggestion for this problem?
can you share ESPHOME Bluetooth proxy config? regards
I tried to use ESPHOME proxy on M5 Atom Lite, but HA on VM don’t discover Xiaomi Flower Care; which setup do you used?
I wanted to try this but using those blue anonymous “Connected Home Plant Monitor” from Aliexpress. They can be added in Tuya using bluetooth and have names like SGS01. But they are not being detected by my Bluetooth Proxy. If I understand correctly, they should just show up in HA. Am I missing a special process? Do they need to stay in pairing mode for a long time when you use Mi Flora?
The Tuya sensors are mainly Zigbee. I see that some are branded as Bluetooth as well, but I believe they only use Zigbee when connecting to a HUB.
It is a different product from Mi Flora (which are bluetooth only), and I do not believe that they use compatible bluetooth protocols.
Those are the newer SGS01Z. The older SGS01 are Bluetooth only. I saw someone made a custom firmware. Interesting: link.
Now I just need to figure out how to use this in Linux.
BTHome is natively supported in HA, so they should work automatically once they have been flashed (provided the firmware works stably). I already have several BTHome temperature/humidity sensors.
Unfortunately these “bluetooth only” sensors seem to be hard to find, I can only see Zigbee sensors on Ali now. And the flashing process is quite finicky.
