i love having this – although i’m convinced knowing the pollen level everyday makes my allergies psychosomatically worse.
small feature request if you don’t mind: the pollen sensor reports data for the primary allergen, while the website reports the top 3. is it possible to get the top 3 built-in and not just the primary? for what i want, i’m currently using the rest sensor below. thanks!!
Took a look at Air Matters. It’s possible to reverse engineer the API from the mobile app, but one main issue prevent me from proceeding: it looks like each request is signed with some sort of authorization header (to validate request authenticity, I assume).
I’m reaching out to their business development folks to see if they’d be willing to help. Stay tuned.
I don’t seem to be getting any response from this. When testing using APItester.com i get this as a response.
{“status_code”:“403 Forbidden”,“date”:“2018-06-25T15:39:39+00:00”,“message”:“Could not parse location”}
I’m using my LAT and LON from Wunderground i.e. 51.30, -0.141
this is just a field so u can;t spy on me
I GOT IT. Instead of reverse engineering the Air Matters iOS app, I went after the web app – I think I’ve got what I need. Will start working on a library for the integration ASAP.
2018-07-05 08:58:56 ERROR (SyncWorker_3) [homeassistant.components.sensor.pollen] An error occurred while retrieving data
2018-07-05 08:58:57 ERROR (SyncWorker_1) [homeassistant.components.sensor.pollen] Pollen.com API didn't return any data```
