Bit offtopic, but can you please share the include_verbruik_actueel_apex.yaml
and input_select.apex_span
files? That graph is really looking great especially with the span
Not at the office now, but I posted it some time ago in the Apex card thread. Search for it and you’ll easily find it?
This would be it ApexCharts card - A highly customizable graph card - #1495 by Mariusthvdb
Can you please chare you template to calculate the different sensors used. Thanks!
Thanks for the work on this @ulic it looks stunning!
Is there a way I can stretch the height of the card to make it fill 100% of the available viewport space?
The card was built using the design of the built-in Energy Cards as a base and last time I checked they didn’t work that way either. Right now I don’t have any plans on adding that feature.
Thanks @ulic I was able to stretch (and magnify) it using 🔹 Card-mod - Add css styles to any lovelace card
You’ll see from my screen shot above that I have a white line running between Grid and Battery, but this will never happen.
In the screen shot from @ulic in the first post that line isn’t present.
How do I remove this line from my card?
How do you do that? which values of styles?
I would like to reduce size of my power flow:
Hello, I am trying to start the power flow card, I would like to know how to make the card appear in Watts, thanks
You can use the watt_threshold setting to configure when watts or kilowatts will be shown.
Sorry for the delay in replying @Plouf34
First, I installed the Card-Mod: 🔹 Card-mod - Add css styles to any lovelace card
Then I edited the dashboard I wanted to change:
Then I selected the Edit
in the bottom left corner:
Then I edited the code from this:
type: custom:power-flow-card
kw_decimals: null
w_decimals: 0
watt_threshold: 999
min_flow_rate: 3
max_flow_rate: 10
entities:
battery_charge: sensor.lux_battery
battery:
consumption: sensor.lux_battery_discharge_live
production: sensor.lux_battery_charge_live
grid:
consumption: sensor.lux_power_from_grid_live
production: sensor.lux_power_to_grid_live
solar: sensor.lux_solar_output_live
To this (note the extra card_mod
section at the bottom):
kw_decimals: null
w_decimals: 0
watt_threshold: 999
min_flow_rate: 3
max_flow_rate: 10
entities:
battery:
grid:
card_mod:
style: |
ha-card {
padding-top: 205px;
width: 1060px;
height: 700px;
transform: scale(1.8);
You can play with the CSS values and tailor it for your own requirements @Plouf34
Very useful card, love it!
I’ve been trying to use conditions within it, to achieve the following:
- Include Solar and Grid, while there’s Solar production, but
- Only include Grid when Solar production is offline.
I have a entity for the state of the inverter, and in that the value is 2 if it’s offline and 1 if it’s online.
I can create a condition based on that, but can not get that to work with which entities are selected for this card (solar and/or grid). Maybe I’m too novice with YAML.
Is this even possible with this card, and if so, can someone please help me understand how conditional entity rows would work in this case? Thank you!
Hi there.
Apologies for what is probably an excrutiatingly short sighted question. I’m new to this.
I cant get the dashboard to work. What I have done is
- Installed HACS on my homeaaistant OS, running on a Pi4
- Installed the card via HACS
- Copied the first “example usage” from the Github page
- Gone into an existing dashboard, edited it and added a card
- Scrolled down to the bottom of the pop-up and chose “manual”
- Pasted the example usage code into the card configuration:
entities:
battery: sensor.battery_in_out
battery_charge: sensor.battery_percent
grid: sensor.grid_in_out
solar: sensor.solar_out
All looks good, but the card doesnt seem to have anything flowing through it. All the values stay at zero. I’ve rebooted the pi
Any advice gratefully received.
thanks
danyul
You must use your own sensor entities, not the sample ones.
Thank you. So I can only choose entries from the list that appears in the sensors list in the overview in home assistant?
@Plouf34 was that of any use?
Yes exactly, you cannot use non-existent entities that have no values.
Thank you so much. All sorted now
tryng to add the water and gas consumption (live, not total) entities, I figured to do
entities:
grid:
consumption: sensor.grid_power_consumption
production: sensor.grid_power_production
solar: sensor.zp_actuele_opbrengst
water: sensor.watermeter_stand
gas: sensor.gas_verbruik
where the watermeter_stand is the actual ticker per liter (and not a unit m3 which would not be expected as that is total, and not actual consumption), and the gas_verbruik (which does have the cubic meter unit) entity, updated each 15 minutes.
however…:
the graph shows the actual state and not a current water flow… suppose the gas might be the same, but as I dont have any other useful entities, that’l have to do.
So, how to get that water circle show the current flowing water, and not the total.
should I change any of the entities, or the config? Or would this have to be done inside the card based on the total entity (like I have now)
If the sensor doesn’t exist to provide the current usage then it just won’t work as intended.
