I overwrite the units in the secondary config section.
Is this this outcome you are after?
I found that only works if the input sensor values are measuring kWh.
e.g. if the input sensor value is 300 Wh then choosing kWh in the config will show it as 300 kWh and not 0.3 kWh.
It works differently to the power number display.
e.g 999 W is shown as 999 W but 1050 W is displayed at 1.05 kW (at whatever decimal precision level is chosen). The unit conversions seem automated with the power numbers but not with the secondary display values.
See my power card above, look at the Solar circle. The two inputs are W for primary and Wh for secondary. The W are auto converted to kW when they go past 999 W but the Wh value remains as Wh, there is no conversion to kWh.
Had various things cranking today during a tariff free period.
I notice a couple of things:
i. Iâm getting a negative value for household consumption. Not sure whatâs going on there. Need to look into it a bit more.
ii. The EV shows power in kW (in the same way grid, solar and battery do) once it exceed 999 W but the water heater and home are still showing power in W. All sensor units used are W.
Also sometimes one of the individual circles just disappears, in this case the water heater:
When I set the individual circle âDisplay Zero Stateâ to on and save, it does not stick. Indeed several of the options do not save.
+1 ⌠water would be very nice to have on the card !!
Thanks for the good work !
Have you considered to make both your cards part of the official HA release eventually? It feels like everyone should see the amazing work you do.
How did you get this working, just adding an extra âindividual3:â in the code editor or as an manual yalm or what?
I am running the âv0.2.0-betaâ version, i created it from scratch several times but i feel like i am doing something wrong because the 3th or 4th entity is not showing up at all (also breaks the visual editor but that was expected i guess).
The visual editor in beta works for me but a number of features of it are not. Same with the yaml, can add code lines without it adding the feature to the card (e.g. secondary data).
The yaml for adding individual entries is a different format in the beta. Here is my current yaml:
type: custom:power-flow-card-plus
entities:
battery:
entity: sensor.battery_power
state_of_charge: sensor.battery_state_of_charge
invert_state: true
color_value: true
color_circle: true
display_state: one_way_no_zero
grid:
entity: sensor.power_real_fronius_meter_2_http_192_168_0_201
color_icon: true
color_circle: true
color_value: true
solar:
entity: sensor.pv_power_total_combined
display_zero_state: true
color_value: true
color_icon: true
secondary_info:
entity: sensor.daily_pv_output_total
unit_of_measurement: Wh
decimals: 0
color_value: true
color:
- 255
- 162
- 0
fossil_fuel_percentage:
state_type: power
entity: sensor.co2_signal_grid_fossil_fuel_percentage
color_value: true
color_icon: true
color:
- 0
- 179
- 3
icon: mdi:leaf
use_metadata: false
unit_white_space: false
display_zero: true
home:
subtract_individual: true
secondary_info:
icon: mdi:home-group
override_state: true
use_metadata: false
individual:
- entity: sensor.input_01_water_heater
icon: mdi:water-boiler
color:
- 255
- 115
- 0
- entity: sensor.input_10_garage_ev
icon: mdi:car-outline
secondary info:
entity: sensor.ev_soc
unit_of_measurement: null
- entity: sensor.input_02_ducted_aircon
icon: mdi:air-conditioner
- entity: sensor.cottage
icon: mdi:home-outline
clickable_entities: true
display_zero_lines:
mode: show
transparency: 50
grey_color:
- 189
- 189
- 189
use_new_flow_rate_model: true
w_decimals: 0
kw_decimals: 1
min_flow_rate: 0.75
max_expected_power: 10000
min_expected_power: 1
watt_threshold: 1000
transparency_zero_lines: 0
max_flow_rate: 6
Firstly i really like the card but i have a ct on my house with a forward and reverse binary sensor. is there anyway to split this into 2 sensors as the energy is always a positive value regardless of the direction
This is an example of what I mean, except in this case the aircon circle disappears, then the cottage moves up to take the airconâs spot and also changes colour:
Youâll probably need to create a new template sensor which returns a positive value in one direction and a negative value for the reverse direction.
Something like the following in your yaml.config file but use the right sensors as input.
A big disclaimer - I am lousy at yaml, so there is every probability I have the syntax wrong. Hopefully others can correct it, this is more about indicating the sort of thing you can do.
template:
- sensor:
- name: "NewPowerSensor"
unit_of_measurement: "W"
state: >
{% if states('sensor.mainsdirection')|= "FORWARD"}
{{ states('sensor.mainspower') }}
{% else %}
{{ states('sensor.mainspower') * -1 }}
{% endif %}
Of if you want two separate sensors, one for import, one for export then you can do something like in this post:
template:
Thats i tried there but it spat this back at me
im sure its a simple thing but i know nothing about yaml so im really going copy paste and fudge.
do you use a float for something that only has forward reverse? my gut tells me float should be for an undefined number
thanks for the help
Logger: homeassistant.config
Source: config.py:623
First occurred: 14:53:58 (4 occurrences)
Last logged: 15:00:37
yaml is very picky about syntax, spacing etc and your pasted code has dots points where dashes should be. Try pasting it inside the code wrappers so people can see what it looks like:
even so, I am not the guy really to be advising on yaml, hopefully someone else here can help you get it right.
This vard has been amazing. I configured it this morning but unfortunately i still see some Solar Generation that is not coming on the Tesla App or the iSolar cloud app. Any reasons why and how i can make this right ?
Very new to this and already love PFC+ . Thanks for the great efforts.
Do you intend to implement, or can you already set up two or more arrays that either feed into a master array and onward or directly. I would love to see my east west array live, but i canât seem to work this out.
I use data from local via the modbus and seem to have 248 entities as a result on my Solax system. More presumably when my EV charger is finally connected.
I want to later do tariff comparisons. If anyone knows of any existing work done on this let me know.
Nice update. Wasnât dificult to migrate my config. I do need to work out why my card-mod theme isnât styling the title though.
I thought this would do it:
card-mod-theme: day
card-mod-card: |
h1.card-header {
font-size: 20px;
font-weight: 300;
letter-spacing: 0px;
Hi All,
I just discovered this card and i think itâs great ! thank you for the hard work.
However i ned some help configuring it as iâve spent 2 hours on it and canât make it work properly.
The card looks like this:
the problems i have are:
At irrigation there should be another sensor as secondary info but it does not show at all.
House: i have a secondary sensor which looks correct but the unit does not show at all. It should show 26.4 kWh
Solar: Secondary sensor shoud show kWh as unit, the value is correct.
The full code is:
entities:
grid:
entity: sensor.smart_meter_63a_real_power
invert_state: false
use_metadata: false
color_value: true
solar:
entity: sensor.solarnet_power_photovoltaics
icon: mdi:solar-panel-large
color_value: true
color_icon: false
use_metadata: false
invert_state: false
secondary_info:
template: >-
{{ (states('sensor.solarnet_energy_day') | float / 1000) | round(1)
decimals: 0
color_value: false
unit_of_measurement: kWh
icon: mdi:pine-tree
entity: sensor.electricity_maps_grid_fossil_fuel_percentage
color_icon: true
display_zero: true
secondary_info:
entity: sensor.electricity_maps_co2_intensity
display_zero: true
accept_negative: false
unit_of_measurement: CO2
home:
secondary_info:
template: >-
{{ (states('sensor.solarnet_energy_day') | float / 1000 +
states('sensor.froniusimport') | float / 1000 -
states('sensor.froniusexport') | float / 1000) | round(1) }}
decimals: 1
unit_white_space: true
color_value: true
icon: ''
display_zero: false
individual:
- entity: sensor.1405_power
icon: mdi:heat-pump-outline
inverted_animation: true
- entity: sensor.1404_power
icon: mdi:pump
- entity: sensor.waterdaily
icon: mdi:water-pump
color: '#71bec4'
color_icon: true
display_zero: true
unit_of_measurement: mÂł
w_decimals: 0
- entity: sensor.629_power
icon: mdi:pump
display_zero: true
color_icon: true
secondary_info:
entity: sensor.456_power
display_zero: true
display_zero_lines:
mode: show
transparency: 50
grey_color:
- 189
- 189
- 189
w_decimals: 0
kw_decimals: 2
min_flow_rate: 2
max_flow_rate: 6
max_expected_power: 15000
min_expected_power: 0.01
disable_dots: false
As iâm not very skilled with YAML please help me tidy up the code so the issues are solved.
Thank you !!!
I figured out some of the issues, resulting in
Still need help on the fossil fuel and water
After the last update of the card (yesterday) my Shelly EM used to control the EV charge canât be recognized.
I can set up an individual for other shelly or other entities, but not for the Shelly. It worked until yesterday.
I tried to set directly or in the yaml editor, no difference.
So i managed to solve almost all the issues:
But the display error at Water still eludes me. Same sensor set as secondary info displays the value correctly.
color: '#71bec4'
color_icon: false
display_zero: true
decimals: 1
secondary_info:
color: '#71bec4'
display_zero: true
decimals: 1
@flixlixlix any idea why this is happening please ?
Cheers
Hello everyone!
First of all thank you so much for this amazing Card! Very good work!
Just to let you know, since the last major update I realized two issues:
EDIT: As soon as you color the icon of the first individual entity the line gets colored too ?!
EDIT 2: Zero lines of individual entities are not greyed out correctly.
