Hello! Set up the container but i cant get it connected on mqtt. i’m using a raspberry pi 3 b+ with last version of pi os. In sudo docker exec -it voltronic-mqtt bash -c ‘/opt/inverter-cl i/bin/inverter_poller -d -1’ i obtain this response:
pi@raspberrypi:/opt/ha-inverter-mqtt-agent $ docker exec -it voltronic-mqtt bash -c '/opt/inverter-cli/bin/inverter_poller -d -1'
Tue Jun 14 08:46:24 2022 INVERTER: Debug set
Tue Jun 14 08:46:24 2022 INVERTER: Current CRC: 49 C1
Tue Jun 14 08:46:24 2022 INVERTER: QMOD reply size (5 bytes)
Tue Jun 14 08:46:24 2022 INVERTER: QMOD: 5 bytes read: (B
Tue Jun 14 08:46:24 2022 INVERTER: QMOD query finished
Tue Jun 14 08:46:24 2022 INVERTER: Current CRC: B7 A9
Tue Jun 14 08:46:24 2022 INVERTER: QPIGS reply size (110 bytes)
Tue Jun 14 08:46:24 2022 INVERTER: QPIGS: 110 bytes read: (000.0 00.0 230.2 50.0 0000 0000 000 373 26.94 006 100 0031 0006 059.4 27.00 00000 00110110 00 00 00166 110
Tue Jun 14 08:46:24 2022 INVERTER: QPIGS query finished
Tue Jun 14 08:46:24 2022 INVERTER: Current CRC: F8 54
Tue Jun 14 08:46:25 2022 INVERTER: QPIRI reply size (98 bytes)
Tue Jun 14 08:46:25 2022 INVERTER: QPIRI: 98 bytes read: (230.0 13.0 230.0 50.0 13.0 3000 3000 24.0 23.0 21.5 28.2 27.0 0 30 060 0 1 2 1 01 0 0 27.0 0 1
Tue Jun 14 08:46:25 2022 INVERTER: QPIRI query finished
Tue Jun 14 08:46:25 2022 INVERTER: Current CRC: B4 DA
Tue Jun 14 08:46:25 2022 INVERTER: QPIWS reply size (36 bytes)
Tue Jun 14 08:46:25 2022 INVERTER: QPIWS: 36 bytes read: (00000100000000000000000000000000
Tue Jun 14 08:46:25 2022 INVERTER: QPIWS query finished
INVERTER: ampfactor from config is 1.00
INVERTER: wattfactor from config is 1.01
"Inverter_mode":4,
"AC_grid_voltage":0.0,
"AC_grid_frequency":0.0,
"AC_out_voltage":230.2,
"AC_out_frequency":50.0,
"PV_in_voltage":59.4,
"PV_in_current":6.0,
"PV_in_watts":163.6,
"PV_in_watthour":5.4540,
"SCC_voltage":27.0000,
"Load_pct":0,
"Load_watt":0,
"Load_watthour":0.0000,
"Load_va":0,
"Bus_voltage":373,
"Heatsink_temperature":31,
"Battery_capacity":100,
"Battery_voltage":26.94,
"Battery_charge_current":6,
"Battery_discharge_current":0,
"Load_status_on":1,
"SCC_charge_on":1,
"AC_charge_on":0,
"Battery_recharge_voltage":23.0,
"Battery_under_voltage":21.5,
"Battery_bulk_voltage":28.2,
"Battery_float_voltage":27.0,
"Max_grid_charge_current":30,
"Max_charge_current":60,
"Out_source_priority":1,
"Charger_source_priority":2,
"Battery_redischarge_voltage":2532947876441777295090823175602176.0,
"Warnings":"00000100000000000000000000000000"
So i assume that the software is communicating correctly with the inverter. But i cant get connected to the mosquitto broker, i cant see any new connection.
if i log the container i see this response
pi@raspberrypi:/opt/ha-inverter-mqtt-agent $ docker container logs voltronic-mqtt
Unable to connect (Lookup error.).
Since i have 2 containers running, one with this software and one with home assistant and mosquitto, i think it could be a networking issue, but since i’m not very expert i don’t know how to solve it. I also tried to connect voltronic-mqtt to a cloud hivemq broker but it cant connect. here is the response of the container ps:
pi@raspberrypi:/opt/ha-inverter-mqtt-agent $ docker container ps
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
d892725cd300 bushrangers/ha-voltronic-mqtt "/bin/bash /opt/inve…" 12 hours ago Up 12 hours (unhealthy) voltronic-mqtt
475461e8dac3 containrrr/watchtower "/watchtower --inter…" 12 hours ago Up 12 hours 8080/tcp watchtower
cc1a2c311d4b eclipse-mosquitto "/docker-entrypoint.…" 17 hours ago Up 15 minutes 0.0.0.0:1883->1883/tcp, :::1883->1883/tcp mosquitto
d6b07c4a1350 ghcr.io/home-assistant/home-assistant:stable "/init" 34 hours ago Up 15 minutes home-assistant
and here is the response of the docker compose ls
pi@raspberrypi:/opt/ha-inverter-mqtt-agent $ docker compose ls
NAME STATUS CONFIG FILES
esempio-compose running(2) docker-compose.yaml
ha-inverter-mqtt-agent running(2) docker-compose.yml
hope somene can help me! if you need more information let me know!
thanks
