I´m using your dockerized solution - thanks for all your effort! Unfortunately I´m unable to read data out of my MPI 15 KW Inverters. After a lot googling, I found out, the device seems to be called “PI18”. Do I need to reconfigure these values set in “mqtt.json”:
Your problem doesn’t come from that. These are some fancy description which it will be send to HA through mqtt protocol. At that point was a requirement that this details to be sent to HA, to not have error on mqtt. But doesn’t care about you put here.
What say the test commands?
look on documentation and find the command to search for protocol code. Probably your invertor use another protocol/updated protocol?
thanks for the fast reply :-). In Fact it seems, that i dont get any data back from the inverter
Fri May 19 13:04:33 2023 INVERTER: Current CRC: B4 DA
Fri May 19 13:04:33 2023 INVERTER: QPIWS reply size (0 bytes)
Read, that sometimes the inverter USB Interface seems to stop responding. Because of that, i reset the inverter via power cycling. Unfortunately I got no luck still
Would you recommend me using serial over usb for being more stable?
Hi, sorry to hear that.
I keen to hear from you if it is more suitable to you an esp32 + serial adapter converter (with esphome). look on esphome for mpp integration.
it is more cheap that a rasp pi and probably more support from guys who know to program with this new inverters.
in my case already got working so why fix it!
My server is directly connected to inverter USB-microUSB.
I managed to get events into HA but with no values. I assume, that I put a wrong device name into inverter.conf as my server has 6 USB ports and I randomly pluged-in my cable. Is there a way to find out to what USB port my inverter is connected? Current config: device=/dev/hidraw0
Maybe I’m doing something wrong.
Will appreciate any help or suggestions.
I’ve managed to get data into HA. Just for future for anyone who get problems with Axpert VM IV 5,6 kWt. So after installation with docker it was not working, most probably, that was due to my server has a lot of USB ports and 2 of them were used by mouse and keyboard. I plugged-in my cable from inverter to server into working server and most probably it was assigned as not /dev/hidraw0. I restarted server and checked with sudo dmesg | grep hidraw what devices were assigned to what hidraw’s. In that case it was /dev/hidraw0 and i tried to run voltronic-mqqt in debug mode. This time i got incorrect start/stop bytes. Have found buffer config
qpiri=99
qpiws=36
qmod=5
qpigs=110
restarted container and got values in HA but get no values for
The story does not end ((( After working one day on some point inverter stops responding and even after inverter restart data cannot be retrieved. Has someone get this problem fixed?
I’m running all on one server. Any setting will do the trick? And I wonna thank you for your work on the improving ned-kelly’s repo. I switched to use your repo)
As I posted earlier, i have connected my server via usb to the inverter so I ran voltronic-mqtt container also in the server. I even managed to get values in ha (except PV input watts, but this is not critical, as it can be easily calculated). Unfortunatelly, at some point inverter stops responding. I tried to change time in settings, but no result. Changed as you’ve said and have no luck. ( It’s so annoying when it was working and with no reason just stops…
It might be that your inverter is using a different protocoll. I also tried catalinbordan’s version, and
i was receiving exactly the same message “(NAKss” … after i started sniffing the communication between the SolarPower app and the inveter, i found out the protocol is different. Currently working to implement it. I have an EASUN Igrid SV4, which seems to be same as the Voltronic Infinisolar V
You could also try that to see what the messages look like.
or you could try
docker exec -it voltronic-mqtt bash -c /opt/inverter-cli/bin/inverter_poller -d -r ^P005PI
So my problem is not a new one ) There is a different baud rate of serial port between default linux config and inverter. As I understood, inverter supports ‘2400 raw’ baud rate (whatever it means). So there is a solution that worked for me
If I open a minicomm session with 9600 baud rate, inverter communications works fine, but that baud rate does not stay after reboot and I’ve been unable to get it to stay using setserial etc.
