Hi everybody,
I found this blueprint here in the community and was exited to finally get rid off my automations that I wrote when just starting Home Assistant.
This usually works great: I open a window, the climate entity turns off
, I close the window, it turns to auto
(I modified the original blueprint so that it would set the climate entity to auto instead of heat, as heat
seems to set my climate entities to full power).
However, I also have automations like the ones below; they will set particular climate entities to set degrees at set times. In other words, I don’t have them on <n>°C
24/7, but use helpers to change temperature values, for example, turn the kitchen radiator to 12°C
at 23:00:00
, to 25°C
at 06:00:00
, and to 17.5
at 07:30:00
. So don’t waste heat at night, assure to have the room nicely heated when entering in the morning, then having it at another value throughout the day. That’s just an example.
The Issue
Let’s say that I had opened the kitchen window at 22:45:00
. In this case, the automation via blueprint would have turned the climate entity off
, which is the expected behavior. However, now that 23:00:00
has come, the temperature gets set to 12°C
. And when it does, it seems like the hvac_mode
also, unintentionally changes from off
to auto
. So even if the window is still open when changing the current_heating_setpoint
, it will not retain it’s current status (off
), but go to auto
without checking whether the window is open or not.
Of course, I could use a condition
that checks whether or not each window corresponding to each radiator is open, and -if so-, do not change the temperature. However, if this was the case, and I’d eventually shut the window, it’d still be at whatever value it was before, regardless of the time (and the appropriate set temperature it was supposed to be).
I also thought of something like time_pattern
to check every x minutes whether a window is open, and -if so- then set hvac_mode: "off"
. But that didn’t seem like the best way to handle this, either.
Below are the automation based on the blueprint as well as the time-based heating setpoint one. What am I doing wrong, what do you suggest I change?
Thank you in advance for your ideas
alias: Heizung KU von Blueprint
description: ''
use_blueprint:
path: govido/window_controlled_heater.yaml
input:
heating_target: climate.kueche_heizung
window_entity: binary_sensor.kueche_fenster_contact
window_closed_wait: 1
window_opened_wait: 1
input_datetime:
ku_abends:
has_date: false
has_time: true
ku_morgens:
has_date: false
has_time: true
ku_nachts:
has_date: false
has_time: true
ku_vormittags:
has_date: false
has_time: true
input_number:
ku_abends:
min: 5
max: 30
step: 0.5
mode: box
ku_morgens:
min: 5
max: 30
step: 0.5
mode: box
ku_nachts:
min: 5
max: 30
step: 0.5
mode: box
ku_vormittags:
name: KU Vormittag
min: 5
max: 30
step: 0.5
mode: box
automation:
- alias: "Heizung KU Abends"
- platform: time
at: input_datetime.ku_abends
variables:
temperatur: input_number.ku_abends
heizung: climate.kueche_heizung
- service: climate.set_temperature
data_template:
entity_id: "{{ heizung }}"
temperature: "{{ states(temperatur) }}"
- alias: "Heizung KU Morgens"
- platform: time
at: input_datetime.ku_morgens
variables:
temperatur: input_number.ku_morgens
data_template:
- alias: "Heizung KU Nachts"
- platform: time
at: input_datetime.ku_nachts
variables:
temperatur: input_number.ku_nachts
data_template:
- alias: "Heizung KU Vormittags"
- platform: time
at: input_datetime.ku_vormittags
variables:
temperatur: input_number.ku_vormittags
data_template:
