Reported in https://github.com/home-assistant/home-assistant/issues/10920 and being fixed in https://github.com/home-assistant/home-assistant/pull/10923 for 0.59.1
You may want to hold off upgrading to 0.59 if you use the iOS app.
wish i seen this. just upgrade and same issue. is it possible to downgrade?
Matter of fact, there is:
I got the same issue with 0.59.1
What issues are you seeing? I haven’t used it alot on 59 but it appeared to be working fine.
The issue was related to any data sent from the iOS device to HA. The webview would work fine.
0.59.1 was released with a fix so feel free to upgrade now.
