Reliable MariaDB-addon backup ideas
Hello All HA lovers and haters,
We have got already quite a number of somehow related topics, but I could not find a proper solution to a reliable backup of MariaDB running on hassio as an add-on.
I’ve found at least two tickets (130146 and 188334) pointing out, that the snapshot/backup service on HA does not backup required mariaDB files in a proper way, which often ends up in a corrupted restore.
I am interested in the historical values and I do not want to lose the data by reinstalling the add-on after unsuccessful restore, as in many cases recommended and proposed as a final solution!
My idea is to dump the complete database via mysqldump to the /config/db-backup folder and let it be processed by a subsequent HA nightly snapshot.
And here comes my lack of knowhow and kind request for your assistance:
I could successfully call mysqldump
  1. from the addon_core_mariadb docker (e.g. via Portainer):
    mysqldump --user=homeassistant --password=mypasswd --lock-tables --all-databases > /var/tmp/db.sql
  2. from hassio OS calling the docker:
    docker exec -it addon_core_mariadb mysqldump --user=homeassistant --password=mypassword --lock-tables --all-databases" > /var/tmp/db.sql
As a next step I wanted to create a shell_command which would run the command mysqldump in an automation preceding the snapshot.
Unfortunately neither mysqldump nor docker is available in the homeassistant docker shell.
MariaDB add-on does not provide ssh, so I cannot login there to run the 1) option.
Not available docker prohibits me from running the 2) option.
Do you know how to call mysqldump on a MariaDB-addon from the shell in an automation?
or
Do you have any better idea how to backup the MariaDB in an automation?
Moving the DB to NAS is not a solution for me.
Any kind of your suggestion is very much appreciated
Best, Peter
Hi Peter,
did you find a solution. I hear here, that it now a days, if is backuped in the right way out of the box. BUT I don’t find any additional information.
BR,
Tristan
Hi Tristan,
I gave up setup on MariaDB and divided it into two parts. One is back on SQLite for sensors with values I need on a short term basis and “long terms sensors values”, which I save in InfluxDB.
The backup is now on google cloud GitHub - sabeechen/hassio-google-drive-backup: Automatically create and sync Home Assistant backups into Google Drive
I created own Google API credentials. Now I’m happy with good database performance and stable backup.
Hope it helps in your setup.
Cheers
Peter
Just found this old thread. I have no idea how addons should officially be backed up, it seems like every addon has to create its own backup routines.
So I started my own stuff …
ssh ha docker exec addon_core_mariadb mysqldump --default-character-set=utf8mb4 --lock-tables --complete-insert --skip-opt --add-drop-table --add-locks --create-options --disable-keys --lock-tables --quick --set-charset --force -u homeassistant -pxxxxxxx homeassistant | grep -a -v 'Dump completed on ' > ha_mariadb.dump
  • the dump always goes into the same file on the server the backup runs on.
  • use restic which compresses and deduplicates and makes it easy to diff backups, so I can easily see what changed in the data base. My server is fast enough to do this hourly.
  • I am removing the time stamp from the dump so the diffs are smaller.
if anyone need something like that :
