I have a Hass.io installation running 0.96.5 that I had to restore from a full snapshot the other day. Once the restoration came back online recorder, logbook, & history components don’t work.
MariaDB Add-on is up-to-date with version 1.2 and was working properly prior to having to restore a snapshot.
The snapshot was restored due to LetsEncrypt having problems renewing my certificate and my Hass.io frontend became unavailable. No other changes were made to my configuration.
Any leads on how I can get my database back up and running or setup again? Thanks!
Full Relevant Error Log
2019-07-31 12:55:14 INFO (MainThread) [homeassistant.setup] Setup of domain logger took 0.0 seconds.
2019-07-31 12:55:15 INFO (MainThread) [homeassistant.setup] Setting up http
2019-07-31 12:55:15 WARNING (MainThread) [homeassistant.components.http.auth] legacy_api_password support has been enabled.
2019-07-31 12:55:15 INFO (MainThread) [homeassistant.setup] Setup of domain http took 0.0 seconds.
2019-07-31 12:55:15 INFO (MainThread) [homeassistant.setup] Setting up system_log
2019-07-31 12:55:15 INFO (MainThread) [homeassistant.setup] Setup of domain system_log took 0.0 seconds.
2019-07-31 12:55:15 INFO (MainThread) [homeassistant.setup] Setting up recorder
2019-07-31 12:55:16 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: (MySQLdb._exceptions.OperationalError) (2002, "Can't connect to MySQL server on 'core-mariadb' (115)")
(Background on this error at: http://sqlalche.me/e/e3q8) (retrying in 3 seconds)
2019-07-31 12:55:19 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: (MySQLdb._exceptions.OperationalError) (2002, "Can't connect to MySQL server on 'core-mariadb' (115)")
2019-07-31 12:55:22 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: (MySQLdb._exceptions.OperationalError) (2002, "Can't connect to MySQL server on 'core-mariadb' (115)")
2019-07-31 12:55:25 WARNING (MainThread) [homeassistant.setup] Setup of recorder is taking over 10 seconds.
2019-07-31 12:55:25 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: (MySQLdb._exceptions.OperationalError) (2002, "Can't connect to MySQL server on 'core-mariadb' (115)")
2019-07-31 12:55:28 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: (MySQLdb._exceptions.OperationalError) (2002, "Can't connect to MySQL server on 'core-mariadb' (115)")
2019-07-31 12:55:31 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: (MySQLdb._exceptions.OperationalError) (2002, "Can't connect to MySQL server on 'core-mariadb' (115)")
2019-07-31 12:55:34 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: (MySQLdb._exceptions.OperationalError) (2002, "Can't connect to MySQL server on 'core-mariadb' (115)")
2019-07-31 12:55:37 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: (MySQLdb._exceptions.OperationalError) (2002, "Can't connect to MySQL server on 'core-mariadb' (115)")
2019-07-31 12:55:40 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: (MySQLdb._exceptions.OperationalError) (2002, "Can't connect to MySQL server on 'core-mariadb' (115)")
2019-07-31 12:55:43 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: (MySQLdb._exceptions.OperationalError) (2002, "Can't connect to MySQL server on 'core-mariadb' (115)")
2019-07-31 12:55:43 INFO (MainThread) [homeassistant.setup] Setup of domain recorder took 28.7 seconds.
So, I just was fiddling with some stuff unrelated to any recorder or MariaDB things and when I restarted HA, I, too, received this error. I wasn’t restoring from a snapshot, just making a minor change to a camera config and restarting.
Unfortunately, uninstalling, rebooting, and reinstalling the MariaDB add-on didn’t fix the issue for me.
Not sure what else to do here. What is the root cause of that error? I hadn’t changed anything related to the recorder or MariaDB but it just decided to not connect.
I changed also to the ip-adress but its not working.
2019-08-16 21:24:26 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: (MySQLdb._exceptions.OperationalError) (2002, "Can't connect to MySQL server on 'core-mariadb' (115)")
2019-08-16 21:24:29 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: (MySQLdb._exceptions.OperationalError) (2002, "Can't connect to MySQL server on 'core-mariadb' (115)")
2019-08-16 21:24:32 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: (MySQLdb._exceptions.OperationalError) (2002, "Can't connect to MySQL server on 'core-mariadb' (115)")
2019-08-16 21:24:35 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: (MySQLdb._exceptions.OperationalError) (2002, "Can't connect to MySQL server on 'core-mariadb' (115)")
I have also problems to access other apps local with manuell port and without ingress. (glances, portainer…)
Looks like this is a known issue that is in the pipes for a fix:
Until then, it appears the accepted workaround is to stop the Mariadb service before taking a snapshot, then restarting it afterward. This is good to know… I just started using Mariadb and haven’t tried a restore yet. Retaking another snapshot after writing this… with maria off.
I just moved my HA instance to a laptop and restored a snapshot and had the same issue. I just did another snapshot this time stopping the Mariadb service before the snapshot. I just restored the image to my laptop, started the Mariadb service and then re started HA and all the errors were gone and the logbook is working again.
Perfect, thanks for posting your verification Richdem. Now I don’t have to actually test it to know it works lol. (famous last words… I really should be testing anyways)
I always have an old pc that I have a test environment setup, that way I can play with things and get it right before messing with my actual HA. When it all works everyone in the house is happy, when there are issues I am the only tolerant one lol
I did encounter the same issue. In my case it seems that the backup has been corrupted which made the MariaDB server not start correctly. There is also an issue for this case: https://github.com/home-assistant/hassio-addons/issues/667
Same issue here. What helped me was to use Portrainer > Execute mariadb container shell (addon_core_mariadb) and remove following:
rm /data/databases/ib_logfile*
Restart the MariaDB. It will report some issues regarding log file but in the end checks should be passed and MariaDB will startup again, so you don’t need to start over again with new DB.
Update: I realized even you remove log files and you’re able to startup DB, it may get corrupt during next snapshot creation. So steps above is temporary solution how to get some SQL data from DB if you need them. For me was crucial to export the nginxproxymanager DB and here are steps what I did:
Once you will get started MariaDB when you remove log files mentioned above, save your addon config with username/password to the DB and open portrainer and hook into the container:
