Awesome
What’s the YAML needed to deploy it?
doesnt require any YAML can be all configured thru the ui install thru HACS then reload and add thru the normal integration
I can’t find it in Hacs. Is there a custom repo for it?
Hi there
I’ve been desperate to try this out on our Merlin garage door so I gave it a go, but there’s a couple of questions I have.
It shows up as a “sensor” instead of a “switch”. I don’t know if that’s important, but I can’t seem to make any Automations involving the Remootio “sensor”. I also have a light “switch” and can make Automations with that - I don’t know much about HA so I just mention it in case that’s important
Secondly. Our garage door is one of those “toggle” ones, so I use the Remootio external magnet sensors to enable the system to “know” what’s “open” and what’s “closed”. The problem is that if you hit “open” and then hit “close” while it’s still opening, HA (ie this custom_component) returns that it’s “closed” whereas it’s actually stopped half-open. The Remootio app on my Android seems to know the proper state: if you hit “open”, I guess it polls the WebSocket until it sees it return “closed” before declaring that within HA? I guess the current code instead is assuming that if you hit “open/closed” then it must become “closed/open”? Shouldn’t there be extra polling until the Remootio device declares the state has changed properly?
Anyway, fingers crossed this gets into HA properly soon. Looking good
Thanks!
Hi! I just updated to Home Assistant 2022.5. This unfortunately breaks the Remootio-integration, which no longer seems to load. Do we need an update in the integration?
2022-05-06 11:25:45 ERROR (SyncWorker_7) [homeassistant.util.package] Unable to install package aioremootio==1.0.0a14: ERROR: Cannot install aioremootio==1.0.0a14 because these package versions have conflicting dependencies.
ERROR: ResolutionImpossible: for help visit https://pip.pypa.io/en/latest/topics/dependency-resolution/#dealing-with-dependency-conflicts
WARNING: You are using pip version 22.0.3; however, version 22.0.4 is available.
You should consider upgrading via the '/usr/local/bin/python3 -m pip install --upgrade pip' command.
2022-05-06 11:25:45 ERROR (MainThread) [homeassistant.setup] Setup failed for custom integration remootio: Requirements for remootio not found: ['aioremootio==1.0.0a14'].
If anyone is eager to get this working. It seems that the aioremootio
has a dependency on an older version of voluptuous
which seems to cause the problems.
I tested by forking that to my own version and just changing the version dependency. Now it seems to work.
If you really need it to work, until the maintainers get this fixed, you can do so by editing the file
custom_components/remootio/manifest.json
Change the requirement to instead be
"requirements": ["aioremootio @ git+https://github.com/peaceduck/aioremootio.git"],
and restart HA. Then it works (at least for me). I guess you have to trust me to not change the code to something evil, so it is on your risk Hopefully the official versions will be updated very soon!
nice one! did the job
THANK YOU!!!
This works perfectly for me
Christopher,
I’m trying to duplicate the logic in your flow. Would you be able to share the Node RED JSON export (presumably minus any sensitive info)?
Cheers,
-James
Hi, I am trying to integrate my Remootio into HA and have it installed via HACS but when I configure the I-address, API and Auth Keys I get an “Unexpected error” message.
I am running:
Home Assistant Core 2022.6.5
Home Assistant Supervisor 2022.05.3
Home Assistant OS 8.1
Error log details are as follows:
Logger: custom_components.remootio.config_flow
Source: custom_components/remootio/utils.py:66
Integration: Remootio
First occurred: 2:43:46 PM (1 occurrences)
Last logged: 2:43:46 PM
Unexpected exception/error
File “/config/custom_components/remootio/config_flow.py”, line 117, in async_step_user
validation_result = await validate_input(self.hass, user_input)
File “/config/custom_components/remootio/config_flow.py”, line 86, in validate_input
device_serial_number: str = await get_serial_number(
File “/config/custom_components/remootio/utils.py”, line 66, in get_serial_number
result = await remootio_client.serial_number
TypeError: object str can’t be used in ‘await’ expression
Is anyone else getting this issue? First time I try it so not sure if its an issue with 22.6.5?
Any help appreciated
Thanks!
I’ve just installed it via HACS, made the modifications for the requirements as per the post on May 6 and got further than before, but the same errors as what you’re seeing.
I am not sure… It looks like both the HACS-remootio and the aioremootio-package has been updated. My quick-fix for the aioremootio should probably not be used anymore.
I guess you have tried without my “fix” and it still does not work? Otherwise, you should really do that first.
I have not updated the integration in my HA installation, since my remootio kind of works. Though, to me it looks like that the
is strange.
I hope that the maintainer updates this, if it is not working. At a glance, it should not have that await-statement there.
I will see if I can find time to look at this next week. Since I did not write the code, it will take some time to understand it.
Yes, that await-statement is wrong. I am a bit unused to the “correct” way of versioning and git and the development-containers for doing home assistant stuff. But I have read through some documentation, and tried to do this by the book…
I have tried to send the change by making a “pull request” to sam43434 so he can make an update to the package. Hopefully I did that correct…
If you are feeling bold, you could while waiting for the new version change the file
Change line number 66
from
to
result = remootio_client.serial_number
I.e. just remove the await. Make sure that you do not change the indentation of the file, since python depends on it.
If you have made my previous fix for the versioning problem, please change that back to the original. If you can not remember what it was, just search for the remootio integration in HACS and choose to download it again.
And do that before changing the utils.py-file. Otherwise that change will be lost.
Awesome, thanks!
I saw the PR was accepted just after I saw this post updated, so it’s all working now. Happy days!
Good that it works! Yes, it seems like my PR was merged a few hours ago, so now it hopefully works without any special fixes!
Hello mates!
I tried to install the remootio under HA ( Home Assistant Core 2022.6.0) with hacs (ver 1.26.2).
All seems looking fine, but when I tried to enter IP, API secret key key and API auth key, the integration says me:
"Your Remootio device isn’t supported. Please update the software on your device at least to v2.21 and install the sensor for detecting if your gate is open or closed."
The remootio’s firmare version is 2.30, and on the same subnet with my home assistant docker.
Anybody had the same problem with solution?
I wanna use the remootio with my HA to control Hörmann Rotamatic.
Cheers:
CeruzaUR
After attached the status sensor, the integration works.
Apologies for my ignorance, but how did you install remootio in HA. I have tried to find it in HACS and can’t and it clearly is not in the core integrations yet.
You need to add this custom repository to HACS → https://github.com/sam43434/remootio
After restarting HA you can then use the Integrations feature in HA to install Remootio. You will need to supply the API keys provided to you from the Remootio App.
Ass @chillywasher wrote below:
