following as getting same error via HACS too
what version of Core HA is this being aimed for
I noticed there was an update this morning so tried it.
Getting two different errors now
Config flow could not be loaded: 500 Internal Server Error Server got itself in trouble
And
homeassistant.requirements.RequirementsNotFound: Requirements for remootio not found: [âaioremootio==1.0.0a13â].
And
Logger: homeassistant.util.package
Source: util/package.py:99
First occurred: 6:45:46 AM (3 occurrences)
Last logged: 6:47:10 AM
Unable to install package aioremootio==1.0.0a13: ERROR: Cannot install aioremootio==1.0.0a13 because these package versions have conflicting dependencies. ERROR: ResolutionImpossible: for help visit Dependency Resolution - pip documentation v22.1.dev0
thanks for this. the install instructions arenât too clear on the git page. What do i need to add to my config.yaml file once iâve added the folder to my custom_components directory, or what do i need to do to get this working inside my home assistant setup. Any help would be appreciated.
Looks like there is some movement on the official integration request.
@jamesbj348 hope the requests are easy enough to address. Thereâs a number of us super keen! Thank you!
custom repo was removed as i have no idea wtf im doing it worked on older versions but not on newer, we will all just have to wait for the creater and core team to implement it however long that takes
the code owner has updated it and it now works again can be used in HACS until it hopefully soon hits the main branch
Again this is only for those who cant wait
Awesome
Whatâs the YAML needed to deploy it?
doesnt require any YAML can be all configured thru the ui install thru HACS then reload and add thru the normal integration
I canât find it in Hacs. Is there a custom repo for it?
Hi there
Iâve been desperate to try this out on our Merlin garage door so I gave it a go, but thereâs a couple of questions I have.
It shows up as a âsensorâ instead of a âswitchâ. I donât know if thatâs important, but I canât seem to make any Automations involving the Remootio âsensorâ. I also have a light âswitchâ and can make Automations with that - I donât know much about HA so I just mention it in case thatâs important
Secondly. Our garage door is one of those âtoggleâ ones, so I use the Remootio external magnet sensors to enable the system to âknowâ whatâs âopenâ and whatâs âclosedâ. The problem is that if you hit âopenâ and then hit âcloseâ while itâs still opening, HA (ie this custom_component) returns that itâs âclosedâ whereas itâs actually stopped half-open. The Remootio app on my Android seems to know the proper state: if you hit âopenâ, I guess it polls the WebSocket until it sees it return âclosedâ before declaring that within HA? I guess the current code instead is assuming that if you hit âopen/closedâ then it must become âclosed/openâ? Shouldnât there be extra polling until the Remootio device declares the state has changed properly?
Anyway, fingers crossed this gets into HA properly soon. Looking good
Thanks!
Hi! I just updated to Home Assistant 2022.5. This unfortunately breaks the Remootio-integration, which no longer seems to load. Do we need an update in the integration?
2022-05-06 11:25:45 ERROR (SyncWorker_7) [homeassistant.util.package] Unable to install package aioremootio==1.0.0a14: ERROR: Cannot install aioremootio==1.0.0a14 because these package versions have conflicting dependencies.
ERROR: ResolutionImpossible: for help visit https://pip.pypa.io/en/latest/topics/dependency-resolution/#dealing-with-dependency-conflicts
WARNING: You are using pip version 22.0.3; however, version 22.0.4 is available.
You should consider upgrading via the '/usr/local/bin/python3 -m pip install --upgrade pip' command.
2022-05-06 11:25:45 ERROR (MainThread) [homeassistant.setup] Setup failed for custom integration remootio: Requirements for remootio not found: ['aioremootio==1.0.0a14'].
If anyone is eager to get this working. It seems that the aioremootio
has a dependency on an older version of voluptuous
which seems to cause the problems.
I tested by forking that to my own version and just changing the version dependency. Now it seems to work.
If you really need it to work, until the maintainers get this fixed, you can do so by editing the file
custom_components/remootio/manifest.json
Change the requirement to instead be
"requirements": ["aioremootio @ git+https://github.com/peaceduck/aioremootio.git"],
and restart HA. Then it works (at least for me). I guess you have to trust me to not change the code to something evil, so it is on your risk Hopefully the official versions will be updated very soon!
nice one! did the job
THANK YOU!!!
This works perfectly for me
Christopher,
Iâm trying to duplicate the logic in your flow. Would you be able to share the Node RED JSON export (presumably minus any sensitive info)?
Cheers,
-James
Hi, I am trying to integrate my Remootio into HA and have it installed via HACS but when I configure the I-address, API and Auth Keys I get an âUnexpected errorâ message.
I am running:
Home Assistant Core 2022.6.5
Home Assistant Supervisor 2022.05.3
Home Assistant OS 8.1
Error log details are as follows:
Logger: custom_components.remootio.config_flow
Source: custom_components/remootio/utils.py:66
Integration: Remootio
First occurred: 2:43:46 PM (1 occurrences)
Last logged: 2:43:46 PM
Unexpected exception/error
File â/config/custom_components/remootio/config_flow.pyâ, line 117, in async_step_user
validation_result = await validate_input(self.hass, user_input)
File â/config/custom_components/remootio/config_flow.pyâ, line 86, in validate_input
device_serial_number: str = await get_serial_number(
File â/config/custom_components/remootio/utils.pyâ, line 66, in get_serial_number
result = await remootio_client.serial_number
TypeError: object str canât be used in âawaitâ expression
Is anyone else getting this issue? First time I try it so not sure if its an issue with 22.6.5?
Any help appreciated
Thanks!
Iâve just installed it via HACS, made the modifications for the requirements as per the post on May 6 and got further than before, but the same errors as what youâre seeing.
I am not sure⌠It looks like both the HACS-remootio and the aioremootio-package has been updated. My quick-fix for the aioremootio should probably not be used anymore.
I guess you have tried without my âfixâ and it still does not work? Otherwise, you should really do that first.
I have not updated the integration in my HA installation, since my remootio kind of works. Though, to me it looks like that the
is strange.
I hope that the maintainer updates this, if it is not working. At a glance, it should not have that await-statement there.
I will see if I can find time to look at this next week. Since I did not write the code, it will take some time to understand it.
Yes, that await-statement is wrong. I am a bit unused to the âcorrectâ way of versioning and git and the development-containers for doing home assistant stuff. But I have read through some documentation, and tried to do this by the bookâŚ
I have tried to send the change by making a âpull requestâ to sam43434 so he can make an update to the package. Hopefully I did that correctâŚ
If you are feeling bold, you could while waiting for the new version change the file
Change line number 66
from
to
result = remootio_client.serial_number
I.e. just remove the await. Make sure that you do not change the indentation of the file, since python depends on it.
If you have made my previous fix for the versioning problem, please change that back to the original. If you can not remember what it was, just search for the remootio integration in HACS and choose to download it again.
And do that before changing the utils.py-file. Otherwise that change will be lost.
Awesome, thanks!
I saw the PR was accepted just after I saw this post updated, so itâs all working now. Happy days!
