Remotely forget an SSID
I have a remote off-grid instance of HomeAssitant, that occaisionally loses power, typically because the offgrid solar batteries died. When power comes back on, typically HomeAssistant is quicker to boot up than my remote wifi/starlink system.
As a result, HomeAssistant will connect to my neighbors wifi, because my wifi isn’t available, and I guess once, years ago, I connected to my neighbors wifi.
I would really like to tell HomeAssistant to forget (only) my neighbors SSID.
I have found instructions for doing this via the CLI, but - it’s remote, and I’m not there. Surely there’s a way to forget an SSID without using NMCLI on console?
I’ve also found instructions for deleting ALL SSIDs, but I don’t want to delete the correct SSIDs.
Can you change the configured password for the neighbours WiFi SSID to an incorrect password so it will not successfully connect? Ask your neighbour to change their SSID password as part of good security practise?
You can use the Home Assistant Community Add-on: SSH & Web Terminal - Installation / Home Assistant OS - Home Assistant Community to get to the console.
EDIT: That is the wrong Add-On since it only works in protected mode. The correct add-on is hassio-addons/addon-ssh: Advanced SSH & Web Terminal - Home Assistant Community Add-ons
SSH doesn’t get me to to the actual Debian console. SSH console is just another container.
Not really the solution I’m looking for here. That’s a ton of work for someone with a lot of devices…
at the ‘ha >’ prompt type in login
The neighbour has access to your remote system through their WiFi - could you get them to do the change from their end?
I think that is only available from the local console? I need a way to do it remote.
It doesn’t work from SSH container.
Sure, but how? How do you forget an SSID without walking through the forest with a keyboard and monitor?
Use the ssh add-on from the community store with protection disabled
(and just login, not ha login)
I edited my post above as I had posted the wrong add-on. The one you need is hassio-addons/addon-ssh: Advanced SSH & Web Terminal - Home Assistant Community Add-ons
Make sure you disable ‘Protection Mode’
Maybe someone can walk me through doing this?
Using The Advanced SSH Ad-on, with protection disabled, I still cannot access the BaseOS Wifi settings.
On a separate machine, from the console, I can run ‘nmcli’ and access the Debian Network Manager CLI.
But on this remote machine, when I connect via either SSH ad-on, NMCLI is not available, even after running login. I’m still in a container, not on the base-os.
You can see that with the 'Welcome to Alpine!" line.
Maybe someone can show me how I can see the Wifi connection configs?
If you can figure out from within HASS what the current SSID is, you could possibly write an automation to reboot after x number of minutes on the assumption that by that point your own WiFi has been restored.
Unfortunately, all I have in this regard is the high-level suggestion; I don’t know how to implement either piece of that on your system.
I don’t think such a sensor exists.
The whole idea of WiFi is discouraged in the installation documentations, and then to add a sensor on the WiFi, just in case someone not only adds one WiFi but two?
I doubt it…
I want to apologize as I did not realize this was no longer possible using the Add-on nmcli command not found · Issue #891 · hassio-addons/addon-ssh
Seems the only way now is to create an SSH debug port. You can try this :new:[add-on] HassOS SSH port 22222 Configurator - Installation / Home Assistant OS - Home Assistant Community
I run HA OS in a VM on Proxmox so normally have access to the Console even remotely, so not sure if the above will work.
Can you point to the documentation where WiFi discouraged? I do not see that.
I don’t believe there is a single document that says “do not use Wi-Fi”, however I would say the documentation does recommend a Wired Ethernet connection (Raspberry Pi - Home Assistant).
These would be the main reasons:
1). Reliability: A wired connection is stable and less prone to interference or signal drops.
2). Latency: Ethernet has a much lower latency, which in turn means a faster and more responsive system.
3). Power: Wi-Fi actually consumes more power than Ethernet.
Yeah, wired would certainly avoid issues like this, but the prior comment suggested it was actually discouraged, or possibly not-supported. I didn’t think that was the case.
I’m a bit stunned that forgetting an SSID is this complex.
I guess it is because very few people have run into the issue and the Dev’s haven’t consider adding a UI for it because the recommendation is to use Wired Connections.
I’ve never tried the WiFI settings in HA so have no clue what they look like.
I can’t find it now, but just a last week I copied from some page on HA documentations the following in response to someone else:
Ethernet cable. Required for installation. After installation, Home Assistant can work with Wi-Fi, but an Ethernet connection is more reliable and highly recommended
