I recently added my 1st Reolink camera, Iāve installed the custom component and everything is working great.
Iām wondering if thereās any way to create the behavior my other Ring cameras have in Home Assistant, where clicking the image opens a window and plays back the most recent motion event. In other words clicking the image would get the camera to stream playback of the most recent recording on the SD card.
Iām experiencing streams being cut with the custom component after a day or so.
Not so with the generic component.
Anyone else also experiencing the same?
Im using my reolink cameras with snapshot and record services without any problem and using pushover too, I added my camera as ffmpef platform and rtsp input
All working fine
## Log Details (WARNING)
Mon Dec 16 2019 10:57:26 GMT+0000 (Western European Standard Time)
You are using a custom integration for reolink_dev which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
@roadkill247
Hey Road
I ended up putting a POE Switch so my cams and NVR are ON the same network. Itās the only way I could get it to work. It better as i donāt need to run all cams back to the NVR, just back to the closes switch. And it opens up the ability to connect to the cams independently via the custom component or Onvif or use tiny ipcam on my firetv.
