I intending to install a customized internet access point and home automation system at my mother of law’s cabine.
The reason is that her current system is broken and a replacement is ridiculously expensive.
Moreover, she was used to having a second home internet connection offered by her ISP of her main home for not little money plus a fixed-line plan.
The fixed-line was necessary as the old system was controlled by calling the fixed-line.
This is obsolete now as she is on a very decent mobile data plan.
She could go the usuals way for a non-techy and upgrade the current system to work via wifi and mobile internet but is that hell-like expensive and will cause following-up costs.
So I told her that there are reasonable prices alternative using e.g.
- a Raspberry or similar
- plus automation hardware
- low-cost mobile plan
- home-assistant.
I hope that you folks can give me some bits of advice on the components than if anything goes wrong with that system I’m going to burn in hell .
This is the current hardware what is installed including the hardware that needs to be replaced (partially):
- electrical heater 1000 W, model ATLANTIC SOLIUS 510312, there is a manual but in French the most important is this illustration
Thermor wall mounted boiler what is self-regulating
- ADSL modem
- DELTA DORE home automation
- TYPHONE 500, to control the system via fixed line
- GP500
- DRIVER 520
second and third comes as the PACK LABEL PERFORMANCE package. The installation and operation manual are in French but the illustration below is the most important piece of information:
As at least the DRIVER 520 is broken I want to replace the entire system and make it feature ready (video surveillance, medai server etc.).
I compete against the offer to replace it by the
- TYDOM 1.0 what is somehow reachable via web according to this youtube clip although it looks like to be designed for home use only. Details are in interogration
- three RF 6000 FP
bundled in the PACK RF6600 FP CONNECTE / RF 6600 FP CONNECTED PACK for 220 €
I don’t like that system as it communicates via the property X2D and X3D protocol altough there are attempts to hack it.
My current idea of setup would be:
- raspberry pi B+
- 2G/4G modem
- 4G Antenna
- cheap sim 2€ / month includes 50 MB, unlimited national SMS, 2 hours national outbound talk, unlimited incoming calls, upgradeable to 100 GB and unlimited talk if staying longer
- home assistant
- 230 V relays to control the heaters
- 230 V relay to control the boiler
- WifFI extension either by a
- second access point
- WiFi extender
- Powerline
for indoor and outdoor coverage to allow outside installation IP cameras.
Moreover, I want to avoid to have low signal around that place to counter radiation exposure discussion.
- VLAN (home and guest wifi)
- Firewall allow internet access only when mobile plan allows it. (changed manually via Home Assitant command).
I still need to check if SMS is received after a plan change. This could allow automotive firewall profile change.
possible extension
- alternating current source controlled by temperature measurement
- roller shutter control
- garage door control
- camera surveilance
