Repositories have stopped working
This mornin I was logging in to take a snapshot of my system as I had some free time. I noticed the configurator wasn’t working. I rebooted. Same issue. Nothing would show.
I tried to remove the add-on, then went to add it back. No repositories. Weird. opened up the firewall for this PI to see if that was why. Nope, cannot add an repo’s either…
21-04-27 05:41:56 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
21-04-27 05:42:04 WARNING (MainThread) [supervisor.store.data] No repository information exists at /data/addons/git/96a017aa
21-04-27 05:42:05 INFO (MainThread) [supervisor.store] Loading add-ons from store: 43 all - 0 new - 0 remove
21-04-27 05:42:05 INFO (MainThread) [supervisor.resolution.fixups.store_execute_remove] Remove invalid Store: core
21-04-27 05:42:05 ERROR (MainThread) [supervisor.store.repository] Can’t remove built-in repositories!
21-04-27 05:42:05 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.RUNNING
21-04-27 05:42:05 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.SECURITY/ContextType.CORE
21-04-27 05:42:05 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.FREE_SPACE/ContextType.SYSTEM
21-04-27 05:42:05 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.PWNED/ContextType.ADDON
21-04-27 05:42:05 INFO (MainThread) [supervisor.resolution.check] System checks complete
21-04-27 05:42:05 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state CoreState.RUNNING
21-04-27 05:42:05 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
saw this question on another thread
“Hello, can you share a print screen of “system health” (configuration menu → Info)…
Do you use a SD card to boot from ?”
Yes. I use an SD card to boot from. Does this affect repositories not found?
just upgrade to 2021.4.6. still the same erorrs
Unspported. Read the provided link to find out why.
Everthin was working fine for the last year and now all of the suddent it comes falling down. I don’t need more features, just wanted a stable system. Spent far too much time on this and although vested in the solution, considerin abandoning my setup… Frustrating.
I’m running a raspberr pi, SD card boot. Now all of the sudden HASSIO isn’t support on it? Am I understanding that correctly?
Actually, it sasy Debian Buster (10) which is what i’m running on the PI
Or I need to SSH to the box to do this?
But what if I cannot modify SSH because the repository isn’t work?
Do you use home assistant supervised install? If so, you can ssh to the pi directly, no addon needed. just sshd need to be running, maybe you need to enable it with a keyboard and screen attached to the pi.
For god’s sake click on the supplied links.
Seem to be a Pi issue.
Raspberry Pi Addon Repositories missing / not working
No valid repository
and several entries more.
I’m doing my best here. I think I meet the OS version but I don’t have SSH so i’m triyng tget that worrking so I can get into this docker system that I don’t know. This isn’t intuitive for me. Wish I would (could?) have just stayed at the previous working version…
I didn’t do anything and now all of the repo’s are workin and I can see the configurator…
It seems as thought I cannot make the appropriate changes that nickrout asked me to via ssh as i cannot seem to gget out of the container…
So, i was able to the configurator/file back up. I can open SSH via the browser – still have the unsupported message as I cannot get anywhere, trapped inside the docker container.
I think you probably don’t. Can you show a screenshot of the info screen?
Hey David…
From the link
From my info
Am I wrong in seeing the Linux 10 Buster as the same, or are they different? I’m running on a raspberry pi as it was the simplist for me to understand get running. Given all teh issues i’ve spent hours looking at (from the disappearing conigure sidebar, to ssh, to docker, etc)
Raspbian </> Debian even though it’s based on Debian.
I’m still confused. That was my issues why the repositories weren’t working or why I got reamed out above. Trying my best here. Way over my head with this stuff and spent hours on it…
Thank you David for sharing info with me.
I dont wanna be rude or so, but to use supervised install its atleast mandatory to know some linux stuff like how to activate ssh, difference between native ssh on the pi and ssh addon, difference between raspbian/raspberry pi os and debian and how to setup correctly supervised install by yourself and how to fix the issues mentioned by the supervisor. Its probably better to switch to home assistant (former called hass.io), thats simpler to use and wont come with these drawbacks.
Thanks Tenn0. I think i’ve done pretty well with my little knowledge. It was been running for a year… I was able to get SSH working in the browser, but I’m not able to break out of the container to access the files that I want to to change my journaling config. I may have another issue with the PI or my firewall which seems to not let me remote in (any port is accepted). But that’s separate.
There is a reason I went with the Raspian supervised install and that was for the store, was I was guided that way because it’s easier. Now with it being unsupported, it seems i’m being pushed back towards hassio… The reason I went with the supervised option was because I had an update that broke my previous install and because I didn’t have access to the OS files (even taking the SD card out) i had to scrap my entire setup.
I may just give up on the Raspberry and run it on my Server as a VM but again, that has other challenges…
If you know how to run a VM I would consider switching to that. The VM image is maintained by the HA team so they address all the compatibility issues. I managed to get the VM up and running and applied my snapshot back in no time. Like I think it was literally 15 minutes.
Just download one of the prebuilt VMs from the HA site, load it on your VM platform of choice, apply the snapshot, and you’re up and running like nothing changed.
It’s certainly easier than trying to manage the image yourself (if you have little experience doing so).
Thanks @jjross jjross.
So here is my dillemma. Failed setups have left me salty. I thought going with Rasp/HA would solve it. Apparently not.
I have a raspberry PI. I can only run Raspiann not full Debian 10 on it. So that method is gone.
I can run Home Assistant (Hassio) but that is a limited environment (access to the host OS which is what I wanted after the last crash) – but I do get add-on’s – I use Node-Red so I need this one.
The main reason I haven’t gotten rid of the PI and went to the VM on my server is because I use a z-wave stick and I’m not sure how to pass the z-wave stick to the VM that has HA on it… I guess that’s another thread…
I do know the ESXI environment well as well as traditional linux so I’m comfortable there.
Appreciate the insight on the moving of your config/upgrade. It would be nice to have it on a system /VM that I can fully backup as well.
Or you could run debian + supervised.
