I was trying to code a ring component too when i saw your work, so I can stop and work on something else
Please keep an I on the reddit topic it’s about our doorbells sending strange traffic to china…
Team, the PR was merged and we should have Ring sensor officially on 0.40 version.
@rdnzl you are more than welcome to help on the remaining pieces. Basically I’m working on a custom UI card and still studying the best way to get a binary_sensor for motion alerts. Just let me know then we can split our efforts.
Thanks everyone for all the tests and I’m happy to see the growth of HA.
mmello
@tchellomello Are you only going to create a binary_sensor for motions or also for rings? Since I’d still like to have HASS act on it whenever someone rings my doorbell
I believe I saw the Ring app on Windows 10 doing some kind of notification registration via the API.
I have to start Fiddler again to check this.
Hello @syphernl yes, I want to. I’m still trying to understand how the notifications work to implement it.
Like @rdnzl said, using a mitmproxy to sniff the communication from the Ring app installed on a Windows client, I saw the notification registration.
I’ve already started some work to get it supported as you can see https://github.com/tchellomello/python-ring-doorbell/commit/3fbc00e22f2203081bbc6361b1383f9ff614f0bf but still need to figure out a good way to get it working. I’m currently testing via IFTT especially for instances that are not public on the internet.
Hello guys,
I think were able to crack the motion and ding sensor on Ring. I’ve published a new test version on my personal branch and would be awesome if you guys could test it. I’ve been running on my own house for the next 2 days and it is working fine. Today I published a new version for the 3rd library party [1] to prepare a PR to HA in case it works for you too. OK, let’s get to work. To use the new sensors, basically follow the steps below:
Ring Binary Sensor -> https://raw.githubusercontent.com/tchellomello/home-assistant/ring_binary_sensor/homeassistant/components/binary_sensor/ring.py
Ring Sensor -> https://raw.githubusercontent.com/tchellomello/home-assistant/ring_binary_sensor/homeassistant/components/sensor/ring.py
Make sure the both files are correctly placed under the custom_components directory.
(home_assistant) ↪ tree custom_components/
custom_components/
├── binary_sensor
│ └── ring.py
└── sensor
└── ring.py
The use the configuration:
#configuration.yaml
binary_sensor:
- platform: ring
username: !secret ring_username
password: !secret ring_password
monitored_conditions:
- ding
- motion
- platform: ring
- battery
- last_activity
- volume
Verify the configuration with hass --script check_config
and start HA as expected.
Please let me know any errors or good results. Thank you for your time.
mmello
[1] - https://pypi.python.org/pypi/ring-doorbell
https://github.com/tchellomello/python-ring-doorbell/releases/tag/0.1.1
Everything seems to be working over here; I tested for a bit but due to the high winds here I have had to disable motion for the night.
But it all checks out and at this point I feel like I can remove Ring from Wink and just use HA and the native app. So thank you!
Awesome @rpitera. How was the response time? Did you try motion and ding? Did it work fine?
I’m very glad to know that it worked for you. I’m going to wait another person to test and if that works, I’ll go ahead and submit the PR to see if we can get it included to 0.40 version.
Thanks @rpitera. I really appreciate your help.
The binary sensor has been off since the moment HA started, the last_activity
hasn’t changed either. While typing this someone walked past my house and seems to have triggered the motion sensor which did update the last_activity
and also the binary_sensor
for motion is on
so that looks fine.
Also, just tried the doorbell again and it is properly switching to on
! I may have been too soon to try after restarting HA
So: it works!
In the previous version the last activity was showing on which event (ding / motion). Wouldn’t it make sense to split the last activity in one for both events? Although one could also get the last changed time of the binary sensor.
It should take about 5-15 seconds to see the sensor active. Did you see any attributes being changed on the motion binary_sensor? Did the last_activity work fine?
Seems to be working now! It just takes a bit longer than I expected.
Motion works, ding works as well! Awesome, looks like its time to write some automations based on the events
Nice!! PR submitted today and let’s see if we can make it to 0.40.
@syphernl I liked your idea of splitting the last_activity sensor to cover dings and motion as well.
Maybe instead replacing the last_activity
we can create 2 new ones like last_activity_motion
and last_activity_ding
sensors.
Inspired on your requested, I’ve submitted a PR already to the 3rd party library and the next step will be to add them on HA which probably will be present on 0.41.
Thanks!
I got compile errors on each sensor when I tried them out. I just copied the config stuff right off your post.
Downloaded the files using the links in the post.
17-03-10 18:34:19 ERROR (MainThread) [homeassistant.components.sensor] Error while setting up platform ring
File “/usr/local/lib/python3.4/dist-packages/homeassistant/helpers/entity_component.py”, line 151, in _async_setup_platform
entity_platform.add_entities, discovery_info
File “/usr/lib/python3.4/asyncio/futures.py”, line 388, in iter
yield self # This tells Task to wait for completion.
File “/usr/lib/python3.4/asyncio/tasks.py”, line 286, in _wakeup
value = future.result()
File “/usr/lib/python3.4/asyncio/futures.py”, line 277, in result
raise self._exception
File “/usr/lib/python3.4/concurrent/futures/thread.py”, line 54, in run
File “/home/tcarlin/.homeassistant/custom_components/sensor/ring.py”, line 85, in setup_platform
sensor_type))
File “/home/tcarlin/.homeassistant/custom_components/sensor/ring.py”, line 101, in init
self._name = “{0} {1}”.format(self._data.name,
AttributeError: ‘str’ object has no attribute ‘name’
17-03-10 18:34:20 WARNING (Thread-3) [fedexdeliverymanager] totalNumberOfShipments = 0
17-03-10 18:34:26 ERROR (MainThread) [homeassistant.components.binary_sensor] Error while setting up platform ring
File “/home/tcarlin/.homeassistant/custom_components/binary_sensor/ring.py”, line 56, in setup_platform
persist_token=True)
TypeError: init() got an unexpected keyword argument ‘persist_token’
$ sudo pip3 install git+https://github.com/tchellomello/python-ring-doorbell@dev --upgrade
Collecting git+https://github.com/tchellomello/python-ring-doorbell@dev
Cloning https://github.com/tchellomello/python-ring-doorbell (to dev) to /tmp/pip-27mr_dbo-build
Requirement already up-to-date: requests in /usr/local/lib/python3.4/dist-packages (from ring-doorbell==0.1.1)
Requirement already up-to-date: pytz in /usr/local/lib/python3.4/dist-packages (from ring-doorbell==0.1.1)
Installing collected packages: ring-doorbell
Found existing installation: ring-doorbell 0.1.1
Uninstalling ring-doorbell-0.1.1:
Successfully uninstalled ring-doorbell-0.1.1
Running setup.py install for ring-doorbell … done
Successfully installed ring-doorbell-0.1.1
Forget my last post. I found there was an old version of ring-doorbell left over from some early testing. When I removed it, both sensors came up just fine. Sorry 'bout that.
Yes, based on the error it seems that you were using the old version probably under deps
directory.
@syphernl I’m already testing a separated sensor as you suggested. Check it out:
One that reports any activity, one only for dings and another for motions. I don’t think this change can make into 0.40, so I’ll submit the PR next week.
Hi All,
I setup as explained with one exception. UI have a seperate sensors.yaml file which I include in my main config. In the main config I did however add the binary sensor. I am not sure if this woudl have thrown something, HOwever, I received this error in my log:
17-03-11 21:17:19 ERROR (MainThread) [homeassistant.components.binary_sensor] Error while setting up platform ring
File “/usr/src/app/homeassistant/helpers/entity_component.py”, line 151, in _async_setup_platform
File “uvloop/future.pyx”, line 230, in iter (uvloop/loop.c:110600)
File “uvloop/future.pyx”, line 432, in uvloop.loop.BaseTask._fast_wakeup (uvloop/loop.c:113980)
File “uvloop/future.pyx”, line 101, in uvloop.loop.BaseFuture._result_impl (uvloop/loop.c:108900)
File “/usr/local/lib/python3.5/concurrent/futures/thread.py”, line 55, in run
File “/config/custom_components/binary_sensor/ring.py”, line 56, in setup_platform
persist_token=True)
File “/config/deps/ring_doorbell/init.py”, line 51, in init
self._authenticate()
File “/config/deps/ring_doorbell/init.py”, line 85, in _authenticate
req.raise_for_status()
File “/usr/local/lib/python3.5/site-packages/requests/models.py”, line 909, in raise_for_status
raise HTTPError(http_error_msg, response=self)
requests.exceptions.HTTPError: 401 Client Error: Unauthorized for url: https://api.ring.com/clients_api/session
Any ideas as to where I may be going wrong?
@uiguy Judging from the error it looks like your credentials aren’t valid. Did you provide the right credentials (email and password) and do they work if you login at ring.com?
You need to provide the credentials to both components: sensor & binary sensor.
yes, I use the same details for both the binary and normal sensor
