and if you use the same username from the risco app, can you still login in he cloud?
can login no prob, but cannot disarm or arm inside the app if ive enabled the intergration
strange, no issues here
There are people who have integrated the function
utility outputs present in the RISCO app?
The function is used to activate or deactivate the relays in the alarm.
Can someone help me?
pergola.fabio, do you speak italian?
i have a question for you.
No, I donāt speak italian unfortunately
On the RISCO App there is a function utility outputs.
The function is used to activate or deactivate the relays.
Has been integrated?
I donāt know , donāt think so, in didnāt create this
I think you can only read statesā¦ But I can ask the developer
Can you help me by asking the developer?
The function is useful. Thank you.
Ok, why do you use them anyway?
I use there in the risco app. But i want to use them in home assistant.
But what have you attached to it, can you give an example? Is it for lights and stuff?
Ah, you can also use a cheap nodemcu board to control relays
Correct but I would like to use this card that I have
@Francesco_Baruzzo got feedback, no the outputs are not available in integration
and he is not going to develop it, since its needs to be reverse enginered
not a good idea anyway to use outputs because of the polling interval
but risco is coming, they promisied to release a public api, so maybe in future it will be possible
thanks we look forward to the new apiā¦
some updates, risco 5.5.0 is coming in about 3 weeks, afterwards public api will be availaible in 5.6.0 or 5.7.0
For some reason, my connection drops out for s short period then reconnects. (still trying to work why this happens)
When the connection drops out, the alarm on HA reports, alarm unavailable then when it reconnects, it reports backs the status of the alarm prior to connection drop out, which in most cases my alarm is disarmed status
My network drops out at least once a day if not more at random times.
I am currently running (lights on) automation based on the disarm reporting but due to the dropouts, my light turns on every time itās recovered from a connection drop out.
Is there a way to have the integration report a different status after connection dropouts?
Itās normal behavior, best to change your automation from state
