Are you using the Xiaomi Miio integration which works with the Xiaomi Home app, or the new roborock integration which works with the roborock app?
My post was referring to the new Roborock integration, not the Xiaomi Miio.
Indeed I had not seen that you had recreated an api. What evolution does your integration bring ? Did you test it with a roborock s7 pro ultra ?
It is not my integration This integration was primarily developed to be able to use the roborock app which supports the camera of the S7 MaxV - which does not work in the Xiaomi Home app.
Since S7 pro doesnāt have the camera, that is not a valid reason for you of course. I have not used the Xiaomi Miio integration, so I donāt know if there are other major differences.
Ok I see to integrate it. And it works well. No more flipped sensor and most importantly the mop management works unlike the Xiaomi Home app integration. Thank you itās a nice discovery
Since the sensor life is measured in seconds when you look at the history, I made my own sensors in config.yaml to convert the values to percentages and then reference those new sensors to create a tile in the vacuum card. See code below.
@wgumaa As far as zones and rooms go, it is rather straight forward after you āgenerate static configā and āgenerate room configāā¦Just check the yaml code in the card to make sure the service calls are referencing your entity, otherwise it wonāt work. Not sure if it has been fixed or not in recent updates, but when I first generated config my service calls were referencing something like xiaomi.vacuum_clean_segment rather than the correct reference for me which was roborock.vacuum_clean_segment.
@tjafbe I have noticed that although I donāt appear to lose āconnectionā to the entities and map, they do stop updating after a while and a restart of HA is required. Is this still a bug being worked on?
- name: "Roborock Filter Left"
unit_of_measurement: '%'
state: >-
{{ (((states('sensor.max_filter_remaining') | float(0)) * 100) / 540000) | round(0) }}
- name: "Roborock Main Brush Left"
state: >-
{{ (((states('sensor.max_main_brush_remaining') | float(0)) * 100) / 1080000) | round(0) }}
- name: "Roborock Side Brush Left"
state: >-
{{ (((states('sensor.max_side_brush_remaining') | float(0)) * 100) / 720000) | round(0) }}
- name: "Roborock Clean Sensors"
state: >-
{{ ((states('sensor.max_sensor_dirty_remaining') | float(0)) / 3600) | round(0) }}
- name: "Roborock Room"
state: >
{% if is_state_attr('camera.max', 'vacuum_room', 16) %}
Dining Room
{% elif is_state_attr('camera.max', 'vacuum_room', 17) %}
Sunroom
{% elif is_state_attr('camera.max', 'vacuum_room', 18) %}
Kitchen
{% elif is_state_attr('camera.max', 'vacuum_room', 19) %}
Living Room
{% else %}
Not Sure
{% endif %}
Yeah. For me the map also regularly stops updating with only an integration reload helping. I hope this will eventually be addressed, but I am not involved (and not capable) with the development.
How do you generate those?
Hey guys,
The HACS Roborock integration is great - I am glad to be able to keep my Roborock app up and running!
I am able to add the device with 21 entities - but seem to be missing the camera entity? (S7 VMax Ultra). Any ideas??
Edit: After several reboots/device updates the camera entity did finally pull in. Not sure what I did to trigger it - but it was most likely me being impatient.
Do you mean the live front camera?
When I send the vacuum.pause
command to my S7, it sets it āidleā and is unable to resume whatever it was set to clean (e.g. segment, zone, etc.). Sending a vacuum.start
command after the vacuum is either āidleā or āpausedā causes it to start a full cleaning (even when paused from the app). Also, vacuum.start_pause
throws an unknown error, regardless of what state the vacuum is in.
Is there a way to pause the current cleaning and then resume? Maybe by creating a new roborock.pause
or roborock.start_pause
command?
Iāll also add that after pausing from the app, I was able to resume cleaning from HA using
service: vacuum.send_command
command: resume_segment_clean
After a few days of use, I notice that the Roborock service crashes regularly which causes an error message when calling the service and the card does not update. Moreover, I find that the update of the values is too slow.
I tried setting up a simple automation to send notification when attribute ādock_error_statusā change to 38.
But for some reason it doesnāt seam to work.
Any idea why ?
alias: Roborock water tank notification
description: ""
- platform: state
entity_id:
- vacuum.roborock_s7_maxv
attribute: dock_error_status
to: "38"
- platform: state
entity_id:
to: "39"
condition: []
- service: notify.mobile_phone
message: water tank full
mode: single
Hello All,
Is it possible to read rooms and send the vacuum to multiroom cleaning, eg. kitchen and floor?
I donāt see this data pointsā¦
I canāt get those sensors to show up. Iām still pretty green though. Is there anyway you could post a screen shot of your actual config, so I can get the spacing right? I have added everything to the config.yaml, and itās not throwing any errors. Rebooted and they sensors are still not showing up.
I found that if you use the xiaomi-vacuum-map-card, go into the code editor and make sure that all the sensors are using the ones created by your integration. It didnāt automatically pick up the name of my vacuum.
I have the vacuum set up with 22 sensors. Iām trying to get the sensor info turned into percentage, so I can add the tile to the card.
platform: roborock
name: āRoborock Filter Leftā
unit_of_measurement: ā%ā
state: >-
This passes the self check, but Iām not getting a new sensor with the % of life left.
I know but Iām saying if you use the xiaomi-vacuum-map-card, then you will get the sensors to show up, as long as you update the yaml code in the card to reflect the actual name of the sensors being provided. However, the sensors will show up as āhours remaining.ā
For example, the xiaomi-vacuum-map-card defaults to something like āsensor.filter_remainingā but I had to change it to sensor.[VACUUM NAME]_filter_remaining
The conversion above is to change it from hours to percentage. If thatās what youāre trying to accomplish, then you can ignore my post.
I get the value to show up, as hours remaining, but I want %. I canāt figure out how to get it to show a percentage.
First of all, great work! Working really good with my Roborock S7.
I got one problem with the integration though, all commands (send_command) gives me an error message āFailed to request the service blablablaā. It works, but I got this error message. Anyone know what causing this?
Try to put this in your sensor.yaml:
sensors:
roborock_filter_left:
friendly_name: "Roborock Filter Left"
value_template: >-
{{ (((states('sensor.change_this_to_your_sensor) | float(0)) * 100) / 540000) | round(0) }}
then reload template sensors and use sensor.roborock_filter_left in your tile.
- entity: sensor.roborock_filter_left
label: Filter livslƤngd
icon: mdi:air-filter
unit: '%'
