Rtl_433 installation
I have rtlsdr running on a Rpi 0w and mosquitto running under proxmox with Home assistant. All works nicely except the RPi 0W doesn’t seem to have enough speed to handle -H frequency skipping and sending to MQTT.
I would like to move everything under home assistant (under Proxmox). I am unable to get automated installs…I can’t add the directories. The instructions say “install the add on” which isn’t exactly helpful without telling you how to do it…of course it tells you to add through the addon store…but the directory fails so I can’t do it that way.
How do I add the rtl_433 addon’s? what files do I copy where…or how do I get them to show up under either HACS or the addon store?
I don’t do VMs, but I have 2 SDRs on my server, one running RTL_433 and the other running RTL_TCP, both as docker containers… works great, just tell each which device number to use… my HA install is a supervised docker container…
I’ve not run across options for freq skipping… could you explain how that is working?
hope that helps you…
Add the following options to wherever you have your option string:
-H 120 -f 433 -f 915
This will hop between 433mhz and 915 mhz every 120 seconds. the default for -H is 600 seconds but you can change it (eg 120).
I am not running my own docker…I just use the one started by Home Assistant…I have the MQTT add on installed, but I don’t know how to install rtl_433 itself under Home Assistan.
ah, thx… that helps my project a ton… I was wondering how to use one SDR to read 433 & the ISM band (902-926MHz) for utility meters…
RTL_433 doesn’t install directly into HA… or at least I’ve never run across that idea anywhere…
there is an add on …on github…
installation instruction says “install add on” … not exactly the most helpful instruction.
ok, in HA…
  1. goto settings
  2. goto add-ons
  3. click add-on store
  4. click 3 vertical dots in upper right corner
  5. click repositories
  6. add: https://github.com/pbkhrv/rtl_433-hass-addons
  7. click add
  8. close
  9. refresh page, new add-ons for RTL_433 at the bottom…
now it should work… let me know either way…
I would have sworn I did exactly that…but yes, it worked…thanks.
Next problem. I have a string of options I’d like to use when starting rtl-433:
-H 180 -f 433920000 -f 914915000 -R 11 -R 142 -R 71 -F “mqtt://192.168.1.177:1883,user=“xxx”,pass=“yyy”,retain=0,events=rtl_433”
If I enter them into a file, it doesn’t recognize -? commands…the addon seems to want words like output -F…
Is there a way to save the startup options???
(note: that string works…usiing frequency hopping etc).
UPDATE: I figured it out…I can’t use -H type commands, I have to use the full words.
I’m actually putting everything into the config file and using it that way…
sample config: https://github.com/merbanan/rtl_433/blob/b668f40fd539644fd3a9c1a9884f2fb2a2bff0f6/conf/rtl_433.example.conf
once you create a config file, you have to specify where it is… in the addon configuration tab, give the path of the config file…
apparently, you can’t use the -F or -H format in the configuration files, you have to use the full words like Output and hop_interval.
were you able to get this working?
i was able to get the installation done and it Started.
in my config, i editted to fit my setup:
in the Add-On config, i got that file selected
when i listen, i still get nothing
Yes, I’m running that addon…with a separate Mosquitto server (I run everything under proxmox). I read the Mqtt data in node-red
I’m traveling working from an iPad mini, so not easy to help you out. Likely your config file is wrong
Did you get your problem solved since I have the same issues
i could not solve. so i went back to Sonoff 433 wifi device
@tung256 . I just installed it and ran it without a conf file as I didn’t know where to put it. Put the RTL dongle in the back of RPI 3B+ running HA. I have mosqitto running on the HA and it all just started up and put messages through MQTT.
@Spiro How did you manage to get is working. Any more detailed instuctions?
Very confusing.
I did install and run successfully the RTL_433 on Windows 10 Virtual Machine running Ubuntu and get the results. So the SDR dongle works.
time : 2023-01-31 17:52:55
model : Nexus-TH House Code: 244
Channel : 2 Battery : 1 Temperature: 11.70 C
Humidity : 39 %
But MQTT etc is more confusing on Home Assistant ( I run the Home Assitant OS on Raspberry Pi)
# config for rtl_433
# A valid config line is a keyword followed by an argument to the end of line.
# Whitespace around the keyword is ignored, whitespace is space and tab
# Comments start with a hash sign, no inline comments, empty lines are ok.
# Boolean options can be true/false, yes/no, on/off, enable/disable, or 1/0
# All options will be applied in the order given, overwriting previous values
# Config files can be nested/stacked (use multiple -c and config_file = ).
# If no -c option is given the first found of this list will be loaded:
# - ./rtl_433.conf
# - ~/.config/rtl_433/rtl_433.conf
# - /usr/local/etc/rtl_433.conf
# - /etc/rtl_433.conf
## General options
# as command line option:
#   [-v] Increase verbosity (can be used multiple times).
#        -v : verbose, -vv : verbose decoders, -vvv : debug decoders, -vvvv : trace decoding).
# 0 = normal, 1 = verbose, 2 = verbose decoders, 3 = debug decoders, 4 = trace decoding
#verbose
#   [-c <path>] Read config options from a file
#config_file
## Tuner options
#   [-d <RTL-SDR USB device index>] (default: 0)
#   [-d :<RTL-SDR USB device serial (can be set with rtl_eeprom -s)>]
#   [-d "" Open default SoapySDR device
#   [-d driver=rtlsdr Open e.g. specific SoapySDR device
# default is "0" (RTL-SDR) or "" (SoapySDR)
device        0
#   [-g <gain>] (default: 0 for auto)
# For RTL-SDR: gain in tenths of dB ("0" is auto).
# For SoapySDR: gain in dB for automatic distribution ("" is auto), or string of gain elements.
# E.g. "LNA=20,TIA=8,PGA=2" for LimeSDR.
gain          0
#   [-t <settings>] apply a list of keyword=value settings for SoapySDR devices
# E.g. "antenna=A,bandwidth=4.5M,rfnotch_ctrl=false"
#settings      antenna=A,bandwidth=4.5M
#   [-f <frequency>] [-f...] Receive frequency(s) (default: 433920000 Hz)
# default is "433.92M", other reasonable values are 315M, 345M, 915M and 868M
frequency     433.92M
#   [-H <seconds>] Hop interval for polling of multiple frequencies (default: 600 seconds)
# default is "600" seconds, only used when multiple frequencies are given
hop_interval  600
#   [-p <ppm_error] Correct rtl-sdr tuner frequency offset error (default: 0)
# default is "0"
ppm_error     0
#   [-s <sample rate>] Set sample rate (default: 250000 Hz)
# default is "250k", other valid settings are 1024k, 2048k, 3200k
sample_rate   250k
## Demodulator options
#   [-R <device>] Enable only the specified device decoding protocol (can be used multiple times)
# see "protocol" section below.
#   [-G] Enable blacklisted device decoding protocols, for testing only.
#register_all false
#   [-X <spec> | help] Add a general purpose decoder (prepend -R 0 to disable all decoders)
# see "decoder" section below.
#   [-Y level=<dB level>] Manual detection level used to determine pulses (-1.0 to -30.0) (0=auto)
#pulse_detect level=0
#   [-Y auto | classic | minmax] FSK pulse detector mode.
#pulse_detect auto
#   [-n <value>] Specify number of samples to take (each sample is 2 bytes: 1 each of I & Q)
samples_to_read 0
## Analyze/Debug options
#   [-a] Analyze mode. Print a textual description of the signal. Disables decoding
#analyze false
#   [-A] Pulse Analyzer. Enable pulse analysis and decode attempt
analyze_pulses false
#   [-b] Out block size: 262144 (default)
#out_block_size
#   [-M time[:<options>]|protocol|level|stats|bits|oldmodel] Add various metadata to every output line.
# Use "time" to add current date and time meta data (preset for live inputs).
# Use "time:rel" to add sample position meta data (preset for read-file and stdin).
# Use "time:unix" to show the seconds since unix epoch as time meta data.
# Use "time:iso" to show the time with ISO-8601 format (YYYY-MM-DD"T"hh:mm:ss).
# Use "time:off" to remove time meta data.
# Use "time:usec" to add microseconds to date time meta data.
# Use "time:utc" to output time in UTC.
#   (this may also be accomplished by invocation with TZ environment variable set).
#   "usec" and "utc" can be combined with other options, eg. "time:unix:utc:usec".
# Use "protocol" / "noprotocol" to output the decoder protocol number meta data.
# Use "level" to add Modulation, Frequency, RSSI, SNR, and Noise meta data.
# Use "stats[:[<level>][:<interval>]]" to report statistics (default: 600 seconds).
#   level 0: no report, 1: report successful devices, 2: report active devices, 3: report all
# Use "oldmodel" to use to old model keys. This will be removed shortly.
report_meta level
report_meta stats
report_meta time:usec
report_meta protocol
#   [-y <code>] Verify decoding of demodulated test data (e.g. "{25}fb2dd58") with enabled devices
#test_data {25}fb2dd58
## File I/O options
#   [-S none|all|unknown|known] Signal auto save. Creates one file per signal.
#     Note: Saves raw I/Q samples (uint8 pcm, 2 channel). Preferred mode for generating test files.
signal_grabber none
#   [-r <filename>] Read data from input file instead of a receiver
#read_file FILENAME.cu8
#   [-w <filename>] Save data stream to output file (a '-' dumps samples to stdout)
#write_file FILENAME.cu8
#   [-W <filename>] Save data stream to output file, overwrite existing file
#overwrite_file FILENAME.cu8
## Data output options
#   [-F kv|json|csv|mqtt|syslog|null] Produce decoded output in given format.
#     Without this option the default is KV output. Use "-F null" to remove the default.
#     Append output to file with :<filename> (e.g. -F csv:log.csv), defaults to stdout.
#     Specify MQTT server with e.g. -F mqtt://localhost:1883
#     Add MQTT options with e.g. -F "mqtt://host:1883,opt=arg"
#     MQTT options are: user=foo, pass=bar, retain[=0|1], <format>[=topic]
#     Supported MQTT formats: (default is all)
#       events: posts JSON event data
#       states: posts JSON state data
#       devices: posts device and sensor info in nested topics
#     The topic string will expand keys like [/model]
#     E.g. -F "mqtt://localhost:1883,user=USERNAME,pass=PASSWORD,retain=0,devices=rtl_433[/id]"
#     Specify host/port for syslog with e.g. -F syslog:127.0.0.1:1514
# default is "kv", multiple outputs can be used.
output json
#   [-C] native|si|customary Convert units in decoded output.
# default is "native"
convert si
#   [-T] specify number of seconds to run
#duration 0
#   [-E] Stop after outputting successful event(s)
stop_after_successful_events false
## Protocols to enable (command line option "-R")
  protocol 1   # Silvercrest Remote Control
  protocol 2   # Rubicson Temperature Sensor
  protocol 3   # Prologue, FreeTec NC-7104, NC-7159-675 temperature sensor
  protocol 4   # Waveman Switch Transmitter
# protocol 6   # ELV EM 1000
# protocol 7   # ELV WS 2000
  protocol 8   # LaCrosse TX Temperature / Humidity Sensor
# protocol 10  # Acurite 896 Rain Gauge
#  protocol 11  # Acurite 609TXC Temperature and Humidity Sensor
#  protocol 12  # Oregon Scientific Weather Sensor
# protocol 13  # Mebus 433
# protocol 14  # Intertechno 433
#  protocol 15  # KlikAanKlikUit Wireless Switch
#  protocol 16  # AlectoV1 Weather Sensor (Alecto WS3500 WS4500 Ventus W155/W044 Oregon)
#  protocol 17  # Cardin S466-TX2
  protocol 18  # Fine Offset Electronics, WH2, WH5, Telldus Temperature/Humidity/Rain Sensor
  protocol 19  # Nexus, FreeTec NC-7345, NX-3980, Solight TE82S, TFA 30.3209 temperature/humidity sensor
  protocol 20  # Ambient Weather, TFA 30.3208.02 temperature sensor
#  protocol 21  # Calibeur RF-104 Sensor
# protocol 22  # X10 RF
#  protocol 23  # DSC Security Contact
# protocol 24  # Brennenstuhl RCS 2044
#  protocol 25  # Globaltronics GT-WT-02 Sensor
#  protocol 26  # Danfoss CFR Thermostat
#  protocol 29  # Chuango Security Technology
  protocol 30  # Generic Remote SC226x EV1527
  protocol 31  # TFA-Twin-Plus-30.3049, Conrad KW9010, Ea2 BL999
  protocol 32  # Fine Offset Electronics WH1080/WH3080 Weather Station
  protocol 33  # WT450, WT260H, WT405H
#  protocol 34  # LaCrosse WS-2310 / WS-3600 Weather Station
  protocol 35  # Esperanza EWS
  protocol 36  # Efergy e2 classic
# protocol 37  # Inovalley kw9015b, TFA Dostmann 30.3161 (Rain and temperature sensor)
  protocol 38  # Generic temperature sensor 1
#  protocol 39  # WG-PB12V1 Temperature Sensor
#  protocol 40  # Acurite 592TXR Temp/Humidity, 5n1 Weather Station, 6045 Lightning, 3N1, Atlas
#  protocol 41  # Acurite 986 Refrigerator / Freezer Thermometer
  protocol 42  # HIDEKI TS04 Temperature, Humidity, Wind and Rain Sensor
  protocol 43  # Watchman Sonic / Apollo Ultrasonic / Beckett Rocket oil tank monitor
#  protocol 44  # CurrentCost Current Sensor
#  protocol 45  # emonTx OpenEnergyMonitor
#  protocol 46  # HT680 Remote control
#  protocol 47  # Conrad S3318P, FreeTec NC-5849-913 temperature humidity sensor
#  protocol 48  # Akhan 100F14 remote keyless entry
#  protocol 49  # Quhwa
#  protocol 50  # OSv1 Temperature Sensor
  protocol 51  # Proove / Nexa / KlikAanKlikUit Wireless Switch
#  protocol 52  # Bresser Thermo-/Hygro-Sensor 3CH
#  protocol 53  # Springfield Temperature and Soil Moisture
#  protocol 54  # Oregon Scientific SL109H Remote Thermal Hygro Sensor
#  protocol 55  # Acurite 606TX Temperature Sensor
#  protocol 56  # TFA pool temperature sensor
#  protocol 57  # Kedsum Temperature & Humidity Sensor, Pearl NC-7415
#  protocol 58  # Blyss DC5-UK-WH
#  protocol 59  # Steelmate TPMS
#  protocol 60  # Schrader TPMS
# protocol 61  # LightwaveRF
# protocol 62  # Elro DB286A Doorbell
  protocol 63  # Efergy Optical
# protocol 64  # Honda Car Key
#  protocol 67  # Radiohead ASK
#  protocol 68  # Kerui PIR / Contact Sensor
  protocol 69  # Fine Offset WH1050 Weather Station
#  protocol 70  # Honeywell Door/Window Sensor, 2Gig DW10/DW11, RE208 repeater
#  protocol 71  # Maverick ET-732/733 BBQ Sensor
# protocol 72  # RF-tech
#  protocol 73  # LaCrosse TX141-Bv2, TX141TH-Bv2, TX141-Bv3, TX141W, TX145wsdth sensor
#  protocol 74  # Acurite 00275rm,00276rm Temp/Humidity with optional probe
  protocol 75  # LaCrosse TX35DTH-IT, TFA Dostmann 30.3155 Temperature/Humidity sensor
  protocol 76  # LaCrosse TX29IT, TFA Dostmann 30.3159.IT Temperature sensor
  protocol 77  # Vaillant calorMatic VRT340f Central Heating Control
  protocol 78  # Fine Offset Electronics, WH25, WH32B, WH24, WH65B, HP1000 Temperature/Humidity/Pressure Sensor
  protocol 79  # Fine Offset Electronics, WH0530 Temperature/Rain Sensor
  protocol 80  # IBIS beacon
  protocol 81  # Oil Ultrasonic STANDARD FSK
#  protocol 82  # Citroen TPMS
  protocol 83  # Oil Ultrasonic STANDARD ASK
  protocol 84  # Thermopro TP11 Thermometer
#  protocol 85  # Solight TE44/TE66, EMOS E0107T, NX-6876-917
  protocol 86  # Wireless Smoke and Heat Detector GS 558
  protocol 87  # Generic wireless motion sensor
#  protocol 88  # Toyota TPMS
  protocol 89  # Ford TPMS
#  protocol 90  # Renault TPMS
#  protocol 91  # inFactory, nor-tec, FreeTec NC-3982-913 temperature humidity sensor
  protocol 92  # FT-004-B Temperature Sensor
  protocol 93  # Ford Car Key
#  protocol 94  # Philips outdoor temperature sensor (type AJ3650)
#  protocol 95  # Schrader TPMS EG53MA4, PA66GF35#
  protocol 96  # Nexa
  protocol 97  # Thermopro TP08/TP12/TP20 thermometer
  protocol 98  # GE Color Effects
  protocol 99  # X10 Security
  protocol 100 # Interlogix GE UTC Security Devices
# protocol 101 # Dish remote 6.3
#  protocol 102 # SimpliSafe Home Security System (May require disabling automatic gain for KeyPad decodes)
  protocol 103 # Sensible Living Mini-Plant Moisture Sensor
  protocol 104 # Wireless M-Bus, Mode C&T, 100kbps (-f 868950000 -s 1200000)
  protocol 105 # Wireless M-Bus, Mode S, 32.768kbps (-f 868300000 -s 1000000)
# protocol 106 # Wireless M-Bus, Mode R, 4.8kbps (-f 868330000)
# protocol 107 # Wireless M-Bus, Mode F, 2.4kbps
#  protocol 108 # Hyundai WS SENZOR Remote Temperature Sensor
  protocol 109 # WT0124 Pool Thermometer
  protocol 110 # PMV-107J (Toyota) TPMS
  protocol 111 # Emos TTX201 Temperature Sensor
  protocol 112 # Ambient Weather TX-8300 Temperature/Humidity Sensor
  protocol 113 # Ambient Weather WH31E Thermo-Hygrometer Sensor, EcoWitt WH40 rain gauge
  protocol 114 # Maverick et73
  protocol 115 # Honeywell ActivLink, Wireless Doorbell
  protocol 116 # Honeywell ActivLink, Wireless Doorbell (FSK)
# protocol 117 # ESA1000 / ESA2000 Energy Monitor
# protocol 118 # Biltema rain gauge
  protocol 119 # Bresser Weather Center 5-in-1
# protocol 120 # Digitech XC-0324 temperature sensor
  protocol 121 # Opus/Imagintronix XT300 Soil Moisture
# protocol 122 # FS20
# protocol 123 # Jansite TPMS Model TY02S
  protocol 124 # LaCrosse/ELV/Conrad WS7000/WS2500 weather sensors
  protocol 125 # TS-FT002 Wireless Ultrasonic Tank Liquid Level Meter With Temperature Sensor
  protocol 126 # Companion WTR001 Temperature Sensor
  protocol 127 # Ecowitt Wireless Outdoor Thermometer WH53/WH0280/WH0281A
  protocol 128 # DirecTV RC66RX Remote Control
# protocol 129 # Eurochron temperature and humidity sensor
  protocol 130 # IKEA Sparsnas Energy Meter Monitor
  protocol 131 # Microchip HCS200 KeeLoq Hopping Encoder based remotes
  protocol 132 # TFA Dostmann 30.3196 T/H outdoor sensor
  protocol 133 # Rubicson 48659 Thermometer
  protocol 134 # Holman Industries iWeather WS5029 weather station (newer PCM)
  protocol 135 # Philips outdoor temperature sensor (type AJ7010)
  protocol 136 # ESIC EMT7110 power meter
  protocol 137 # Globaltronics QUIGG GT-TMBBQ-05
  protocol 138 # Globaltronics GT-WT-03 Sensor
  protocol 139 # Norgo NGE101
  protocol 140 # Elantra2012 TPMS
  protocol 141 # Auriol HG02832, HG05124A-DCF, Rubicson 48957 temperature/humidity sensor
  protocol 142 # Fine Offset Electronics/ECOWITT WH51 Soil Moisture Sensor
  protocol 143 # Holman Industries iWeather WS5029 weather station (older PWM)
  protocol 144 # TBH weather sensor
  protocol 145 # WS2032 weather station
  protocol 146 # Auriol AFW2A1 temperature/humidity sensor
  protocol 147 # TFA Drop Rain Gauge 30.3233.01
  protocol 148 # DSC Security Contact (WS4945)
  protocol 149 # ERT Standard Consumption Message (SCM)
# protocol 150 # Klimalogg
  protocol 151 # Visonic powercode
  protocol 152 # Eurochron EFTH-800 temperature and humidity sensor
  protocol 153 # Cotech 36-7959 wireless weather station with USB
  protocol 154 # Standard Consumption Message Plus (SCMplus)
  protocol 155 # Fine Offset Electronics WH1080/WH3080 Weather Station (FSK)
#  protocol 156 # Abarth 124 Spider TPMS
  protocol 157 # Missil ML0757 weather station
  protocol 158 # Sharp SPC775 weather station
  protocol 159 # Insteon
  protocol 160 # ERT Interval Data Message (IDM)
  protocol 161 # ERT Interval Data Message (IDM) for Net Meters
# protocol 162 # ThermoPro-TX2 temperature sensor
  protocol 163 # Acurite 590TX Temperature with optional Humidity
  protocol 164 # Security+ 2.0 (Keyfob)
  protocol 165 # TFA Dostmann 30.3221.02 T/H Outdoor Sensor
  protocol 166 # LaCrosse Technology View LTV-WSDTH01 Breeze Pro Wind Sensor
  protocol 167 # Somfy RTS
#  protocol 168 # Schrader TPMS SMD3MA4 (Subaru)
# protocol 169 # Nice Flor-s remote control for gates
  protocol 170 # LaCrosse Technology View LTV-WR1 Multi Sensor
  protocol 171 # LaCrosse Technology View LTV-TH Thermo/Hygro Sensor
  protocol 172 # Bresser Weather Center 6-in-1, 7-in-1 indoor, new 5-in-1, 3-in-1 wind gauge, Froggit WH6000, Ventus C8488A
  protocol 173 # Bresser Weather Center 7-in-1
  protocol 174 # EcoDHOME Smart Socket and MCEE Solar monitor
  protocol 175 # LaCrosse Technology View LTV-R1 Rainfall Gauge
  protocol 176 # BlueLine Power Monitor
  protocol 177 # Burnhard BBQ thermometer
  protocol 178 # Security+ (Keyfob)
  protocol 179 # Cavius smoke, heat and water detector
## Flex devices (command line option "-X")
# Some general decoder definitions for various devices, enable as needed.
# For details about decoder definition run "rtl_433 -X help"
# If you enable these decoders you'll likely want to add ",match=<YOUR-DEVICE-ID>"
# Elro DB270 - wireless doorbell
# Device information and test files:
# https://github.com/merbanan/rtl_433_tests/tree/master/tests/elro/db270/01
# Output sample:
# {"time" : "2018-02-14 19:11:16", "model" : "Elro_DB270", "count" : 4, "num_rows" : 4,
#  "rows" : [{"len" : 25, "data" : "ebeaaa8"}, {"len" : 25, "data" : "ebeaaa8"},
#            {"len" : 25, "data" : "ebeaaa8"}, {"len" : 25, "data" : "ebeaaa8"}]}
#decoder n=Elro_DB270,m=OOK_PWM,s=300,l=930,r=11000,g=1500,repeats>=4,bits=25
# Euroster 3000TX - programmable room thermostat
# https://github.com/merbanan/rtl_433_tests/tree/master/tests/euroster/3000tx/01
# Output sample:
# {"time" : "2018-02-14 19:20:20", "model" : "Euroster_3000TX", "count" : 1, "num_rows" : 1,
#  "rows" : [{"len" : 32, "data" : "41150515"}]}
#decoder n=Euroster_3000TX,m=OOK_MC_ZEROBIT,s=1000,r=4800,bits=32
# Byron BY series door bell
# https://github.com/merbanan/rtl_433_tests/tree/master/tests/Byron-BY101 and Byron-BY34
# Output sample:
# {"time" : "@1.572864s", "model" : "doorbell#1", "count" : 25, "num_rows" : 25, "rows" : [{"len" : 21, "data" : "e768c8"}, {"len" : 21, "data" : "e768c8"}, {"len" : 21, "data" : "e768c8"}, {"len" : 21, "data" : "e768c8"}, {"len" : 21, "data" : "e768c8"}, {"len" : 21, "data" : "e768c8"}, {"len" : 21, "data" : "e768c8"}, {"len" : 21, "data" : "e768c8"}, {"len" : 21, "data" : "e768c8"}, {"len" : 21, "data" : "e768c8"}, {"len" : 21, "data" : "e768c8"}, {"len" : 21, "data" : "e768c8"}, {"len" : 21, "data" : "e768c8"}, {"len" : 21, "data" : "e768c8"}, {"len" : 21, "data" : "e768c8"}, {"len" : 21, "data" : "e768c8"}, {"len" : 21, "data" : "e768c8"}, {"len" : 21, "data" : "e768c8"}, {"len" : 21, "data" : "e768c8"}, {"len" : 21, "data" : "e768c8"}, {"len" : 21, "data" : "e768c8"}, {"len" : 21, "data" : "e768c8"}, {"len" : 21, "data" : "e768c8"}, {"len" : 21, "data" : "e768c8"}, {"len" : 21, "data" : "e768c8"}]}
#decoder n=Byron_BY_Doorbell,m=OOK_PWM,s=500,l=1000,r=3300,g=1200,repeats>=4,bits=21,match={2}0x3
# Kerui alarm system (PIR and door sensors)
#  short is 333 us
#  long is 972 us
#  packet gap 11000 us
#decoder n=Kerui,m=OOK_PWM,s=333,l=972,r=11000,g=1100,bits=25,invert,get={20}:state,get=@20:{4}:event:[10:pir 14:open 7:close 11:tamper 15:battery_low]
# Golden Security GS-WDS07 door and window sensor
#  short is 476 us + 1344 us
#  long is 1364 us + 448 us
#  packet gap 13972 us
#decoder n=gswds07,m=OOK_PWM,s=476,l=1364,r=15000,g=1600,bits>=24,bits<=25,invert
# Generic SCV2260 4-button remote (see rtl_433_tests/tests/generic_remote/01)
#  short is 472 us + 1412 us
#  long is 1428 us + 472 us
#decoder n=generic_remote_01,m=OOK_PWM,s=472,l=1428,r=1800,g=1600,bits=25,invert,match=13cd,get=@16:{8}:event:[192:arm 12:disarm 3:home 48:sos]
# Generic PT2260 PIR (see rtl_433_tests/tests/PT2262/01)
#  short is 440 us + 1536 us
#  long is 1428 us + 548 us
#  packet gap 15348 us
#decoder n=pt2260_pir,m=OOK_PWM,s=440,l=1428,r=16000,g=1700,bits=25,invert,match=755555,countonly
I downloaded this rtl_433.conf file and didn’t know where to put it so just left it unaltered as it is above in the /config folder of HA. Don’t think it was used sitting here. HA is on RPI 3b+ supervised with MOSQUITTO running in HA ( I didn’t have to enter mqtt user name or password, ip address or port. Pressed start on the Rtl_433 addon. I had made no changes to the config
The rtl log seemed to show everything was running.
This new file showed up in /config/rtl_433 folder.
MQTT explorer
MQTT explorer started picking up devices. Anything I want to use I wrote an MQTT entry in configuration.yaml
    - name: " Oil Remaining"
      state_topic: "rtl_433/9b13b3f4-rtl433/devices/Oil-SonicSmart/143430056/depth_cm"
      value_template: "{{ (value |float(0) - 130) | abs }}"
      unit_of_measurement: "cm"
thanks…
I did create the /config/rtl_433.conf file.
I did not get any such file.
However…the system seems working as I pressed refresh
I got some results.
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
s6-rc: info: service legacy-services successfully started
Starting rtl_433 with rtl_433.conf...
[rtl_433] rtl_433 version 21.12-159-g5f76eae6 branch  at 202210212043 inputs file rtl_tcp RTL-SDR
[rtl_433] Use -h for usage help and see https://triq.org/ for documentation.
[rtl_433] Registered 176 out of 223 device decoding protocols [ 1-4 8 11-12 15-17 19-23 25-26 29-36 38-58 63 67-71 73-81 83-87 91-94 96-100 102-105 108-109 111-116 119 121 124-128 130-139 141-149 151-155 157-161 163-167 170-175 177-179 181-185 187-197 199 202 204-215 217-223 ]
[rtl_433] Detached kernel driver
[rtl_433] Found Fitipower FC0013 tuner
[rtl_433] Exact sample rate is: 250000.000414 Hz
[rtl_433] Sample rate set to 250000 S/s.
[rtl_433] Tuner gain set to Auto.
[rtl_433] Tuned to 433.920MHz.
[rtl_433] Allocating 15 zero-copy buffers
[rtl_433] baseband_demod_FM: low pass filter for 250000 Hz at cutoff 25000 Hz, 40.0 us
[rtl_433] _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _
[rtl_433] time      : 2023-02-01 14:23:22
[rtl_433] model     : Nexus-TH     House Code: 173
[rtl_433] Channel   : 3            Battery   : 0             Temperature: -19.10 C     Humidity  : 53 %
[rtl_433] time      : 2023-02-01 14:23:28
[rtl_433] model     : Nexus-TH     House Code: 244
[rtl_433] Channel   : 2            Battery   : 1             Temperature: 10.70 C      Humidity  : 48 %
[rtl_433] time      : 2023-02-01 14:05:49
[rtl_433] model     : Nexus-TH     House Code: 149
[rtl_433] Channel   : 1            Battery   : 1             Temperature: -1.30 C      Humidity  : 86 %
[rtl_433] time      : 2023-02-01 14:06:04
[rtl_433] model     : Nexus-TH     House Code: 12
[rtl_433] Channel   : 1            Battery   : 1             Temperature: -2.50 C      Humidity  : 77 %
Although…not sure if this is needed as same results without this file
This is missing from rtl_433 logs
I have these running…
and
