Yes, that is what I plan to do. Sadly most of the Templates I found didn’t work due to Syntax Changes in HA, but I will get there eventually. I am going to test my current Automation for another day or so and play with some variables like the “Charge from Grid” and “Forcible Charge” options for my Inverter.
How have you found the DETA outdoor plugs? That was what I was looking at installing for my pool pump and heater.
Also with the move the EMHASS did you add any energy monitors to dynamically get the deferable load values or have you found they are pretty static and can just be approximated with a nominal values?
The Deta sockets have been pretty solid. They were a bit of a pain to setup with localtuya but I haven’t been able to find any other outdoor rated sockets. Sometimes the wifi is a little fiddle as the pool equipment is away from the house.
My pool heater is a big three phase heat pump and I was worried about how I could get a big enough relay to switch. In the end the heat pump has a flow switch that turns on and off with a smaller flow pump that could plug into a 10A GPO, I use the other socket for the 10A filter pump.
For the three phase heat pump I use a Shelly 3EM with CT clamps for power monitoring. The 2x 10A sockets report combined power via local tuya. So I can monitor the pumps and heat pump separately and control as two different loads in EMHASS. I set the run hours for the heat pump to the hours of extremely_low (< 5¢/ kWh) prices for the day. I set the filter pump to run for a certain daily energy or a function of the solar pv forecast for the day.
- name: def_total_hours_pool_filter
state: >-
(is_state('automation.p_deferable0_automation', 'on') | int(0)) *
max(
(4 - states('sensor.pool_daily_energy') | int(0) / 1000) | int(0),
(states('sensor.solcast_forecast_today') | float(0) / states('sensor.solcast_peak_forecast_today') | float(0)*1000)
)|int(0)
- name: def_total_hours_pool_heatpump
state: "{{is_state('automation.p_deferable1_automation','on')|int
* max(0,((state_attr('sensor.amber_feed_in_forecast', 'forecasts')|selectattr('descriptor','eq','extremely_low')|list|count)/2)
)|int(0)}}"
Some details on how I have configued the Power Flow Plus Card
type: custom:power-flow-card-plus
entities:
battery:
entity: sensor.apf_battery_entity
state_of_charge: sensor.gateway_battery
invert_state: true
color_icon: true
color_circle: true
display_state: one_way
state_of_charge_unit_white_space: false
color_state_of_charge_value: true
display_zero_tolerance: 100
grid:
entity: sensor.apf_grid_entity
invert_state: true
display_zero_tolerance: 150
color_icon: true
color_circle: true
use_metadata: false
secondary_info:
entity: sensor.solaredge_imported_energy
unit_of_measurement: kWh
icon: ''
color_value: false
unit_white_space: true
display_zero: true
solar:
entity: sensor.apf_generation_entity
display_zero_state: false
color_value: true
color_icon: true
invert_state: false
use_metadata: false
secondary_info:
display_zero: true
entity: sensor.apf_generation_entity_energy_daily
color_value: true
home:
entity: sensor.apf_real_house_load
color_icon: true
color_value: true
secondary_info:
entity: sensor.apf_house_entity_energy_daily
color_value: true
display_zero: true
override_state: false
individual2:
entity: sensor.ev_charging
secondary_info:
entity: sensor.m3p_battery
unit_of_measurement: '%'
color_value: true
template: >-
{{states('sensor.m3p_battery') + '% ' + states('sensor.my_battery')
display_zero: true
color_value: true
color_icon: true
calculate_flow_rate: true
display_zero_tolerance: 50
show_direction: false
inverted_animation: false
icon: mdi:car-2-plus
color:
- 79
- 158
- 79
individual1:
entity: sensor.hvac_power
icon: mdi:hvac
secondary_info:
template: ''
color_value: true
decimals: 0
display_zero: true
entity: sensor.heating_cooling_daily
color_icon: true
color_value: true
color:
- 64
- 121
- 255
display_zero: true
calculate_flow_rate: false
use_metadata: false
display_zero_tolerance: 200
fossil_fuel_percentage:
display_zero: false
color_icon: true
color_value: true
use_metadata: false
clickable_entities: true
display_zero_lines:
mode: hide
transparency: 50
grey_color:
- 189
- 189
- 189
use_new_flow_rate_model: true
w_decimals: 0
kw_decimals: 1
transparency_zero_lines: 0
min_expected_power: 1000
max_expected_power: 10000
max_flow_rate: 10
min_flow_rate: 1
Some details on how I have configured the Sankey Chart Card
height: 200
unit_prefix: M
round: 1
min_box_height: 3
min_box_distance: 5
show_states: true
show_units: true
sections:
- entities:
- type: entity
children:
- sensor.apf_solar2batt_energy_monthly
- sensor.apf_solar2house_energy_monthly
- sensor.apf_solar2grid_energy_monthly
entity_id: sensor.apf_generation_entity_energy_monthly
color: var(--warning-color)
- type: remaining_child_state
children:
- sensor.apf_grid2batt_energy_monthly
- sensor.apf_grid2house_energy_monthly
entity_id: grid
color: var(--error-color)
- entities:
- type: entity
children:
- battery
entity_id: sensor.apf_solar2batt_energy_monthly
- type: entity
children:
- battery
entity_id: sensor.apf_grid2batt_energy_monthly
- type: entity
children:
- sensor.apf_grid_export_energy_monthly
entity_id: sensor.apf_solar2grid_energy_monthly
- type: entity
children:
- sensor.apf_house_entity_energy_monthly
entity_id: sensor.apf_solar2house_energy_monthly
- type: entity
children:
entity_id: sensor.apf_grid2house_energy_monthly
- entities:
- type: remaining_parent_state
children:
- sensor.apf_batt2house_energy_monthly
- sensor.apf_batt2grid_energy_monthly
entity_id: battery
color: var(--success-color)
- entities:
- type: entity
children:
entity_id: sensor.apf_batt2house_energy_monthly
- type: entity
children:
entity_id: sensor.apf_batt2grid_energy_monthly
- entities:
- type: entity
children: []
entity_id: sensor.apf_house_entity_energy_monthly
- entity_id: sensor.apf_grid_export_energy_monthly
type: custom:sankey-chart
show_names: true
wide: true
min_state: 0
energy_date_selection: false
title: Energy - Monthy
