Samba share AND Windows 11 NOT WORKING!
Do you mean the Home Assistant add-on? Are you running Home Assistant OS?
Did it work on Windows 10?
What do you mean with that? A samba share on the Synology NAS can be seen on the windows machine or the Synology NAS can see the samba share on the Pi?
I can see with windows 11 everything in my lan by name or by IP
Synology NAS - Raspeberry with Volumio etc…
But i can’t see HASSIO!
What do you mean with you can’t see it? The device itself or only the samba share?
Btw, the term hassio has been deprecated more than a year ago, it’s calles Home Assistant OS now.
similar issue here with me Samba Share 9.5.1, can’t access samba share on home assistant from windows. HA core-2021.10.6.
my samba add-on configuration.
workgroup: ********
username: ********
password: **********
allow_hosts:
  - 10.0.0.0/8
  - 172.16.0.0/12
  - 192.168.0.0/16
  - fe80::/10
veto_files:
  - ._*
  - .DS_Store
  - Thumbs.db
  - icon?
  - .Trashes
compatibility_mode: true
interface: ''
I do see it under Networks but can’t connect
If I try to connect , it fails.
Samba share add-on log
INTERNAL ERROR: Signal 11: Segmentation fault in pid 564 (4.13.8)
If you are running a recent Samba version, and if you think this problem is not yet fixed in the latest versions, please consider reporting this bug, see https://wiki.samba.org/index.php/Bug_Reporting
PANIC (pid 564): Signal 11: Segmentation fault in 4.13.8
unable to produce a stack trace on this platform
coredump is handled by helper binary specified at /proc/sys/kernel/core_pattern
Registered MSG_REQ_POOL_USAGE
check_ntlm_password:  Authentication for user [********] -> [******] FAILED with error NT_STATUS_NO_SUCH_USER, authoritative=1
here this mite point down the right path
Map a network drive with your HA samba credentials.
Did it work under windows 10 with the same settings?
yes but don’t work form me!
yes in windows 10 works
? more details?
File explorer → map network drive → \\ip.of.HA\config → checkbox ’ log in as other user’ enter user and password as defined in HA samba setup
no! ip or name not accepted
my understanding is if the SMB sharingSupport is turn ON then the problem must be in host SMB not turn on or working correctly
i don’t know SMB work with the other device only fail with home assistant OS
sudo sudo sudo :wink: Thank You very much, but i don’t have a linux machine at the moment available, i could install but ufff i prefere if possible a more easy solution! Thank You anyway!
The first part in this manual is for Windows 11, the second part is for Linux. You don’t need sudo or a linux machine for these instructions.
Try solid explorer app on android. It is working for me on Android to home-assistant.
Already tried that, same result.
