I’ve got this installed on my Galaxy Watch and I’m presuming the token input refers to a long live access token? Anyone know if it is possible to copy and paste on a Galaxy Watch as I don’t fancy typing it?
Steps seems to be a bit complicated and I am not sure if I see the right things. Is there a instruction video? Like benm said. Typing a token is a bit annoying.
Alright… got a few steps further… apparently you need to read very carefully but still I am getting stuck at some point.
To start of… I needed to remove the app again and reinstall it. On the first opening I am getting an url I have to type in a browser. (It is every time hidden behind the “OK” button and therefore easy to dismiss).
But every time I fill in the server url and token and hit “send” I get an error with “Not Found”.
Not sure what I am doing wrong. Already tried with the watch screen set “always on”. But it did not make any difference.
The sockets are timing out before you click send. Its something i’m actively working on but for now you need to be really fast. Have your url and token in a notepad ready to copy and paste as quickly as possible
Yes, it doesn’t like my certificate, but it was just a single message, so I don’t really mind about it.
Not working lights section is much more important (all other sections work flawlessly)
Yeah I can imagine thats annoying. Do you have any non alphanumeric (a-z, 0-9) characters in your light names? Something must be blowing it up but its hard to debug without your specific setup
I use several non alphanumeric characters (space, (, ), ó), but they are also used in scripts and covers which are displayed correctly, so I don’t think the issue is here…
That’s very weird, I thought the problem might be with lights that are unavailable, but I have checked and the issue is somewhere else.
What lights do you have? I have:
no not working… I have many types of lights… The light button on the watch is just not responsive, but when I use bezel to select switches that does work
But the other question - is it possible to show only certain entities on watch? I want to exclude many entities from being showed and control only most importnt ones.
I have installed this app on my frontier and neither the lights or the switches are doing anything. Covers opens even though there is nothing in there, but lights and switches won’t even open.
Scripts and groups look to have picked everything up fine.
