I second the question about if this is working still. Seems great but I haver the same issue as @Recneps
does this work on a Galaxy watch?
it is similar to Frontier
So is this a dead app now? Kind of disappointing⊠I just found out about it! Looked nice though. Thanks for the work you put into it.
I can confirm that works perfectly on Samsung Galaxy watch SM-R800.
is there any chance that we will get app for Samsung smart TV with Tizen OS?
I have a Samsung Galaxy Watch and have installed the app for HA. I have filled in the âHA urlâ and the password, but you cannot enter a user ID? If not, how do you create a connection to my HA that can be logged in without a user ID?
For everyone thinking this appâs dead, itâs not. It does need to be updated soon, but I canât help with that sadly.
You need to set an API password to be able to connect with your watch (since Home Assistant only by default supports logins with username and passwords). This is my config:
homeassistant:
auth_providers:
- type: homeassistant
- type: legacy_api_password
api_password: fancyAPIpassword
Find more information here. Do note that an API password can potentially reduce your HASS systemâs security (since you no longer need a username), so make sure to use a fancy password.
Iâve used this to connect with my Galaxy Watch, and the appâs working perfectly fine! Thanks so much Jerrod
I put the correct URL and password, and after I receive an error
status code 401
message an unknown error has occured
Well, I forked sclubâs modified version to work with Longlive Token instead of password and it works fine, and now Iâm maintaining it -> https://github.com/mybabysexy/HAGearS3NG
Where can I download it?
How does one go about installing the forked version of the UI on a Samsung (Galaxy) Watch? The original version was installed by the UI for Home Assistant
app in the Galaxy Store. None of the forked âNGâ version explain how to get the new version onto the watch.
I also want to know how to install the fork version?
Thank You!
I installed it for the watch but unfortunately it doesnât work. The cl1p link does not work. âNo valid token found for xyâ
Whatâs the problem?
Thanks for the help!
im using my instance https://mydns:org:8123
should I use the port? if I donât use it it does not work, if I use it i got the error 403 âForbiddenâ but the token its correct
I am updating the official app on the app store to work with my own credential sharing website, its currently in review in the app store. Stand by
Its in the app store guys, just pushed an update that hopefully solves some issues. If you have trouble loading your url or if you load it and then after you submit it says âNot Foundâ please try disconnecting your watch from your phone and using the wifi on your watch.
The websockets donât seem particularly long lived, i may rewrite the server implementation here pretty soon
Is this update only for s2 and s3 or also for the gear sport? I only see version 1.0.1 in the store. Last update is 21-12-2017
weird, maybe try restarting the app? the latest version is 1.0.2, although 1.0.1 will probably still work as well
Oh now it is there⊠had to update the galaxy store⊠updating right now
