Script to send actions to the right Google Home (based on voice commands)
Background
I first started to create a script to send actions to a Google Home and resume the stream (TuneIn / Spotify) which was playing afterwards. It also restores the volume, and you can work with Google Home speakers groups.
In my home I have several Google Nest/Home speakers, and I had some scripts where a TTS would be sent which was triggered by a Google Home routine. However, I could only set it to a predefined Google Home speaker, and not to the specific speaker on which I gave the voice command.
This made me thinking, and I found a solution for this, using the ambient sounds which you can start in your routines.
So I made a new script, which can be used in cooperation with the other script, to send a TTS or other actions, like e.g. an image, or a cast of your Lovelace dashboard to specific Google Home after you ask a question to it.
As of version 2022.12 this script is included into the total Google Home Resume package
Latest changes
2022.12 Happy Holidays; letā€™s bring the family together
:red_circle: BREAKING
  • Integrated into the Google Home Resume package, update according to the instructions
:star2: Improvements
  • Template improvements
  • More use of YAML anchors
Older changes can be found here
How to install and use the package
As of version 2022.12 the instructions how to install the package are moved to my GitHub repository, so it is easier for me to keep them up to date.
Buy me a coffee
If you like this script, please feel free to buy me a coffee (I might spend it on another beverage though).
In case you decide to do so, thanks a lot!
Buy Me A Coffee
Excellent stuff, something thatā€™s bugged me forever. So, am I right in saying, these scripts, use the ā€˜trailingā€™ playing of ambient sounds for us uniquely identify the speaker in that state and therefore direct the TTS back to it?
Wow, using the ambient sound to check which speaker was talked to, is a great idea! Cumbersome to integrate but very interesting!
Hi, just wanted to say this is a brilliant idea - specifically, passing the TTS to the right Google Home
Unfortunately I am have an issue with this. Iā€™ve gone through the debug and the issue seems to be that I am not passing a tts_volume (I would like the TTS volume to be whatever the media_player. is set to).
This is the error I am getting, which is generated on this part of the code:
Stopped because an error was encountered at January 2, 2022, 15:08:20 (runtime: 0.04 seconds)
Error rendering data template: TypeError: ā€˜<ā€™ not supported between instances of ā€˜strā€™ and ā€˜intā€™
alias: Apply TTS volume
service: media_player.volume_set
  entity_id: '{{ tts_target_list }}'
  volume_level: '{{ tts_volume if tts_volume < 1 else tts_volume / 100 }}'
According to the debug, the tts_volume is being set as:
tts_volume: ā€˜ā€™
The media player volume is being picked as
volume_old_not_playing:
  - entity_id: media_player.living_room_speaker
    volume_level: 0.05
screen_not_playing: []
I think the TTS is set correctly as per the example. But looks like it is being taken as a string where it defaults to undefined?
    - alias: "TTS"
      service: script.google_home_say
        voice_tts_target: "{{ tts_target }}"
        tts_message: "{{ tts_message }}"
        tts_volume: "{{ tts_volume if tts_volume is defined else undefined }}"
Really out of my depth here - not sure whats causing the error nor how to fix it.
Thank you in advance.
Kudos for this idea. I have wanted to do that quite some time.
Does this also work with your new script, or do I need to use the one stated in the first post?
It also works, but then you need to change the google_home_say_voice as well.
Here is the updated version.
I will change the post accordingly somewhere in the near future.
Iā€™ve update the first post so it explains how it works with the new script (and amended the script to work with other actions besides TTS)
Update
Version 1.0.0 - 9 February 2022
:sparkles: New feature
  • Now the new script is used, other actions besides TTS are supported
  • Added version number as a variable to the sequence. This will make it more easy to see which changes there are since you last updated the script
  • Several improvements in the templates
  • Update of the first post of this forum topic
Update
Version 1.1.0 - 10 February 2022
  • No need to define speaker_groups anymore, as I found a way to define them using a template.
Update
Version 1.2.0 - 13 February 2022
  • Made several changes in how data is sent from this script to the Google Home Resume script. So if you update this script, make sure to also update the other one. However, as of this version, it is also possible to use this script without the Google Home Resume script
  • It is now possible to use target_conversion. This means you can give your voice command, and perform your actions on another target eg the speaker group the target belongs to.
  • By setting the use_resume variable to false you can send the actions without using the Google Home Resume script. This can be used if you for example want to start a radio stream which is not in TuneIn, and do not want to resume other streams in case that one is stopped.
  • The target determined by the ambient sound will only be used in case you omit the target in your service call. If you provide it, that target will be used. This can be useful if you also want to provide other actions, for example setting the state of an input_boolean.
  • In case you donā€™t have the need to use the Google Home Script at all, you can set use_resume: false in the variables of the Google Home Voice script, and it will just send the actions.
  • Information is shared with the Google Home Resume script in a better way. This was also needed because now multiple targets or groups as target are possible, where in the old version there was always only one target.
  • Information on for the ytube_music_player integration is now also shared.
Sorry for all the updates :slight_smile:
Update
Version 1.2.1 - 14 February 2022 :heart_decoration:
:bug: Bug fixes
  • Fix for resuming ytube_music_player after voice command
UPDATE
Version 1.3.0 - 25 February 2022
  • Changes in the way data is shared with the Google Home Resume script. So if you update this script, make sure to also update the other one. However, as of this version, it is also possible to use this script without the Google Home Resume script
  • The ytube music player integration will now resume at the right position in the track
Update
Version 1.3.1 - 14 March 2022
  • Do not store unnecessary data of non playing devices
:receipt: Documentation
  • Created seperate file for older changes
Update
Version 1.3.2 - 21 March 2022
  • No need to for the variable primary_spotcast anymore, this will be handled by the Google Home Resume script
  • Only data of playing Spotify entities will be stored (other non playing entities were already excluded in 1.3.1)
Update
Version 1.3.3/1.3.4 - 22 March 2022
  • Added a update of Spotify entities before data is stored, so the most recent data is used
  • Only relevant data of entities is stored (depending on state and playing app)
:bug: Bug fixes
  • (1.3.4) Template fix
Update
Version 1.3.5 - 2 April 2022
  • Ambient sound will now be stopped after the data from the media_player is stored
Update
Version 1.3.6 - 8 April 2022
:sparkles: New features
  • Support for extra variables in service calls added. This is a new feature of the Google Home Resume script. Version 2.0.0 or higher of the Google Home Resume script is required for this. For more information see here
Hello!
Iā€™m really thankfull for your work, but I havenā€™t been able to modify all the settings of both script to make them work; seems that there are a lot of scripts inside, with radios and all, lots of diferrent entities that I donā€™t have, and I really donā€™t want that. All that I really wanted was to know the entity_id of the media_player that was used to call a script, is there any way to simplify this, without thinking in youtube / spotify or any other integration for that matter? I thisnk that would be very usefull, for a lot of people, on itā€™s own.
For instance, I have this list of media_players, and is possible to know the ā€œlast_changedā€, but that doesnā€™t quite work as expected:
{% set colunas = ['media_player.coluna_da_sala', 'media_player.coluna_da_cozinha', 'media_player.coluna_da_cave'] %}
{{ expand(colunas) | sort(attribute='last_changed', reverse=true) | map(attribute='entity_id') | first }}
Is there something that I could do before just to get the correct media_player ?
Thanks in advance!
The script is intended to actually send an action to the right Google Home.
The Google Home Resume script is not required, you can use this script without the Google Home Resume script if you use: use_resume: false
I donā€™t know what you actually mean with your template example, because it doesnā€™t seem related to starting an action by voice on your Google Home, and knowing which one you asked it to in Home Assistant.
What your template does is determine which media_player was changed last, which of course could be because of the question asked, but also because someone changed the volume or whatever. So that might be the reason why it doesnā€™t work as expected.
I know you are right, and Iā€™m thankfull for your approach. I will try to make both scripts work, but mainly understand the sequence to send the white noise and get the media_player from there. Thatā€™s mainly what I want.
I managed to replicate the white noise and possibly get the player, but as it goes last in the sequence in Google Home app it has to wait for it to be identified, as I understand. Donā€™t know any better aproach, so I will try to addapt your scrits to my entities. Thanks again.
