πŸ’‘ Sensor Light - Motion Sensor - Door Sensor - Sun Elevation - LUX Value - Scenes - Time - Light Control - Device Tracker - Night Lights
@lucascoco
I will go through the options I suggested again.
  1. If you have a humidity sensor like in your fist post you said you had one then use a template sensor so when it is above above 60% (your request) then the by-pass turns ON or better option would be to use it to toggle to night lights with state condition and use a 10 min delay (your request for 10 min). That is if your not using night lights in the automation.
  2. If you get yourself a door contact sensor then use :honeybee: Bee In The Hive Sensor :honeybee: template sensor.
  3. If you have a humidity sensor and something to control the fan then use my :shower: Bathroom Humidity Exhaust Fan blueprint.
The best option would be 3 then the 2nd best would be 2 then 1 but they will all work.
Blacky :smiley:
