Your welcome, I am glad you like it . Also thank you for asking the questions and for your suggestion.
This is in or FAQ. If you would like to enter 1000 or any other number the slider is not allowing then just simply type the number you would like in and click save .
This is also in or FAQ. I wouldnāt add the new āsensor groupā but you can add a āBinary sensor groupā. The FAQ is below, follow the steps in the link and it will walk you through it.
Q: I have more than one trigger sensor / binary sensor and my light will come ON then it will turn OFF and stay OFF? - or - The automation is not working correctly with 2 or more trigger sensor / binary sensor and is driving you crazy?
Thanks for your suggestion . I have this on my list to do as I would also like to have it linked with my Bathroom Humidity Exhaust Fan blueprint (both blueprints work together). I will try and get this out in the next release soon.
