Your lighting experience, your way β take control and customize it to perfection! ![]()
In this update, we focused exclusively on dynamic lighting bugs. Below are the changes we have made. Hope you like it ![]()
DYNAMIC LIGHTING UPDATE
New Input Option
- Dynamic Lighting - Toggle Helper: If you have chosen a brightness level of 0%, then itβs essential to create an independent toggle helper and enter into dynamic lighting. This toggle helper can also address issues if the automation doesnβt behave as expected due to the occasional unavailability of light entities. While it may not always be necessary, if youβre open to creating toggle helpers, itβs highly recommended to utilize this option to ensure proper functionality of the automation.
Bugs Fixed
- Fixed bugs in option 8.
- Fixed bugs when using options 1, 2, 4, 5, 6, 7 or 8 and setting a brightness level of 0%. Dynamic lighting would stop and not come back ON. There is now a new toggle helper that is required when setting a a brightness level of 0%.
If you like this blueprint? Consider hitting the
button in the top post ![]()
If you like my blueprints, and would like to show your support or just say thank you? Click Here ![]()
Enjoy
Blacky ![]()
