Love it ![]()
If you are not sure what version you came from if it is not to much trouble I would recommend a clean install of your automations. This way it will clean up any existing YAML configerations that may cause problems.
In the FAQ under " UPDATES OF BLUEPRINT" it will list all the things that were needed to be done. But again if it has been a wile sometimes it is easer to just redo the automations ![]()
Yes this can be done, but I respect you would like to tinker and try and work it out. In any case if you run into troubles just post a message and I will be happy to help. There is one thing I will say, if you haven’t checked out my
Bathroom Humidity Exhaust Fan then it is realy worth a look. There are 2 blueprints I realy like, this one and the Bathroom Humidity Exhaust Fan blueprint. I think they are a must have, and spoiler alert I am working on the Bathroom Humidity Exhaust Fan blueprint now.
Blacky ![]()
