Thanks for your suggestion âMore Than One By-passâ. I will add it to the list.
For now you could and âentitiesâ card to your dashboard with a top toggle and name. This will turn ON and OFF any entities in the card. You could have one for downstairs, guest, upstairs, all light automations, all automations. It will be easy to manage then.
You could also use areas but name them how you like example area name âLight Automations Downstairs - By-passâ Then put all your by-passes in that area and you can turn on and off areas in automations.
Thanks, everything is working again. I am not sure what version I upgraded from, but I changed all the previously working ones from âdeviceâ to âentityâ and everything is working as expected again.
This is my go-to blueprint by far!
My next attempt will be trying to use a humidity sensor (set as a binary sensor helper) to leverage as my âbypassâ device. (Am not asking for assistance, as I prefer to tinker and figure it out on my own first). But too often my wife yells at me when sheâs in the shower and the lights go off on her.
Thanks again! And another ask to add to your list⌠Would be great to be able to use a template value for brighness + color. This would make this blueprint work better with âAdaptive Lightingâ integration on HACS.
If you are not sure what version you came from if it is not to much trouble I would recommend a clean install of your automations. This way it will clean up any existing YAML configerations that may cause problems.
In the FAQ under " UPDATES OF BLUEPRINT" it will list all the things that were needed to be done. But again if it has been a wile sometimes it is easer to just redo the automations
Yes this can be done, but I respect you would like to tinker and try and work it out. In any case if you run into troubles just post a message and I will be happy to help. There is one thing I will say, if you havenât checked out my Bathroom Humidity Exhaust Fan then it is realy worth a look. There are 2 blueprints I realy like, this one and the Bathroom Humidity Exhaust Fan blueprint. I think they are a must have, and spoiler alert I am working on the Bathroom Humidity Exhaust Fan blueprint now.
I donât use Adaptive Lighting, but I know a lot of companyâs are including it, like Apple, Philips, etc. I think they do all the hard work and all you need to do is to turn the light ON and it will adjust as required. Maybe I should look into it further to get a better understanding.
. Youâre correct about how adaptive lighting works. The reason being able to use a template in your blueprint for brightness/color etc, is that currently, the light will turn on with defaults and then adaptive lighting will adjust it. That adjustment is noticeable. If I can use the adaptive lighting desired brightness, color etc, then your blueprint can turn it with the desired parameters and avoid the immediate adjustment by Adaptive Lighting.
This looks like it may be an âadaptive lightingâ or the lights your using bug, issue or setting. When you donât choose any lighting control options in this blueprint, the light will just simply turn ON with no lighting data input .
Not sure of the lights your using or if there is a setting in âadaptive lightingâ but maybe there is a setting that is âRestore previous light setting when turned OFFâ that you can untick. A lot of lighting controls sometimes have an option like this. This way the light will get new data every time the light tuns ON . Maybe have a look around for this.
Hey Blacky. The behavior youâre describing is exactly the current behavior. However, itâs not the desired behavior When the blueprint turns on the lights it has two options (no lighting data input or static lighting data input). (Excluding the night mode). However, the desired result is to turn lights on with dynamic lighting data provided by another entity. For example, at 5pm, the temp may be 3000K, at 6pm it may be 2900K and at 7pm it may be 2800K. So the desired result is for the blueprint to be able to pass in a variable value for lighting data. Does that make sense?
I use Blackyâs blueprint and the same HACS adaptive lighting. It works just fine for me, except that the adaptive lighting settings kick in about 1 second after the lights turn on. So if itâs late at night, for example, lights will come on full brightness then a second later adaptive lighting kicks in and changes the color and brightness. Not completely seamless, but it hasnât bothered me.
Yes, agreed, they are compatible. I use both as well, but Iâm of the mindset that adaptive brightness is great not just for adjusting over time but making it so seamless that you donât really notice the lights adjusting in the first place.
is anyone able to show best practice for use of âAdaptive Lightingâ. I meant to ask the question a few days ago, and feel it would be good to see how people have set it up. Screen shots: ok.
Hi all, I thought I would respond to all of you in the one post as it is on the same topic .
I did see your post a few day ago asking the same question but because I dont use it and it is about âAdaptive Lightingâ and not this blueprint it would be best asked in âAdaptive Lightingâ forum or create another topic on how do I use âAdaptive Lightingâ.
If you are asking how to use it in this blueprint then we will go through it below but I could be wrong as I donât use it.
I agree 100%. This is why I was leaning you to have a look around in your light or the âAdaptive Lightingâ settings as there may be something.
Depending on your selection in lighting control. It will either pass light data to a light entity or not. If nothing is selected then no light data will be passed, if you select something then that data will be passed. This is for normal light and night lights as you have âUse The Light Control Optionsâ and âNight Lights - Use The Light Control Optionsâ.
Adaptive Lighting
Because I dont use âAdaptive Lightingâ, I may be wrong (wont be the first time nor the last) but this is how I read the âAdaptive Lightingâ documentation.
Once you have installed âAdaptive Lightingâ in HACS you then have to create an instance for every light or light group you would like Adaptive Lighting for.
To do this you will need to go into device & services / add integration / search for âAdaptive Lightingâ / then enter in a name you would like for this instance ( example: âKitchen Lightsâ) / submit & finish. You will then have an âAdaptive Lightingâ instance called âKitchen Lightsâ . If you would then like another instance you would just do it again⌠it could be for âFamily Room Lightâ etc.
In each instance you create it will have 4 entities that you can use in this automation. The entities are âswitchâ domain not a âlightâ domain so everything we talk about 'light" domains above will do nothing as in this blueprint the domains are separated and you will never send data to a âswitchâ, so effectively you could use separate light entities with light control and control the lights and then enter the âAdaptive Lightingâ instance switch entity, and have âAdaptive Lightingâ control the lights enter in that instance. But if you do this you canât use the same light entity in the automation and in the âAdaptive Lightingâ instance.
The 4 switches that each âAdaptive Lightingâ instance creates are;
Switch for brightness
Switch colour â colour temp
Switch for sleep mode
Switch for adaptive lighting - (This switch entity is the one I think you would use in this automation if not then you may have to use the switch for brightness and or switch for colour. Maybe the sleep mode could be use in night lights but not 100% sure. This could be a switch to enable (turn ON) / disable (turn OFF) the âAdaptive Lightingâ instance)
In the instance âKitchen Lightsâ there is a configure selection. If you click on it, this is where you select what light entity you would like to use in the instance and all the settings you would like to use. This is then applied to the 4 switches âAdaptive Lightingâ instance creates.
Once you have set all this up you will then enter the switch âAdaptive Lightingâ instance creates something like Adaptive Lighting ??? in our case âAdaptive Lighting Kitchen Lightsâ into âLights - Switches - Scenesâ and or âNight Lightsâ. But read above as the switch entities could be âSwitch for Brightnessâ if you would like to use brightness and or âSwitch for colourâ if you would like to control colour. The switch for adaptive lighting could be a switch to enable (turn ON) / disable (turn OFF) the âAdaptive Lightingâ instance. You will just have to try it and see by turning them ON and OFF. You may need to add 2 or 3 switches depending on what you would like to control (brightness / colour / sleep mode).
NOTE: I could be 100% wrong about all the above âAdaptive Lightingâ as again I donât use it. This is just my understanding of what I have read.
If I am correct then adding a âAdaptive Lightingâ switch entity into this blueprint will not control anything about the light entity you selected in the instance. It will just simply turn the switch entity ON and OFF. The brightness, temp, and colour will all be done through âAdaptive Lightingâ not this blueprint.
Again maybe I am 100% wrong.
Good input yes your correct.
Please note this is not the blueprint, it will have to do with your lights or what your using to connect it into HA.
Example: At night in my automation I have 5 lights come ON when someone goes to the bathroom.
1 in the toilet
3 in the hall
1 in the bathroom.
The bathroom is an LED strip controlled by ESP32 & WLED. The other lights are controlled via Shelly dimmers. When a motion sensor is triggered the bathroom lights come on first (ESP32 LEDâs) then followed by the other lights in about 1 second after the ESP32 LED Strip. The blueprint automation turned all of them on at the same exact time but the Shelly is slower to react than the ESP32. So you can see it is not the blueprint nor does the blueprint turn it ON at 100% then 5% it just sends light data at 5%. What you are probably seeing is within what you are using. Maybe have a look around in the settings of your lights. If you can set the default to 10% that way it will always run smoothly to the eyes.
Below is a Shelly setting. I donât use it but you can see not all lights are equal. The Shelly dimmers just uses the setting it was on when it was turned OFF as the default for then next time it is turned ON. So the first one for the night you have bright 100% then the automation setting 5% and you can see this, but then every time after that it just goes to 5%. So it is within the Shelly dimmer not the blueprint. I am good with that.
Thanks Andy . If I am correct about âAdaptive Lightingâ , adding switch domain to the automation then having a transition time will do nothing as this data only gets passed to a light domain.
Conclusion
I hope I am not sending you all down the wrong path an I probably should of kept my thought to myself. Maybe one day I should install âAdaptive Lightingâ. Most of my light just come on at night and I am happy with the light control options.
Hey there! I am in awe of the constant improvements to this blueprint, thank you so much for your efforts!
A bit of behaviour Iâve noticed that I wonder if thereâs a workaround: I have a milimeter wave sensor in our open living room controlling the zigbee group of all the lights in there. Iâm using v4.2 of the blueprint, and I also added the lux sensitivity option so the lights donât turn on if itâs really bright already.
However as the room is very often occupied, what often happens is if when someone enters the room when itâs really bright, the automation will trigger then exit due to the lux level check without turning on the lights.
But from that point on, unless the motion sensor state becomes unoccupied (which sometimes wonât be be for hours as itâs a large open living space), the automation will never trigger again even if the light level falls below the preset point.
Is there a way to get the blueprint to behave differently and always trigger if the lux level falls below the preset level if the room is still occupied?
I had another user just experience this. What they did was to update to V4.4 I think with a clean install and recreated the automation again and this fixed the problem. I should work in V4.2 so you could try to just delete that automation and recreate it.
If you would like me to look at your automation then could you please provide us your YAML of the automation? This YAML code are the settings you have selected in the automation so I can help. To do this go into your automation, top right 3 dots, Edit in YAML, copy all the code, come back to the forum and in your reply at the top tool bar click on â</>â and paste code in there.
What the automation should do when Ambient is enabled.
If the Lux is below your setting when the trigger is triggered it will turn the lights ON. If the Lux is above your setting when the trigger is triggered it will not turn the lights ON. This is with any setting when enabled.
If you setting is as shown below then if the trigger is ON (occupied) and the LUX is above your setting then the lights will not come ON. If the trigger stays ON (occupied) and the LUX crosses over from above your setting to below your setting then the lights will come ON. If the trigger stays ON (occupied) and the LUX crosses over from below your setting to above your setting then the lights will go OFF.
If you setting is as shown below then if the trigger is ON (occupied) and the LUX is above your setting then the lights will not come ON. If the trigger stays ON (occupied) and the LUX crosses over from above your setting to below your setting then the lights will come ON. If the trigger stays ON (occupied) and the LUX crosses over from below your setting to above your setting then the lights will stay ON. When your lights turn OFF the LUX value will be considered again.
Hey Blacky, thanks for your detailed help! I upgraded to 4.4 and switched to the âNOâ option for the sensor/light interaction and itâs now working as expected.
The only feedback I could give is it would be nice if there was some sort of smoothing or averaging applied to the lux level. At the moment the lights switch on and off very frequently if a particularly thick cloud goes overhead (we have a lot of roof windows so the light levels in the room change quite dramatically with weather), ideally it would wait some user-defined amount of time to see if the light level has fallen below the set point and STAYED below?
The âTime Delayâ could be what you are looking for. When the light level has risen, then the time delay starts, if the LUX goes below your level before the time delay turn your lights OFF then it will reset again. Maybe try extending your time delay for now.
I will look into add a delay for the LUX sensor. Another user has suggested this in the past and I can see it would be nice just to delay the LUX OFF and not use the âTime Delayâ for this. I will put this onto the list.
