You need to have a switch that has an ON and OFF state. Most buttons do not. I have 2 blueprints that you can use with your aqara zigbee mini button. First you will need to create a toggle helper and use that in the by-pass. On how to do that Click Here . Then depending on your aqara zigbee mini button (how it reports state when you push it) use my
Press Button - Turn ON & OFF Entities blueprint if it has no state or if it has a quick ON/OFF state use my
Toggle Switch - Turn ON & OFF Entities blueprint. You will then enter in your aqara zigbee mini button in and then in “Main Entity” enter in your toggle helper.
Hope this helps.
Blacky ![]()
