I am confused on how to use this Blueprint.
I need to include three sensors but the blueprint has only one line to enter the sensor.
I have a large room with three motion and presence sensors to cover the entire area. I need any one of them to turn the lights for the whole room on and lights stay on until none of the sensors detect presence.
Can you advise me?
Thanks!
I am wanting to add another condition (without requiring use of additional user-operated bypass switches).The requirement is quite simply to have the automation NOT trigger if the light is already on.
Initially I thought I could set up an ON script which toggles the light but I cannot select an OFF script (it is device or scene only, even though it is labelled as āScenes - Scripts To Turn OFFā).
I could leave this blank and perhaps write another automation that turns the light off automatically after āxā minutes when a helper switch is triggered but that seems like perhaps I am overcomplicating the issue perhaps?
Alternatively, could I edit the YAML to include another simple condition?
Awesome, thanks. Iāve updated to 5.8.
OFF scene now selectable which means I donāt need to implement any helper toggles.
ON script simply checks if light is already ON and stops if so (otherwise turns light on).
OFF script turns light off.
I now have a motion activated light that wonāt turn itself off if it has already been commanded on by the switch
I realize the caveat of this is that I likely miss out on some of the dynamic lighting options/transitions since I am pointing the automation at a scene rather than device/entity.
Surely this check would be worth building into the template as an option?
I really love the Dynamic Lighting feature, but was wondering if thereās a way to bypass it after sunset? I know we can set it to run between set times, but i live in a place where, depending on the season, it gets dark (or stays light) at wildly different times.
As i mentioned a bit above, iām trying to figure out a way to have only certain lights in my living room dim in the evening when there is no presence near them, but the Dynamic Lighting then triggers them on again.
Sorry for the late respons. My notifications were not on.
But here is the code.
So even when the Lux is above the value the Ledkoof comes on when there is movement.
Not sure as sensor 5 has to be off for 5 minā¦ maybe that is the trigger and if the script runs this may already be done. The sensor 1 could be the sameā¦ same but different to turn on lightsā¦ you will just have to try and see then adjust if not right.
EDIT: I see you have more postsā¦
yesā¦ I thought that may be the case but was not sure. You will need to set your conditions up correctly to your liking.
Yep, use night lights and the sun condition. Dynamic Lighting feature is not used in night lights. Maybe try this way.
I has a quick look at HA YouTube on CarPlay. It looks like it has the app so you can control your garage door or anything in HA. So if you would like to turn the light ON you could just use the switch. Maybe you can give me a step guide so I can understand more of what you are trying to achieve.
I answer may be wrong so sorry if that is the case. Just let me know if I got it wrong.
If the trigger is ON ( mmWave sensors) and your LUX drops from above to below this will trigger the automation and the light will come ON. If it goes from low to high it will trigger the lights OFF. The key is the mmWave sensors must be ON. If you have 2 triggers like a PIR and a mmWave sensors then you will need to group them together.
For this you are best to do a custom automation. The flow should look like this.
When motion goes from ON to OFF for 5min then turn light OFF.
So like this
Create new automation When = state / select your motion sensor / from = detected / to = clear / for = 5 min And if = state / select your light or switch (mirror lights) / state = ON Then do = light turn off / select your lightā¦ it could be switch turn off just depends what you have.
It is a lot to take in at first and I fully understand this can be the case.
As you enter in a sensor another input will pop up allowing you to add another one. BUT!!! I would strongly recommend you group your sensors and just add the group as it will work a lot better for you.
For more information on how to set up group sensors please Click Here.
100% use the group link provided above and it will walk your through the How To Do It.
Dynamic lighting only works for a light entity not a scene or a script. Have a look at the FAQ on dynamic lighting, hopefully it will explain everything for you.
Some work is happening on scenes and scrips now but dynamic lighting will still need to be a light entity.
