I just upgraded to hassio v108,2 and regardless which of my many frontend themes I chose, my sidebar background color is always white. Given that most of my themes I use have a dark background with light text color, it has now become impossible to see any of the options on the side bar. I have search all over for what attribute I need to specify within any of my themes that applies specifically to the sidebar back/frontground color but cant seem to find anything that works. The default theme I use is below. What do I need to change or add so I can once again see the options on the side bar??
I tried the above example you linked both under hassio and hassbian v108.2 and had the same results. All the colors changed except the sidebar which remained white.
I booted up my backup hassio v108.1 and the tried these themes. Worked like a charm albeit one ugly looking theme
Obviously use your own colors. I have found if you donāt also set the sidebar-selected background color especially if youāre switching between themes the previous color sticks in places even though the rest of the sidebar changes.
Updated a few hours ago, I have the Chrome app and Ariela installed, no issues with different themes.
Same thing on a different device from which I have never used to access HomeAssistant.
Probably same issue as HACS, for me it kept working normally but other people reported a broken HACS or itās components not working anymore.
Edit - should add, this is 108.3 - I think I skipped 108.2, and possibly 108.1 but I canāt remember - was working before I just pressed update though, and now itās like that and adding the line @blackvrs suggested to my ādarkā themes, reloading and clearing the cache didnāt change anything.
theres a same proble when we go in cofigure/entiites or configure/devices.
custom themes show white color as side-bar was showing.
please anybody here who can guide.
thanks in adv.
