Yes! Thatād be the perfect card: use the layout of slider-entity-row with a mushroom style slider like this:
Anyone know how I can change
paper-slider-container-color: ārgba(1,1,1,.2)ā using style: | ???
Ive tried this
- type: horizontal-stack
cards:
- type: custom:slider-entity-row
entity: input_number.mixer
full_row: true
hide_state: true
min: -5000
max: 5000
grow: true
style: |
slider-entity-row:
ha-slider:
paper-progress:
#progressContainer {background-color: rgba(100, 0, 0, 1)}
Ive searched the DOM and cant find the reference for it and I dont want to nest it in an entities card.
I can change it in the theme and it works fine without the need for card-mod but I have a few of them and this one in particular is a slider that does hot and cold water mixing.
Is there a way to have a faster value update of the slider ?
(I have a velux screen. When I push the icon, I can only see the position of the slider when it is finished āslidingā)
Not exactly.
When you finish āslidingā - the defined value is actually assigned to a corresponding entity.
This is how THIS particular slider works.
Other slider-like controls may assign values WHILE you are moving a slider.
Ok. Thanks
EDIT 20231106: As of 2023.11, this example no longer works. The updated example can be found here.
Recently, I wanted to change the colors of the slider. A regular slider cardās color were pretty easy to modify with card mod, but slider-entity-row as a little bit different. Ultimately, this is what I came up with.
Note: The colors will not update while editing. The changes wonāt take affect until you click Save.
YAML code (outdated)
type: entities
entities:
entity: light.hallway
full_row: true
toggle: false
hide_state: true
step: 10
- entity: light.hallway
toggle: true
step: 10
style:
slider-entity-row:
ha-slider:
'#sliderKnob.slider-knob': |
.slider-knob-inner {border: 1px solid white}
.slider-knob-inner {background-color: white}
paper-progress:
#progressContainer {background-color: blue}
#primaryProgress{background-color: red}
ha-entity-toggle:
ha-switch {
--switch-unchecked-button-color: red;
--switch-checked-button-color: green;
--switch-unchecked-track-color: red;
--switch-checked-track-color: green;
UPDATE 20230815: At some point, something must have changed because the sliderKnob would not show the color I defined. I had to change from '#sliderKnob': | to '#sliderKnob.slider-knob': |
I took elements from the following posts to help me with the process:
@maskazzās post where he completely redesigned the slider. š¹ slider-entity-row - Add sliders to entities cards - #203 by maskazz
@Ildar_Gabdullinās post in card mod thread for coloring the toggle button š¹ Card-mod - Add css styles to any lovelace card - #1402 by Ildar_Gabdullin
@Kabala 's post which set me in the right direction of what needed to be done š¹ slider-entity-row - Add sliders to entities cards - #210 by Kabala
Good evening, does this still modify the slider colors? I copied the code, inserted into a manual card to test only changing the entity. Iām unable to change slider colors and havenāt figured out the difference.
Thanks!
I just checked in my dashboard (I keep a section of experiments) and it is still functioning. I have not made any changes to it since I made the post. Can you confirm that you have card-mod installed? It doesnāt say it in the yaml (with a card_mod: section) but Iām pretty sure it does rely on it.
I do have card-mod installed. My Home Assistant version is 2023.11.0b1 and noticed color changes of the slider and knob while using slider entity row once I upgraded Home Assistant. I had modified the slider bar within my theme.yaml, but that doesnāt seem to work any longer. I seen your code while searching for a solution to my problem. I will continue to work on my problem.
I appreciate your response!
Do you mind taking a look to see my mistake? I havenāt had any luck getting this to work.
type: entities
entities:
entity: light.office_corner_lights
full_row: false
toggle: true
hide_state: true
step: 10
- entity: light.office_center_light
toggle: true
step: 10
style:
slider-entity-row:
ha-slider:
paper-progress:
ha-entity-toggle:
ha-switch {
@jschafermo I did not realize it before, but I noticed today, that you were running 2023.11b1; I was still on 2023.10.x when you originally posted and my card worked fine. Now, Iām on 2023.11.1 and my card_mod is broken. I did some work with it today and figured out most of the new syntax and made some improvements.
YAML code
type: entities
entities:
toggle: true
hide_state: false
step: 10
card_mod:
style:
ha-slider:
div.container {
--md-sys-color-primary: blue;
{% if states(config.entity) == "on" %}
--_active-track-color: orange;
--_inactive-track-color: hotpink;
--_handle-color: yellow;
--_hover-handle-color: lime;
{% else %}
--_active-track-color: pink;
--_inactive-track-color: black;
--_handle-color: gray;
--_hover-handle-color: yellow;
{% endif %}
--_pressed-handle-color: cyan;
--_pressed-state-layer-color: yellow;
--_focus-handle-color: white;
ha-entity-toggle:
ha-switch {
--switch-checked-button-color: yellow;
--switch-checked-track-color: orange;
{% else %}
--switch-unchecked-button-color: gray;
--switch-unchecked-track-color: black;
{% endif %}
If you want to use just the slider in full mode, the card_mod syntax can be simplified.
YAML code
type: entities
entities:
full_row: true
toggle: false
hide_state: true
step: 10
card_mod:
style: |
ha-slider {
{% else %}
{% endif %}
EDIT 20231109: Updated code to reflect it is supposed to reside within an entities card.
I appreciate your update. For the life of me, I canāt get this to work on my end. I will keep working on it. Thanks again for your effort!
Update: I have it working. I had posted the code into a manual card for testing which didnāt work. Once I notice my mistake and posted the code into an entities card, slider color changes worked!
Thanks again for your assistance!
Good catch on the missing entities card part. Iāve updated the code above; I just forgot to copy that part from my test-bed
Just for fun, hereās something for ya:
YAML code
type: entities
entities:
entity: light.living_room_lights
card_mod:
style:
ha-slider:
div.container {
background-image: linear-gradient(to right,red,yellow,green);
--paper-progress-active-color: none;
hi Derek, noticing you use the direct element name variable here, which I also found in the inspector after the move to the new material elements in 2023.11.
would you please care to have a look at š¹ Card-mod - Add css styles to any lovelace card - #5335 by Mariusthvdb
where I am trying to follow Pauls suggestion to use the new material variables, but am not succeeding�
seems to me many users would benefit from a direct replacement instruction for those paper slider variables.
I have added this code as well, works great!
Thanks again for taking time as I searched for my error.
missed the āall tokensā on that linked page:
md-slider-active-track-color: green
md-slider-inactive-track-color: yellow
md-slider-focus-handle-color: black
md-slider-pressed-handle-color: white
md-slider-handle-color: pink
md-slider-hover-handle-color: orange
md-slider-handle-shadow-color: red
md-slider-label-container-color: grey
md-slider-label-text-color: purple
all work in theme now.
however, cant find a variable for the container itself. would be a pity if we needed card_mod for that after all
Hi, Iām using the slider entity row for quite a while now.
So far itās been working great, but today I noticed something strange.
Normally when I slide the slider, it will show the values as you slide, so you know where you are. But that value appears to be missing now.
Not sure exactly when this started.
Iām running:
- Core 2023.11.1
- Supervisor 2023.11.3
- Operating System 11.1
- Frontend 20231030.1
The card in question:
entity: input_number.kantoor_target_temperature
name: Set temp kantoor
icon: mdi:temperature-celsius
How is it possible to indent the numerical value in the slider on the right?
It is span class=āstateā.
cards:
entity: input_number.root_192_168_10_66_volume
full_row: true
style: |
.state {
margin-right: 10px;
I have tried this but it does not work.
