Aha. It did too. Should always update before posting on hereā¦
Good work @thomasloven
any chance of an option for a slider, name and percentage aka no icons?
Try setting the icon to something that doesnāt exist.
icon: mdi:no-such-icon
Love the slider/toggle combination, really helps to streamline control!
Is there a way to adjust the toggle offset? Iām using them in conjunction with a switch as the module doesnāt have switch support and they donāt line up with the default entities.
- entity: light.mbr_light_level
toggle: true
type: 'custom:slider-entity-row'
- entity: switch.master_bed_fan
- entity: light.guest_light_level
toggle: true
- entity: switch.guest_bed_fan
- entity: light.guest_bath_light
toggle: true
- entity: switch.guest_bath_fan
Hello!
For the life of me - I CANNOT get slider-entity-row or fold-entity-row to work and I have been wracking my brain for 2 days now trying to figure out why I canāt get this custom to work.
I have installed manually, and VIA HACS - both ways I get the same error - āCustom element doesnāt exist: slider-entity-rowā.
Below are my current resources and snippet of the popup I am trying to create.
resources:
- type: module
url: /local/custom-lovelace/custom-header/custom-header.js?v=0.0.1
- url: /local/custom-lovelace/slider-entity-row/slider-entity-row.js?v=0.0.1
type: js
- url: /local/community/lovelace-fold-entity-row/fold-entity-row.js?v=0.0.1
type: js
- url: /local/custom-lovelace/light-entity-row/light-entity-row.js?v=0.0.1
type: module
#Home Page
- badges: []
cards:
- elements:
#Select Room Text
- entity: remote.harmony_hub
image: /local/text_select_room.png
style:
left: 50%
top: 50%
width: 20%
tap_action:
action: none
type: image
#Navigate to Family Room Page
image: /local/family_room_main_icon.png
style:
left: 35%
top: 11%
width: 20%
tap_action:
action: navigate
navigation_path: '/lovelace/family_room'
type: image
#Navigate to Bedroom Page
image: /local/bedroom_main_icon.png
style:
left: 65%
top: 11%
width: 20%
tap_action:
action: navigate
navigation_path: '/lovelace/bedroom'
type: image
#Navigate to Lighting Control Page
- entity: light.family_room
image: /local/lights_icon_fin.png
style:
left: 91%
top: 94.45%
width: 3%
tap_action:
action: call-service
service: browser_mod.popup
service_data:
title: Popup example
card:
type: entities
entities:
- light.bed_light
- type: custom:slider-entity-row
entity: light.kitchen_lights
deviceID:
- this
- dashboard
type: image
image: /local/tp_background_black_fin.png
type: picture-elements
panel: true
path: home
title: Home
Itās probably something dumb - or maybe I am trying to do something that canāt be done with these customs??
Any help would be MUCH appreciated!
The most recent version of the guide linked from the readme will tell you how to install plugins in Home Assistant 0.107 or later.
Try that method, using the URL that HACS tells you to use (near the bottom).
Or better yet, click the āADD TO LOVELACEā button in HACS, and be done with it.
Hi Folks!
I am really noob on home assistant. I am using this Slider and it is great. thanks for develop it @thomasloven.
I had a question: it is possible to apply it to a group devices? Or some how have one slider that controls all the sliders of the car at once like the header_toggle
controls all toggles?
thansk!
Yes, very simple! Just create a group (of lights) and then assign your slider to this group! Here is the screenshot of how it looks:
And the card code:
entities:
- type: divider
- entity: light.mirek_office
toggle: true
- type: divider
- entity: light.mirek_ceiling
icon: 'mdi:ceiling-light'
toggle: true
- entity: light.mirek_desk_lamp
icon: 'mdi:desk-lamp'
toggle: true
show_header_toggle: false
title: Mirek Office Lights
type: entities
light.mirek_office is actually deconz light group, but it can be as well regular light group created in HA directly. Then it would look like (other group of lights I created for other purpose, so name do not match):
- platform: group
name: Dorota main light
entities:
- light.dorota_main_1
- light.dorota_main_2
- light.dorota_main_3
- light.dorota_main_4
Thanks for the help. That was my approach but I am missing something letĀ“s see:
under my groups.yaml I had:
All Rollers:
icon: mdi:window-open
entities:
- cover.shelly_shsw_25_691ec7
- cover.shelly_shsw_25_b94f56
- cover.shelly_shsw_25_b95255
When I try to use the group in my Lovelace card I need to use group.all_rollers
and group is not a supported entity of custom:slider-entity-row
But what I understand from your answer you can create a group of light and the entity of the group is light.
and not group.
What I am missing?
(sorry probably a silly noob question)
So, there is no way to use it co control a cover group?
No. Groups donāt support that.
You might be able to create a template light and redirect the output of the light brightness control to your cover setting.
show_state: true
In the GUI the state never appear when using Edge but does work in iOS app, chrome and Firefox? Any idea?
Thanks @thomasloven - not sure why it made a difference - but when i used the add to lovelace button it cleared it up - even though the formatting I had should have worked haha.
hello , as i can see % the entity and decrease cursor ?
i see % only i change position the card
Can tell me also if possible decide width and height the card
hello eggman, sorry for my english , i am italy
i install HA 5 days first so i no know as work HA system .
i have install sleder - entity - row , card mod by hacs
if i give you my file example as you put code right so i can copy and test if work ?
also for height / width can you example to write use my entity
my entity is :
entities:
- entity: cover.shelly_shsw_25_ba8b41
full_row: true
title: TAPPARELLA SALA
type: entities
After the last update mine is no longer workingā¦
