Hello everyone. First I want to thank the Home Assistant community for this fantastic project. I love it and seeing it evolve at the speed it does now is simply incredible. Nice Job!
Now to my question. I am looking for an alternative to control the heating in my apartment. Reaching for my phone and opening the Home Assistant app is not so smooth experience. Sometimes I left the phone in the other room or it is out of battery and so on. So I started looking for wall mounted thermostat to control the room temperature. The problem is that in my country having an hvac system is not common at all and usually we have split aircon units with just a remote, so I don’t have the wiring to install a thermostat. As I said I already have all the automation and interface to send IR commands to my air conditioner from my home assistant instance at home, so all I need is just to find a thermostat that I am going to use as human interface to the existing system.
I imagine it to work this way. I set the temperature from the thermostat on the wall and it sends the setting to my Home Assistant (current options for me are WiFi and Z-Wave). Then a simple automation rule sets the same temperature to the air conditioner via IR from my existing setup.
The thing is that as I said all thermostats I found are supposed to be connected to the hvac wiring which I don’t have. First of all I am not sure if it supposed to be powered by 220V and if it does, will the thermostat power on and serve my needs if I just connect it to a power supply? I am worried that Nest Thermostat which supports basically all wiring schemas will fail to recognize the wiring (as there is none) and fail to boot at all, rendering it useless for me.
I have researched the option to mount a tablet and setup HA Dashboard, but this looks a lot bulkier than just having a smart thermostat unit mounted on the wall.
Could you help me with an advice? Are my assumptions correct that any smart thermostat will fail to start if hvac wiring is not in place or can I just use it as control panel? Do you have any suggestions for alternatives - maybe some minimalistic control panel that will expose the control of my air conditioner entity from Home Assistant?
Thank you.
