Smart Thermostat
Based on your window / door sensor this automation turns the thermostat on or off.
You can also specify a delay that is needed to switch the state.
In order to avoid heating in summer, you can specify the weather entity and your “wintermode” temperature to turn it off.
The Delay can be individually set, so you can set a higher delay for example for a door. (So it doesn’t turn off your thermostat, when only opening the door for a minute)
You can specify up to 4 enitites, if you have less than 4 just simply duplicate the entries.
(I’m not sure at this point if there is a better solution).
Be aware the on/off switching based on the current outside temperature triggers only as often your weather entity updates!
Please feel free to enhance this take of mine.
blueprint:
name: Smart Thermostat
description: >-
Based on your window sensor this automation turns the thermostat on or off.
You can also specify the time that is needed to switch the state.
In order to avoid heating in summer, you can specify the weather entity and your winter temperature.
Read more: https://community.home-assistant.io/t/smart-thermostat/258368
domain: automation
input:
window_sensor_1:
name: Window / Door Sensor 1
selector:
entity:
domain: binary_sensor
window_1_delay:
name: Window / Door Sensor 1 Delay
description: "Time the sensor needs to stay the same after change to trigger the automation. This is done to avoid retriggering. (Default = 5s)"
default: 5
selector:
number:
mode: box
min: 0
max: 3600
unit_of_measurement: seconds
window_sensor_2:
name: Window / Door Sensor 2
selector:
entity:
window_2_delay:
name: Window / Door Sensor 2 Delay
default: 5
selector:
number:
mode: box
min: 0
max: 3600
window_sensor_3:
name: Window / Door Sensor 3
selector:
entity:
window_3_delay:
name: Window / Door Sensor 3 Delay
default: 5
selector:
number:
mode: box
min: 0
max: 3600
window_sensor_4:
name: Window / Door Sensor 4
selector:
entity:
window_4_delay:
name: Window / Door Sensor 4 Delay
default: 5
selector:
number:
mode: box
min: 0
max: 3600
weather:
description: "Specify your weather to get the current outside temperature from."
selector:
entity:
domain: weather
wintermode:
description: "The ouside temperature needs to be below this to activate wintermode. (Default = 16°C)"
default: 16
selector:
number:
step: 0.5
min: 0
max: 150
unit_of_measurement: "°C or °F"
wintermode_delay:
description: "Time the outside temperature neeeds to stay above the wintermode temperature to turn the heating off."
default: 30
selector:
number:
mode: box
min: 1
max: 86400
unit_of_measurement: minutes
thermostat:
selector:
entity:
domain: climate
- platform: state
entity_id: !input window_sensor_1
to: 'off'
for: !input window_1_delay
- platform: state
to: 'on'
- platform: state
entity_id: !input window_sensor_2
to: 'off'
for: !input window_2_delay
- platform: state
to: 'on'
- platform: state
entity_id: !input window_sensor_3
to: 'off'
for: !input window_3_delay
- platform: state
to: 'on'
- platform: state
entity_id: !input window_sensor_4
to: 'off'
for: !input window_4_delay
- platform: state
to: 'on'
- platform: numeric_state
entity_id: !input weather
attribute: temperature
below: !input wintermode
for: !input wintermode_delay
above: !input wintermode
- choose:
- conditions:
- condition: and
conditions:
- condition: state
state: 'off'
- condition: state
state: 'off'
- condition: state
state: 'off'
- condition: state
state: 'off'
- condition: numeric_state
sequence:
- service: climate.set_hvac_mode
hvac_mode: heat
entity_id: !input thermostat
- conditions:
- condition: or
conditions:
- condition: state
state: 'on'
- condition: state
state: 'on'
- condition: state
state: 'on'
- condition: state
state: 'on'
sequence:
hvac_mode: 'off'
default: []
