🧠⁺ Smarter Thermostat
:brain:⁺ Smarter Thermostat
A sophisticated Home Assistant blueprint that intelligently controls your thermostat based on window/door sensors and weather conditions. This automation helps you save energy by automatically managing your heating system while maintaining comfort in your home.
:dart: Key Features
  • Window-Aware Heating: Automatically turns off heating when windows are open
  • Weather-Based Control: Activates winter mode based on outdoor temperature
  • Scheduled Operation: Integrates with Home Assistant schedules
  • Manual Override: Includes bypass functionality for temporary control
  • Smart Delays: Configurable delays to prevent frequent switching
  • Detailed Logging: Comprehensive logging of all state changes and decisions
:arrows_counterclockwise: Operation Logic
1. Normal Operation
The automation enables heating when:
  • Schedule is active
  • Windows are closed
  • Outside temperature is below winter mode threshold
2. Bypass Mode Active
When bypass is ON, the automation:
  • Ignores schedule settings
  • Activates heating if:
3. Safety Features
  • Immediate heating shutdown when windows open
  • Temperature-based activation to prevent unnecessary heating in warmer weather
  • Configurable delays to prevent system stress from rapid switching
:wrench: Installation Guide
Prerequisites
  1. Create a Window/Door Sensor Group
  • Combine all your window/door sensors into a single binary sensor group
  • This can be done using a Binary Sensor Group
  1. Configure Generic Thermostat
  • Create and configure a generic thermostat with:
    • Hot and cold thresholds
    • Temperature sensor
    • Actuator switch
  • You can follow the Generic Thermostat documentation
  1. Create Schedule Helper
  • Add a new schedule helper entity
  • Configure your desired heating schedule
  • This will be used to define when heating is allowed to operate
  1. Set Up Bypass Switch
  • Create an input boolean for the bypass system
  • This will allow manual override of the schedule when needed
  1. Configure Weather Integration
  • If not already present, add a weather integration
  • Configure it for your location
  • This is needed for temperature-based decisions
Blueprint Installation
  1. Add Blueprint to Home Assistant
  2. Configure Entities
  • Select your configured thermostat
  • Choose the weather entity
  • Select the grouped binary sensor
  • Pick your schedule helper
  • Choose the bypass switch
  1. Name Your Automation
  • Give your automation a meaningful name
  • This will help identify it in logs and the UI
  1. Test the Setup
  • Verify all entities are correctly selected
  • Test the window sensor response
  • Check schedule functionality
  • Confirm bypass switch operation
  1. Enjoy Your Smart Heating! :tada:
  • Your smart thermostat automation is now ready
  • Monitor the logbook for operation details
  • Make adjustments as needed
:warning: Additional Notes
  • All temperature values can be in either Celsius or Fahrenheit
  • Window delay should be kept relatively short (5-10 seconds recommended)
  • Winter mode delay should be adjusted based on local climate conditions
  • Multiple window sensors can be grouped into a single binary sensor group
:mag: Debugging
The automation provides detailed logging of all decisions:
Example:
"HEAT mode activated: Schedule ON, Window closed, Temperature 14°C below threshold (16°C)"
"Heating is OFF because: Window is open"
"Heating is OFF because: Temperature (18°C) above threshold (16°C)"
:thinking: Why Another Thermostat Automation?
I couldn’t find a blueprint that perfectly matched my use case. Existing blueprints lacked scheduling functionality, which was crucial for my needs. In my home, I run the heating system between 7 AM and 11 PM, and I needed a bypass switch for occasions when continuous operation is required outside these hours.
The main motivations for creating this blueprint were:
  • Integration of a flexible scheduling system
  • Addition of a bypass switch for manual override
  • Combination of window sensors and weather-based control
  • Need for detailed logging of system decisions
I decided to share this enhanced blueprint with the community, hoping it would help others who have similar requirements for their heating automation.
:test_tube: Experimental Blueprint
Please note that this is an experimental blueprint, still in the testing phase. While it has been used in my own home, there may be undiscovered issues or edge cases that could affect its reliability.
Use this blueprint at your own risk, and be prepared to monitor its performance closely. I recommend thoroughly testing it in a non-critical environment before deploying it in your production setup.
If you encounter any problems or have suggestions for improvement, please feel free to provide feedback on the original forum post or the GitHub repository. Your input will help make this blueprint more robust and useful for the entire community.
:pray: Credits
Based on the original work by Siyez (Smart Thermostat) and alexbabel’s fork (Smart Thermostat 2.0). Modified and enhanced by Murat Çeşmecioğlu.
:memo: Changelog
Version 1.0 (November 11, 2024)
  • Initial release
  • Core features implemented:
    • Window sensor integration
    • Weather-based control
    • Schedule helper support
    • Bypass switch functionality
    • Detailed logging system
Had you notice the following one? Or maybe it has too many features? Or is the scheduling different?
Yes, i noticed that blueprint. It’s a great blueprint by the way.
I just wanted a simple one.
Yes it is quite overwhelming at first.
Thanks for this Blueprint!
Sadly i always get an Issue (Screenshot) when executing this Blueprint:
