I have a Solax X1 Hybrid G4 (Solar PV and Battery).
I could not get the Solax Integration working with the required proxy (issues described here: SolaX inverter Wifi Reverse Proxy setup), so I went down the REST API road.
There is lots of advice about on this forum (including Energy dashboard and Solax grid and battery integration, PV SolaX inverter cloud sensors via API). They are long threads that have evovled. So I’ve put this together as a complete worked example, to get it all working with the HA Energy integration, using Solax as the sole source of data.
The end result…
Here is how I did it…
Pre Requisite
You’ll need a Solax Cloud Account, and your API key details.
Create REST Sensor
First create the REST API sensors:
- platform: rest
resource: https://www.solaxcloud.com/proxyApp/proxy/api/getRealtimeInfo.do?tokenId=XXX&sn=YYY
json_attributes_path: "$.result"
json_attributes:
- yieldtoday
- yieldtotal
- acpower
- uploadTime
- inverterStatus
- feedinpower
- feedinenergy
- consumeenergy
- soc
- batPower
- powerdc1
- batStatus
value_template: 'Active' # dummy value, not used; avoids the "State max length is 255 characters" error
Replace XXX and YYY with the tokenId and SerialNumber found in the Solax Cloud respectively.
EDIT 12 Dec 2022
For other inverters / configurations you may need to edit the json_attributes list above, and make corresponding changes to the template below.
To see what your inverter returns point a web browser at the link below (replacing XXX and YYY):
Create Template Sensors for Solax…
template:
- sensor:
- name: "Solax Yield Today"
state: "{{ state_attr('sensor.solax', 'yieldtoday') }}"
unit_of_measurement: "kWh"
unique_id: solax_2
icon: mdi:flash
device_class: energy
state_class: total_increasing
- name: "Solax Yield Total"
state: "{{ state_attr('sensor.solax', 'yieldtotal') }}"
unique_id: solax_3
icon: mdi:flash
- name: "Solax Inverter Power Total"
unit_of_measurement: "W"
state: "{{ state_attr('sensor.solax', 'acpower') }}"
unique_id: solax_4
icon: mdi:flash
state_class: measurement
- name: "Solax Upload Time"
state: >
{% set time = state_attr('sensor.solax', 'uploadTime') %}
{{ as_timestamp(time) | timestamp_custom('%I:%M %p') }}
unique_id: solax_5
icon: mdi:clock
- name: "Solax Battery Status"
state: "{{ state_attr('sensor.solax', 'batStatus') }}"
unique_id: solax_6
icon: mdi:battery
- name: "Solax Solar Panel"
state: "{{ state_attr('sensor.solax', 'powerdc1') }}"
unique_id: solax_7
icon: mdi:solar-power-variant
- name: "Solax Battery Use"
state: "{{ state_attr('sensor.solax', 'batPower') }}"
unique_id: solax_8
icon: mdi:battery
- name: "Solax Battery Use In"
state: >
{% set attr = state_attr('sensor.solax', 'batPower') %}
{{ attr if is_number(attr) and (attr|float > 0) else 0 }}
unique_id: solax_9
icon: mdi:battery
- name: "Solax Battery Use Out"
state: >
{{ (0 - attr) if is_number(attr) and (attr|float < 0) else 0 }}
unique_id: solax_10
icon: mdi:battery
- name: "Solax Battery"
state: "{{ state_attr('sensor.solax', 'soc') }}"
unit_of_measurement: "%"
device_class: battery
unique_id: solax_12
icon: mdi:battery
- name: "Solax Grid Power"
state: >
{% set attr = state_attr('sensor.solax', 'feedinpower') %}
{{ (0 - attr) if is_number(attr) else 0 }}
unique_id: solax_13
icon: mdi:transmission-tower
- name: "Solax Grid Power in"
state: >
unique_id: solax_14
- name: "Solax Grid Power out"
state: >
unique_id: solax_15
- name: "Solax Energy To Grid"
state: "{{ state_attr('sensor.solax', 'feedinenergy') }}"
unique_id: solax_16
- name: "Solax Energy From Grid"
state: "{{ state_attr('sensor.solax', 'consumeenergy') }}"
unique_id: solax_19
- name: "Solax Status"
unique_id: solax_20
state: >
{% set attr = state_attr('sensor.solax', 'inverterStatus') %}
{% if attr == '100' %}Wait
{% elif attr == '101' %}Check
{% elif attr == '102' %}Normal
{% elif attr == '103' %}Fault
{% elif attr == '104' %}Permanent Fault
{% elif attr == '105' %}Update
{% elif attr == '106' %}EPS Check
{% elif attr == '107' %}EPS
{% elif attr == '108' %}Self-test
{% elif attr == '109' %}Idle
{% elif attr == '110' %}Standby
{% elif attr == '111' %}Pv Wake Up Bat
{% elif attr == '112' %}Gen Check
{% elif attr == '113' %}Gen Run
{% else %}unknown{% endif %}
- name: Total Home Use
unique_id: home use
state: >
{% set battery = states('sensor.solax_battery_use') %}
{% set grid = states('sensor.solax_grid_power') %}
{% set solar = states('sensor.solar_panel_power') %}
{% set total = 0 - battery|float if is_number(battery) else 0 %}
{% set total = total + (solar|float if is_number(solar) else 0) %}
{% set total = total + (grid|float if is_number(grid) else 0) %}
{{ total }}
icon: 'mdi:flash'
unit_of_measurement: W
device_class: power
Notes:
- The
unique_idallows you to customise the Icon / Name in the HA Frontend. - I’ve added
state_classin a few places from previous suggestions so that long term statistics are created. - The
Total Home Usesesnor calculates my home total power consumption from all sources.
PowerCalc
I then used the PowerCalc integration to create energy sensors that can be used in the Energy integration. You’ll need to install this following its instructions (I used HACS).
- platform: powercalc
entity_id: sensor.solax_solar_panel
fixed:
power: "{{states('sensor.solax_solar_panel')}}"
entity_id: sensor.solax_battery_use_in
name: Solar Battery In
fixed:
power: "{{states('sensor.solax_battery_use_in')}}"
entity_id: sensor.solax_battery_use_out
name: Solar Battery Out
fixed:
power: "{{states('sensor.solax_battery_use_out')}}"
entity_id: sensor.measured_power
name: Electric Consumption
fixed:
power: "{{states('sensor.measured_power')}}"
Utility Meter
I use Octopus Go for cheap overnight electricity to charge my battery, so I needed a Utility Meter to manage the peak/off peak tariff in the Energy Integration
utility_meter:
daily_grid:
source: sensor.solax_energy_from_grid
cycle: daily
tariffs:
- peak
- offpeak
This also needed an automation to set the tariff:
alias: Set Electric Tariff
description: "Set Electric Tariff for utility sensor"
- platform: time
at: "00:30:00"
variables:
tariff: offpeak
- platform: time
at: "04:30:00"
variables:
tariff: peak
condition: []
- service: select.select_option
entity_id: select.daily_grid
option: "{{ tariff }}"
mode: single
Energy
To set up the HA energy dashboard, use the following sensors…
- Grid Consumption:
sensor.daily_grid_peakandsensor.daily_grid_offpeak - Return to Grid:
sensor.solax_energy_to_grid - Solar Production:
sensor.solar_panel_energy - Home Battery:
sensor.solar_battery_in_energyandsensor.solar_battery_out_energy
NB: Once added to the dashboard, it will take an hour or two for data to become visible.
HA Frontend
I used the Power Flow Card integration to give a current snapshot of the output (screenshot above), in the same format as the HA Dashboard. You will need to install the Power Flow Card following its instructions (I used HACS).
type: vertical-stack
cards:
- type: entities
entities:
- entity: sensor.solax_upload_time
- entity: sensor.solax_status
- type: custom:power-flow-card
entities:
battery:
consumption: sensor.solax_battery_use_out
production: sensor.solax_battery_use_in
battery_charge: sensor.solax_battery
grid:
consumption: sensor.solax_grid_power_in
production: sensor.solax_grid_power_out
solar: sensor.solax_solar_panel
watt_threshold: 1000
Notes
The value in Energy are an approximation, as the Solax reports data to the cloud once every five minutes, so any peaks / dips in use during the 5 minute slots are missed (e.g. boiling a kettle).
I have found in practice my daily figures agree with other data sources withing 5%.
The way round this is to use the local API intergration to get the data rather than REST API (once the issues issues are solved).
I hope you find this useful!
Suggested improvements welcome.
