Some sort oft bluetooth gateway possible?
my home assistant installation runs on a server in my basement. My Livingroom is so far away to be connect with some bluetooth devices directly to the server.
So, are there any sort of gateway possible that I can connect f. e. Xiaomi Mi Floora to my home assistant installation?
Thx.
I see this issue a bit, here’s how I solved it. Should give you some ideas at least:
There is a great BT to MQTT gateway which I just recently added support for the MiFlora sensor.
Check it out here: https://github.com/zewelor/bt-mqtt-gateway/
