Can anyone confirm that new registrations cant be made? Tried it with the nodered node and in home assistant, both are returning an error on the somfy site.
I have a Somfy gate I can only open using a scene created on my Tahoma platform through the Tahoma integration. I’d like to use the status change of the gate as a trigger to turn on lights - but since the gate is not available on the Somfy API (which would have been accessible through the Somfy integration just like shutters etc) I need to use the Tahoma integration which only gives access to the scene “open gate” rather than the gate as an entity itself. Has anyone encountered this or does anyone know a solution?
Did you try with your own app on the Somfy developper website? If yes, you have to wait some delay. They have a synchronization to perform between their servers. 2 hours before your message, it was ok for me.
Hi Tetienne, I re-created my app on the site. Tried it yesterday and today and same message. After the login prompt on the developer site normally the authorize message appears but instead an error is shown. It does not matter if I use the node-red node or the home assistant integration “wizard”. The error is in dutch:
Er is een fout opgetreden.
Probeer het opnieuw. Als het probleem zich blijft voordoen, neem dan contact op met onze dienst technische ondersteuning.
Hi ceriel, I have exactly the same issue (except for the language of error message). I double checked several times client id and client secret. In my configuration file I have the following lines:
@ceriel@lindi I highly recommend you to use built-in application already configured for HA. Just remove the somfy node within your configuration.yaml. Their is no privacy issue with this.
@Marijn which Connexion do you have IO or RTS? I have Glydea curtains and Velux window. I know TaHoma can do them both but to expensive. Can you perhaps help in what direction I should go?
Hi all, I have the Glydea curtains, RTS protocol and also the Velux window IO protocol.
I don’t want to invest money in the TaHoma since HASS should do it all. Can someone explain me, help me what I should get to get both protocols working? I do see the Zwave protocol is supported too, so it should also connect to that protocol?
Hi Tetienne, thank you for the hint. Now I am able to integrate Somfy. Unfortunately, I can see only one device. But this is not primarily a Home Assistant issue since I also get only one device using the API function in the developer portal.
Maybe good to mention, I am not using Home Assistant cloud.
After removing the configuration.yaml and restarting the integration states I need to enter information in configuration.yaml.
Hello, I’ve been tired of Somfy API so I got myself a KLF 200 Velux box, but could not connect any Somfy IO device so far. Did anyone succeded with that? How to do that? Do I need to unpair the devices from my Tahoma box first and then try to recognize them via Velux web interface as a new device? I am not able to finish setup guide on Velux gateway as it cannot see any somfy device. I have 1 io light controller, a gate and garage door - all with io protocol. Thank you for any advice how to get them into velux.
