@SteveM363 is right, an entity is not created for a button, because the button press itself is treated as an event.
I found that the best solution was to manage the button press events in NodeRed and I got the idea from jimford in this post:
Sonoff zigbee button SNZB-01 issue (only in cloud mode)?
And if you’re interested, here is a stripped back version of my NodeRed button management flow for my 8x SN-ZB01 buttons:
[{"id":"6a4f25f2.3d2c5c","type":"tab","label":"Flow 3","disabled":false,"info":""},{"id":"4ad6f054.f3c1e","type":"switch","z":"6a4f25f2.3d2c5c","name":"","property":"payload.event.command","propertyType":"msg","rules":[{"t":"eq","v":"toggle","vt":"str"},{"t":"eq","v":"on","vt":"str"},{"t":"eq","v":"off","vt":"str"}],"checkall":"true","repair":false,"outputs":3,"x":590,"y":260,"wires":[[],[],[]],"outputLabels":["Single Click","Double Click","Long Press"]},{"id":"7574d4ac.64adcc","type":"server-events","z":"6a4f25f2.3d2c5c","name":"zigbee event monitor","server":"666b1cf9.686414","event_type":"zha_event","exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"waitForRunning":true,"x":160,"y":260,"wires":[["4e4f077.88b18f8","d0f6905c.d78e1","7eb800a8.92f91","a2f56e19.d45e3","67dff8c3.23ea38","2238c1a.6a4763e","6f02eee6.c2ec8","a9713657.7faa18","abfef768.f2b758"]]},{"id":"4e4f077.88b18f8","type":"switch","z":"6a4f25f2.3d2c5c","name":"Button A","property":"payload.event.unique_id","propertyType":"msg","rules":[{"t":"eq","v":"00:12:4b:00:1f:91:61:71:1:0x0006","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":420,"y":260,"wires":[["4ad6f054.f3c1e"]]},{"id":"fa465d17.b23ba","type":"comment","z":"6a4f25f2.3d2c5c","name":"Zigbee button payload List ....","info":"single click payload command = \"toggle\"\ndouble click payload command = \"on\"\nlong press payload command = \"off\"\n","x":180,"y":120,"wires":[]},{"id":"d0f6905c.d78e1","type":"switch","z":"6a4f25f2.3d2c5c","name":"Button B","property":"payload.event.unique_id","propertyType":"msg","rules":[{"t":"eq","v":"00:12:4b:00:1f:91:4a:c5:1:0x0006","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":420,"y":340,"wires":[["2428b3f1.a73ddc"]]},{"id":"7eb800a8.92f91","type":"switch","z":"6a4f25f2.3d2c5c","name":"Button C","property":"payload.event.unique_id","propertyType":"msg","rules":[{"t":"eq","v":"00:12:4b:00:1f:91:60:f0:1:0x0006","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":420,"y":420,"wires":[["7c8ff1f5.284f"]]},{"id":"a2f56e19.d45e3","type":"switch","z":"6a4f25f2.3d2c5c","name":"Button D","property":"payload.event.unique_id","propertyType":"msg","rules":[{"t":"eq","v":"00:12:4b:00:1f:8a:9a:e3:1:0x0006","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":420,"y":500,"wires":[["665a1e7e.94864"]]},{"id":"2428b3f1.a73ddc","type":"switch","z":"6a4f25f2.3d2c5c","name":"","property":"payload.event.command","propertyType":"msg","rules":[{"t":"eq","v":"toggle","vt":"str"},{"t":"eq","v":"on","vt":"str"},{"t":"eq","v":"off","vt":"str"}],"checkall":"true","repair":false,"outputs":3,"x":590,"y":340,"wires":[[],[],[]],"outputLabels":["Single Click","Double Click","Long Press"]},{"id":"7c8ff1f5.284f","type":"switch","z":"6a4f25f2.3d2c5c","name":"","property":"payload.event.command","propertyType":"msg","rules":[{"t":"eq","v":"toggle","vt":"str"},{"t":"eq","v":"on","vt":"str"},{"t":"eq","v":"off","vt":"str"}],"checkall":"true","repair":false,"outputs":3,"x":590,"y":420,"wires":[[],[],[]],"outputLabels":["Single Click","Double Click","Long Press"]},{"id":"665a1e7e.94864","type":"switch","z":"6a4f25f2.3d2c5c","name":"","property":"payload.event.command","propertyType":"msg","rules":[{"t":"eq","v":"toggle","vt":"str"},{"t":"eq","v":"on","vt":"str"},{"t":"eq","v":"off","vt":"str"}],"checkall":"true","repair":false,"outputs":3,"x":590,"y":500,"wires":[[],[],[]],"outputLabels":["Single Click","Double Click","Long Press"]},{"id":"67dff8c3.23ea38","type":"debug","z":"6a4f25f2.3d2c5c","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":130,"y":340,"wires":[]},{"id":"2238c1a.6a4763e","type":"switch","z":"6a4f25f2.3d2c5c","name":"Button E","property":"payload.event.unique_id","propertyType":"msg","rules":[{"t":"eq","v":"00:12:4b:00:1f:8a:aa:fd:1:0x0006","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":420,"y":580,"wires":[["20a964b3.391ebc"]]},{"id":"20a964b3.391ebc","type":"switch","z":"6a4f25f2.3d2c5c","name":"","property":"payload.event.command","propertyType":"msg","rules":[{"t":"eq","v":"toggle","vt":"str"},{"t":"eq","v":"on","vt":"str"},{"t":"eq","v":"off","vt":"str"}],"checkall":"true","repair":false,"outputs":3,"x":590,"y":580,"wires":[[],[],[]],"outputLabels":["Single Click","Double Click","Long Press"]},{"id":"6f02eee6.c2ec8","type":"switch","z":"6a4f25f2.3d2c5c","name":"Button F","property":"payload.event.unique_id","propertyType":"msg","rules":[{"t":"eq","v":"00:12:4b:00:1f:91:99:44:1:0x0006","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":420,"y":660,"wires":[["ede71452.3468c8"]]},{"id":"ede71452.3468c8","type":"switch","z":"6a4f25f2.3d2c5c","name":"","property":"payload.event.command","propertyType":"msg","rules":[{"t":"eq","v":"toggle","vt":"str"},{"t":"eq","v":"on","vt":"str"},{"t":"eq","v":"off","vt":"str"}],"checkall":"true","repair":false,"outputs":3,"x":590,"y":660,"wires":[[],[],[]],"outputLabels":["Single Click","Double Click","Long Press"]},{"id":"a9713657.7faa18","type":"switch","z":"6a4f25f2.3d2c5c","name":"Button G","property":"payload.event.unique_id","propertyType":"msg","rules":[{"t":"eq","v":"00:12:4b:00:1f:90:c8:54:1:0x0006","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":420,"y":740,"wires":[["b6c095e4.f66a68"]]},{"id":"b6c095e4.f66a68","type":"switch","z":"6a4f25f2.3d2c5c","name":"","property":"payload.event.command","propertyType":"msg","rules":[{"t":"eq","v":"toggle","vt":"str"},{"t":"eq","v":"on","vt":"str"},{"t":"eq","v":"off","vt":"str"}],"checkall":"true","repair":false,"outputs":3,"x":590,"y":740,"wires":[[],[],[]],"outputLabels":["Single Click","Double Click","Long Press"]},{"id":"abfef768.f2b758","type":"switch","z":"6a4f25f2.3d2c5c","name":"Button H","property":"payload.event.unique_id","propertyType":"msg","rules":[{"t":"eq","v":"00:12:4b:00:1f:91:99:4e:1:0x0006","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":420,"y":820,"wires":[["1f4e7205.c0edfe"]]},{"id":"1f4e7205.c0edfe","type":"switch","z":"6a4f25f2.3d2c5c","name":"","property":"payload.event.command","propertyType":"msg","rules":[{"t":"eq","v":"toggle","vt":"str"},{"t":"eq","v":"on","vt":"str"},{"t":"eq","v":"off","vt":"str"}],"checkall":"true","repair":false,"outputs":3,"x":590,"y":820,"wires":[[],[],[]],"outputLabels":["Single Click","Double Click","Long Press"]},{"id":"666b1cf9.686414","type":"server","z":"","name":"Home Assistant","addon":true}]
