Sir, thank you so much for sharing this. It worked for me.
Sir i have one requirement.
Whenever a switch or light is turned on or off, i need to inform the owner on his iphone.
I was wondering when an entity shows up/or leaves this conditional card, how can i use the state and entity name to be displayed as a notification?
Thanks for another great card. Finally I was able to achieve some kind of satisfying layout. It uses other great custom cards and layouts, but without making it too complex I created an interface that emulates a windows 10 desktop. I would be nice to have an option for up-down slide (or down-up slide).
Check out Lovelace: Swiper card
Another great card from Thomas! Quick questionā¦I have a entity state switch built out and workingā¦but I was wondering if it was possible to direct multiple entities to the same switch? In other words, I have an entity with 5 different input_select conditions , but I only want 2 of them to display a different switch, instead of duplicating all 3 of the same, is it possible to link them together somehow? Just trying to keep my code cleanā¦thanks again!
im having some problems using this. depending on state im switching between the weather card and the āpicture-glanceā card, which is showing a live feed from a camera. sometimes though it is only showing a red bar.
Is it possible to add a time, so the custom:state-switch will switch between the CARDās every⦠letās say 5 min. ?
love your dashboard. care to elaborate on how you did it? i would love to use some parts for my dashboard.
Iāve installed this through HACS, and it shows up under installed front-end repositories⦠but not in the Lovelace card menu. Normal, or no?
Yes, the card menu only shows the cards built into HA, not any added through HACS or custom resources
Great card:)
Is there a way to make it go back to default view in x minutes?
Specially for @Mariusthvdb, @DavidFW1960
Managed to switch between portrait & landscape orientation for iPhone 5S.
For "portrait" case - had to put everything inside "vertical-stack" card - otherwise the content was not shown (an iOS bug, probably).
type: custom:state-switch
entity: mediaquery
default: all
transition_time: 500
states:
'(orientation: portrait)':
type: vertical-stack
cards:
- type: custom:shutter-card
title: portrait
entities:
- entity: cover.left_living_shutter
buttons_position: left
title_position: top
- entity: cover.bedroom_shutter
title_position: top
all:
type: custom:stack-in-card
mode: horizontal
title: landscape
cards:
card_mod:
style: |
ha-card {
box-shadow: none;
entities:
- entity: cover.screen_keuken
entities:
- entity: cover.raamverduistering_stookhok
is there a ādefaultā for the deviceID operator?
I tried it with default, and āallā but only the exact deviceID match will show, the others simply donāt show at all, and dont display an error either
- type: custom:state-switch
entity: deviceID
default: all
states:
'eaSafari0a':
<<: &desktop-view
mode: horizontal
title: Screens
<<: *header
cards:
card_mod:
style: |
ha-card {
box-shadow: none;
entities:
entities:
'3bChrome7':
<<: *desktop-view
all: # also tried 'default', for any of the non matching deviceID's
title: Screens
<<: *header
entities:
even with the specified deviceId for my mobile app in the iPhone, I cant get it to show up⦠how odd. (and I am 100% certain the deviuceID is correct, because I can play media files to it successfully
wait, that what @Ildar_Gabdullin says above this one too⦠sorry, I overlooked that. need to file an issue here? because the singular card shows fine on iOS. but not embedded in the state-switch, either using deviceID or mediaquery.
using the media query like this:
entity: mediaquery
default: default
states:
'(orientation: landscape)':
cards:
title: Screens
<<: *header
entities:
default:
<<: &desktop-view
mode: horizontal
title: Screens
<<: *header
cards:
card_mod:
style: |
ha-card {
box-shadow: none;
entities:
entities:
works better, and yes, the switch to landscape mode on the iPhone now is ok-ish, still cutting off the right side of the shutter image. It is not messing about the shutter-cardās position and name any longer though.
secondly, this time, it doesnāt fully respect the card-mod header anchorā¦
So I guess we still need the deviceID option:
when using an iPhone display the regular shutter-card (vertically) and when using anything else, show the embedded shutter-card in the stack-in-card (horizontally)
Please give me a screenshot, in my iPhone 5S there is no cutting in landscape+horizontal-stack.
will do, using an iPhone 11pro this is what I see:
since this is becoming way to complicated (and fighting an apparent bug between state-switch and iOS) I am back using plain and simple:
title: Screens
<<: *header
entities:
which respects the header mod and shows the full shutter images.
BTW, in my example the ālandscapeā option covered PC browser & smartphoneās portrait mode - i.e. worked fine w/o cutting.
But we need TWO conditions here:
- orientation=portrait AND device=iPhone
- others
since for iPad in portrait mode there is no need to show the vertical version.
I guess youāre right.
which would be way easier if the deviceID would work. Only create the exception for the iPhoneās (no need to distinguish the orientation in my setup) and create a default for all others devicesā¦
Sorry, could you give me the FULL picture? I mean with iPhoneās aspect ratio
its even happening on Desktop when resizing:
this card simply isnāt suited for horizontal displaying I fearā¦
still the bug should be filed, guess itās not dependent on shutter-card, but havenāt tested that yet
@Ildar_Gabdullin hereās the issue I just filed at State-switch, please add so Thomas gets all info her needs
Here it is:
entity: deviceID
default: all
states:
'b26f5ec0-efa72998': ## for iPhone
entity: mediaquery
default: all
states:
...vertical view
all:
...horizontal view
all:
...horizontal view
Rather cumbersome but may be reduced by using a decluttering-card or yaml anchors.
The full example:
entity: deviceID
default: all
states:
b26f5ec0-efa72998:
entity: mediaquery
default: all
states:
cards:
title: portrait
entities:
title_position: top
title_position: top
all:
mode: horizontal
title: landscape
cards:
card_mod:
style: |
ha-card {
box-shadow: none;
entities:
entities:
all:
mode: horizontal
title: others
cards:
card_mod:
style: |
ha-card {
box-shadow: none;
entities:
entities:
Added a comment - iOS devices are not displaying the state-switch selected card Ā· Issue #56 Ā· thomasloven/lovelace-state-switch Ā· GitHub
This is not just an iOS issue - it happens on PC too.
