I purchased a Geekom miniair11 and installed Home Assistant on it through an Ubuntu usb stick. Prior to installing Home Assistant, I had internet access through the original Windows 11 on the machine and through the Ubuntu OS on the usb stick. I suspect I am having connect errors. It is stuck on the prepraring phase. I have seen other have problem with a Raspberry PI but not a mini PC. Here is a portion of the log
23-09-07 12:15:02 ERROR (MainThread) [supervisor.docker.interface] Can’t install ghcr.io/home-assistant/generic-x86-64-homeassistant:2023.9.0: 500 Server Error for http+docker://localhost/v1.42/images/create?tag=2023.9.0&fromImage=ghcr.io%2Fhome-assistant%2Fgeneric-x86-64-homeassistant&platform=linux%2Famd64: Internal Server Error (“Get “https://ghcr.io/v2/”: net/http: request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers)”)
23-09-07 12:15:02 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
23-09-07 12:15:32 INFO (MainThread) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/generic-x86-64-homeassistant:landingpage to ghcr.io/home-assistant/generic-x86-64-homeassistant:2023.9.0
23-09-07 12:15:32 INFO (MainThread) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/generic-x86-64-homeassistant with tag 2023.9.0.
