Anyone getting these messages in the supervisor log, its been going on for sometime and assumed it would go away at some point as I don’t have adguard or unifi controller installed on my HA. I do have backup running on my HA, I checked my config and i have updated my automations to use backup not snapshot.
Running HA 2021.10.7 on OS 6.6 in Ubuntu 20.04.3
21-11-02 12:15:55 WARNING (MainThread) [supervisor.addons.validate] Add-on config 'snapshot_exclude' is deprecated, 'backup_exclude' should be used instead. Please report this to the maintainer of AdGuard Home
21-11-02 12:15:56 WARNING (MainThread) [supervisor.addons.validate] Add-on config 'snapshot' is deprecated, 'backup' should be used instead. Please report this to the maintainer of UniFi Controller
21-11-02 12:15:56 WARNING (MainThread) [supervisor.addons.validate] Add-on config 'snapshot_exclude' is deprecated, 'backup_exclude' should be used instead. Please report this to the maintainer of AdGuard Home
It is enough that they exist in an installed add-on store for these messages to appear.
Funny : both add-ons are created by frenck
To get rid of them : delete the add-on store they appear in.
Hi Francis, I think I checked for this, I have never had Adguard installed, I did have Unifi Controller but uninstalled when I added Cloud Key hardware. Checking again I don’t have either installed or configured in my system as far as I can tell. Outside of HACS and Integration in HA I am not sure where else to check that maybe some vestige of unifi controller still installed, as I said Adguard has never been installed.
There is already informations about this on this forum. (At least for unifi)
There are also opened PR on both add-ons. This is just a warn. Nothing will break anytime soon. Don’t worry !
I have had this problem for a while and just fixed it using your clue of updating automations. I too have never installed adguard and have never had unifi installed. I do have EdgeOS integration. Can you grep for it in the config directory to see if you have hassio.snaphot.system anywhere? Worth a try.
I eliminated the warning messages by editing the config.json file for the AdGuard and UniFi Add-ons.
I simply replaced instances of the word snapshot with backup in both files then restarted the Supervisor. On startup, its log shows no warnings for the two Add-ons.
On my Home Assistant Supervised system, the files are:
Thanks guys, part of the reason I raised it was that I thought this had been fixed some time around when the change from snapshot to backup occurred. As I don’t have these I was assuming it would not affect my HA instance. Closing this now and will ignore the warnings.
